venom986 2 Posted December 13, 2015 Posted December 13, 2015 Been trying to figure this out for a while and haven't found anything obvious. With the built in EmbyTV, if I have a series recording set to record new episodes only, and it misses an episode will it schedule again if that episode re-airs? (I suspect the answer is no here as it relies on the new flag from SD?) What if I am just leaving it wide open to record a series whether the episodes are new or not? Will it recognize that a given episode has previously been recorded or will I get doubles? What if I'm using the auto organize option for EmbyTV and the episode has been moved to my library? For that matter, will it look at the missing episodes in my library vs the ones I have? Sent from my iPhone using Tapatalk
Luke 42241 Posted December 13, 2015 Posted December 13, 2015 it will record everything from that series including doubles. it's something we hope to expand on in the future.
venom986 2 Posted December 29, 2015 Author Posted December 29, 2015 A belated thanks for the reply Luke. I only just saw it today. I'm guessing that to accomplish this the following would be needed? 1) data design and persistence for tracking recordings, even after deleted (option to forget previous recordings of a given series/show) 2) check these against programs from the guide when scheduling 3) check library against programs from the guide when scheduling? Sent from my iPhone using Tapatalk
venom986 2 Posted December 29, 2015 Author Posted December 29, 2015 Presumably the api already provides everything we'd need for each individual step (or sub-step) and it would just be a case of sticking it in to the scheduler (minus adding the data regarding previously recorded episodes)? Sent from my iPhone using Tapatalk
