rjay 21 Posted December 9, 2015 Posted December 9, 2015 Finally got Emby Server (latest version as of yesterday) sorted on Windows Server 2012R2 and endpoints are Windows boxes with Kodi 15.2 and Emby Addon installed. The content of the library appears but when you click on a video to play it, it takes a large amount of time before it actually starts. 1 - 2mins start time. I had checked the option to play from the share rather than stream as I figured that would be quicker? and double clicking on the file in the share location only taks 10 or so seconds to start playing in Media Player which kinda of rules out slow network connectivity. Any thoughts on speed related issues? thanks
sh0rty 727 Posted December 9, 2015 Posted December 9, 2015 Using internal subtitles? Log would be helpful... Gesendet von meinem HTC One M8 mit Tapatalk
rjay 21 Posted December 9, 2015 Author Posted December 9, 2015 Need logs from Emby Server or from Kodi workstation? No Subtitle settings turned on Emby Server and default subtitle settings on Kodi.
rjay 21 Posted December 11, 2015 Author Posted December 11, 2015 Bump, which log did you require? thanks
Luke 42185 Posted December 11, 2015 Posted December 11, 2015 Hi, for playback issues please see how to report a problem so that we can best help you. Thanks.
Angelblue05 4132 Posted December 11, 2015 Posted December 11, 2015 (edited) What device are you using for Kodi? May be too low powered to launch plugin paths. You may get a better experience if you use direct paths instead (in the add-on settings > sync option > use direct paths) and reset your database so your content is imported with direct paths instead of plugin. This way, Kodi is fully in charge of launching the playback and it should be quicker. Edited December 11, 2015 by Angelblue05
rjay 21 Posted December 20, 2015 Author Posted December 20, 2015 Sorry for the delayed reply, wanted to do some extended testing to ensure had the problem sorted. I have the direct path option selected since my initial setup and the endpoint devices are i5 or i7 with SSD etc so their performance is more than adaquate for most aspects. I think I have tracked down the delay to the NAS being asleep. Initial playback of the first video lags substantially but after this it seems to be reasonably responsive to playing new video's and navigating the library. thanks for everyones assistance 2
