xXSagaiaXx 25 Posted December 9, 2015 Posted December 9, 2015 Is there a way to edit the channel numbers or station call letters. I just got cable and some of the stations aren't coming up with any data cause there isn't any guide info in zap2it or I have some music stations that I would like to rename so that I know what they are.
xXSagaiaXx 25 Posted December 9, 2015 Author Posted December 9, 2015 I forgot to ask if there was a way to edit the channel order as well. Sent from my SM-N920T using Tapatalk
xXSagaiaXx 25 Posted December 13, 2015 Author Posted December 13, 2015 Has anyone have an idea on how to edit the channel order in the epg? I'm not using any backend software.
Luke 42185 Posted December 13, 2015 Posted December 13, 2015 have you tried going to a channel detail screen, clicking the dot menu, followed by the Edit button?
xXSagaiaXx 25 Posted December 13, 2015 Author Posted December 13, 2015 That works out well @@Luke for editing the station names. Is there any way to edit the numbers? Thanks Sent from my SM-N920T using Tapatalk
xXSagaiaXx 25 Posted December 13, 2015 Author Posted December 13, 2015 Okay Sent from my SM-N920T using Tapatalk
