xccxxx 11 Posted December 7, 2015 Posted December 7, 2015 Setting up a few boxes for relatives to stream from my PC, for this reason I'm forcing a relatively low bitrate in order to save my upload bandwidth (parents don't seem to notice any difference between HD and SD anyways ). One problem is that when a transcoded file plays in Kodi it asks each time to select an audio track and/or a subtitle track. Is there a way to prevent this and have it just default to English audio track or the normal default audio track. Trying to cut down on the confusion for once I hand these over to my parents so they don't have to select this each and every time. Cheers!
Angelblue05 4132 Posted December 7, 2015 Posted December 7, 2015 Not at this time. The issue with transcoding is once it starts playback, you can't switch audio track/subtitle track. And because tracks are not always identified with language, it's hard to build a logic around it. I have tried in the past, and it was a nightmare to get those odd cases to work correctly. The best I could do is auto select the first track. But if the first track is not english, there won't be anything you can do. Sent from my iPhone using Tapatalk
xccxxx 11 Posted December 7, 2015 Author Posted December 7, 2015 (edited) Cheers, thanks for the reply. Another question, do subtitles actually work at all while transcoding?. As playing around with this a bit more I find that the file will never play if I actually select a subtitle track (Playback failed, one or more items failed to play). Selecting any of the audio tracks seems to be fine, but as soon as I select a subtitle track - no playback. I've attached a log file to this post - the first time is playing a film and selecting no subs - it plays fine. The second time is the same film, but this time selecting a subtitle file - results in no playback and an error. Here's the error part of the log 09:14:54 T:1569400680 NOTICE: Creating Demuxer 09:15:24 T:1569400680 ERROR: bool CDVDPlayer::OpenDemuxStream() - Error creating demuxer 09:15:24 T:1569400680 NOTICE: CDVDPlayer::OnExit() 09:15:24 T:1104116712 ERROR: Playlist Player: skipping unplayable item: 0, path [plugin://plugin.video.emby/movies/e95bd0387aca745e3358b943621d8414/?filename=The.Muppet.Movie.1979.720p.BluRay.DTS.6ch.x264-TayTO.mkv&id=e95bd0387aca745e3358b943621d8414&mode=play] 09:15:24 T:1104116712 NOTICE: CDVDPlayer::CloseFile() 09:15:24 T:1104116712 NOTICE: DVDPlayer: waiting for threads to exit kodi.log Edited December 7, 2015 by xccxxx
Angelblue05 4132 Posted December 7, 2015 Posted December 7, 2015 Ok I'll test the scenario to see. Thanks for letting me know. Sent from my iPhone using Tapatalk
xccxxx 11 Posted December 7, 2015 Author Posted December 7, 2015 Great, thanks. I've tested this on a an OpenElec machine and also on a Kindle Fire TV with the same result. Not sure if it would be any different on other operating systems. Bitrate is set at 2Mbps in the Emby settings in order to force transcoding.
hatharry 113 Posted December 18, 2015 Posted December 18, 2015 Hey How do I set emby or kodi to select the first audio track with no subtitles? Thanks
tomimc 13 Posted December 18, 2015 Posted December 18, 2015 Cheers, thanks for the reply. Another question, do subtitles actually work at all while transcoding?. As playing around with this a bit more I find that the file will never play if I actually select a subtitle track (Playback failed, one or more items failed to play). Selecting any of the audio tracks seems to be fine, but as soon as I select a subtitle track - no playback. I've attached a log file to this post - the first time is playing a film and selecting no subs - it plays fine. The second time is the same film, but this time selecting a subtitle file - results in no playback and an error. Here's the error part of the log 09:14:54 T:1569400680 NOTICE: Creating Demuxer 09:15:24 T:1569400680 ERROR: bool CDVDPlayer::OpenDemuxStream() - Error creating demuxer 09:15:24 T:1569400680 NOTICE: CDVDPlayer::OnExit() 09:15:24 T:1104116712 ERROR: Playlist Player: skipping unplayable item: 0, path [plugin://plugin.video.emby/movies/e95bd0387aca745e3358b943621d8414/?filename=The.Muppet.Movie.1979.720p.BluRay.DTS.6ch.x264-TayTO.mkv&id=e95bd0387aca745e3358b943621d8414&mode=play] 09:15:24 T:1104116712 NOTICE: CDVDPlayer::CloseFile() 09:15:24 T:1104116712 NOTICE: DVDPlayer: waiting for threads to exit I have the same problem with some mkv, when kodi ask for audio/sub if i select a sub kodi cant play and same log in emby server. Anyone knows the issue?
Angelblue05 4132 Posted December 18, 2015 Posted December 18, 2015 (edited) I've seen it happen. I don't think we are doing anything wrong addon side, but more testing will be required to be sure. It works for some of my subtitles. At other times, it's almost as if too demanding for the server to burn the subtitles into the video file or maybe it's crashing during the process(maybe issues with unicode characters or something). I will do more testing. Hopefully get to the bottom of this. Sent from my iPhone using Tapatalk Edited December 18, 2015 by Angelblue05
Angelblue05 4132 Posted December 23, 2015 Posted December 23, 2015 (edited) It seems to fail the first time I initiate playback. Then the second time with the same selection, it works fine. Can anyone confirm? Edit: I just found out that we can download internal subs separately from emby and feed it to Kodi. This should solve the issue. Edited December 24, 2015 by Angelblue05
Angelblue05 4132 Posted December 24, 2015 Posted December 24, 2015 (edited) I'll be working on transcoding for the next beta version 1.1.65. This issue is not resolved with 1.1.63-64. Edited December 24, 2015 by Angelblue05
xccxxx 11 Posted December 31, 2015 Author Posted December 31, 2015 (edited) It seems to fail the first time I initiate playback. Then the second time with the same selection, it works fine. Can anyone confirm? I've found that it 'sometimes' will work after multiple attempts, but not always. And even when it does work once it may not work the next time again. Edited December 31, 2015 by xccxxx 1
Angelblue05 4132 Posted December 31, 2015 Posted December 31, 2015 Yeah, well I haven't started working on the transcode yet. But I will make some adjustments. Hopefully it will perform in a more stable way. 1
xccxxx 11 Posted December 31, 2015 Author Posted December 31, 2015 Thanks AngelBlue. I've got a couple of boxes set up for my parents and sister (who live in different parts of the country to me) that are streaming/transcoding from my server. They were given explicit instructions over Xmas to 'not watch any foreign films with subtitles' until I tell them its all working
Angelblue05 4132 Posted January 21, 2016 Posted January 21, 2016 (edited) Thanks for your patience all. Please test this build, let me know if transcode with subtitles works better. This method will be slightly slower on the first playback because the server actually extract the subtitles from the content, which we then append to the player. It should work faster in following playback of the same item. Let me know if it still fails. If so, post your Kodi log, thank you. Try with the latest beta version (1.1.80) and let me know how transcode with subtitles goes. Edited January 22, 2016 by Angelblue05
screwfaze 38 Posted January 23, 2016 Posted January 23, 2016 Hi, Thanks for all the hard work. Regarding the prompt for choosing default subtitle or audio, in my case that is the first audio is usually the one I want and don't ever really need subtitles so would like it if there was no prompts at all and I could always start again and choose them right? Regards, Al 1
Angelblue05 4132 Posted January 23, 2016 Posted January 23, 2016 The issue is that you can't change once the content has started transcode. I could add a setting that selects the default audio track and subtitles(if any). I could maybe make it so you can bind it in keymaps (basically toggle the option, however it'll be only valid for transcode type)? Let me know what you think. Sent from my iPhone using Tapatalk
screwfaze 38 Posted January 23, 2016 Posted January 23, 2016 Hi, Thanks for the reply it's fine I guess it's not really a big deal you probably have more important things to work on I will wait for people more clever than me to come up with the solution. Thanks, Al
Luke 42241 Posted January 24, 2016 Posted January 24, 2016 You would have to virtualize it and stop and restart with the new parameters
