danergo 40 Posted December 9, 2015 Posted December 9, 2015 Hi, Guys. Do you know how can I build the mono project from github? Is it possible to do this on Windows and then deploy the exe onto Linux? Or I need to do this on Linux for sure? Thank you.
hurricanehrndz 149 Posted December 9, 2015 Posted December 9, 2015 (edited) Why are you trying to build the mono project? What hardware or distro do you need it for? Edited December 9, 2015 by hurricanehrndz
danergo 40 Posted December 11, 2015 Author Posted December 11, 2015 I wanted to use this on a custom linux build I've made. Next time, please focus on answering the question itself (or if you don't know the answer, just don't reply) Now I found out that mono project needs to build on Linux with xbuild. If anyone else needs this. It's not building on Windows because some library dependencies are not existing. Cheers, danergo
spootdev 56 Posted December 11, 2015 Posted December 11, 2015 I wanted to use this on a custom linux build I've made. Next time, please focus on answering the question itself (or if you don't know the answer, just don't reply) Perhaps you should explain completely what you want to accomplish first you ass. The build chain would be different depending on which system tools are available. But apparently the guy offering help was supposed to read your mind on which stuff is in yer custom linux. 2
