Drew333 0 Posted December 1, 2015 Posted December 1, 2015 Hello everyone, I have Emby (3.0.5781.3) on Ubuntu Server (14.04) with TVHeadend Server (4.0.7), and the TVHeadend plugin for Emby (TVHclient 1.0.5628.29938). I have Schedules Direct setup for my guide provider, and I have an active membership. I have subscribed to my local antenna channels in Schedules Direct, and I setup Scheduled Direct as a guide provider in Emby using my login, my ZIP code, and using the antenna lineup. Live TV is working, but my guide is not working within Emby. I have tried refreshing the guide data, and even restarting the host machine. What do I need to do to get my guide working?
Solution Luke 42243 Posted December 1, 2015 Solution Posted December 1, 2015 Hi, at this time, you cannot combine a Live TV plugin with the built-in guide data from Schedules Direct. When you install a Live TV plugin such as TVHeadEnd, it takes over and is expected to provide the guide data. In the future hopefully can allow you to mix and match the various pieces a little more, but for now you need to setup your guide data in tv head end. 1
txNgineer 0 Posted December 3, 2015 Posted December 3, 2015 Does Roku count as a Live TV plugin? I am having the same problem but I have only HDHomerun/SchedulesDirect active and am trying to display the guide on the Roku.
Luke 42243 Posted December 4, 2015 Posted December 4, 2015 Roku should work just fine with that combination. Please describe your issue in more detail
