Anthony24 2 Posted December 13, 2015 Posted December 13, 2015 rename folder from season 9 to season 10 so Emby will create a new Folder of Season 9 (in a way, starting over) so it would just show those missing episodes, after I put the videos back into Season 9, I get this weird mess, trying to get emby to follow thetvdb bc other shows got confused with wrong titles. but some how the usual 2 other sites (TMDB/IMDB) keep coming back but for now I have the series under thetvdb, Got this working ok, not sure how but I'm good with that. since Season 2 22mins long of 4 episodes.
sh0rty 727 Posted December 13, 2015 Posted December 13, 2015 I really don't know what you want to tell. Gesendet von meinem HTC One M8 mit Tapatalk
Happy2Play 9800 Posted December 13, 2015 Posted December 13, 2015 I believe all you should need to do is refresh the metadata on your multi-episodes. You may need to delete the metadata present representing single episodes.
Solution ebr 16307 Posted December 13, 2015 Solution Posted December 13, 2015 Pretty sure the next library scan will clean this up. 1
