aslaksonal 0 Posted December 2, 2015 Posted December 2, 2015 Multi-disc or multi-file movies used to display with the cover art overlayed with a number in a small green circle to show how many items there were - a main movie and a bonus dis, for example. Sometime in the past month, the display now shows each of the items as a separate selection. I've checked the file structure wiki stuff, and it's not changed. My local file structure hasn't changed. Here's what's worked in the past, and now doesn't: /Spiderman folder.jpg backdrop.jpg folder.xml /Extras backdrop.jpg folder.jpg Extras.nfo movie.xml /VIDEO_TS Etc /Movie backdrop.jpg (and 4 more) Folder.jpg Movie.nfo movie.xml /VIDEO_TS Etc Any help appreciated. al
ebr 16333 Posted December 2, 2015 Posted December 2, 2015 Since you didn't provide any version numbers of anything you are running and what changes you made, I don't know when "before" and "now" are in terms of the software. The structure you have is not really how the system is designed to work - although, with certain settings and caveats, it may work. In your example, the supported structure would be: SpiderMan folder.jpg ... /video_ts /Specials /video_ts Also, the number in the green circle was not the number of items, it was the number of unwatched items.
aslaksonal 0 Posted December 2, 2015 Author Posted December 2, 2015 Sorry . . . System is Windows 8 Pro, current with all MS updates. Emby WMC client is current, according to the "update" button. Server is current as of the new "stable" release today. Since the last time it worked the way it always has, I've changed nothing in my setup. Using the file structure you suggest, only the main movie displays - there's no way to select the "bonus" stuff. What settings should I be looking at on either the server or the client to get it back to the way it was? Thanks al
ebr 16333 Posted December 2, 2015 Posted December 2, 2015 Using the file structure you suggest, only the main movie displays - there's no way to select the "bonus" stuff.
Luke 42239 Posted December 2, 2015 Posted December 2, 2015 So you have a \Movie subfolder under \Spiderman? And then also under \Extras you have \Video_TS? The problem is the movie subfolder. That's not within our supported naming guidelines for movies. Please see: https://github.com/MediaBrowser/Wiki/wiki/Movie%20naming
aslaksonal 0 Posted December 2, 2015 Author Posted December 2, 2015 Not on my system . . . . what else should I check?
Luke 42239 Posted December 2, 2015 Posted December 2, 2015 Try a plain video file in your specials or extras folder. It might be that we haven't implemented folder rips for those.
aslaksonal 0 Posted December 2, 2015 Author Posted December 2, 2015 = = = So you have a \Movie subfolder under \Spiderman? And then also under \Extras you have \Video_TS? The problem is the movie subfolder. That's not within our supported naming guidelines for movies. Please see: = = = A - I've changed the file structure, still not working. B - It DID work until a few weeks ago. What's changed? al
