imadork8317 1 Posted December 8, 2013 Posted December 8, 2013 I am sure this topic is somewhere however i cannot seem to find it. I have been lazy and do not put Season folders for my TV shows, so season 1 episodes are mixed with season 7 episodes. It seems like MB is smart enough to sort these by season for me is this correct?
Redshirt 1487 Posted December 8, 2013 Posted December 8, 2013 Yes, but I believe that's still only in the dev builds. It'll be available in the next public build.
Solution Luke 42238 Posted December 8, 2013 Solution Posted December 8, 2013 putting episodes directly in the series folder is not supported in the current release but will be available in the next one. as far as putting season 1 episodes in a season 7 folder - that is not going to be officially supported. it might work, it might not, but i'm not going to ask our team to invest time into testing that. 1
imadork8317 1 Posted December 8, 2013 Author Posted December 8, 2013 putting episodes directly in the series folder is not supported in the current release but will be available in the next one. as far as putting season 1 episodes in a season 7 folder - that is not going to be officially supported. it might work, it might not, but i'm not going to ask our team to invest time into testing that. Glad to hear its coming soon, i am piloting MB as a replacement to MM and this is a feature MM has. I do not have S01 episodes in a S07 folder. What i was trying to say is that all my files for one show are under a single folder named after the TV Show.
Luke 42238 Posted December 8, 2013 Posted December 8, 2013 Perfect, thanks. Perhaps if you decide to make the switch you'll help spread the good word over in MM. 1
moviefan 187 Posted December 10, 2013 Posted December 10, 2013 Off topic but what is MM? Just curious. Never heard of that one.
