mystic.bertie 23 Posted December 1, 2015 Posted December 1, 2015 My gf is polish and so i have set emby server to download polish subtitles. When i play a movie some characters dont display properly. I did some research on the internet and i have managed to get them working fine in vlc, i had to go into subtitles settings and set subtitle encoding to 'eastern european, windows 1250'. How can i get these subtitles to work properly in Emby? thanks all
Luke 42185 Posted December 1, 2015 Posted December 1, 2015 see if saving them as utf8 makes a difference
mystic.bertie 23 Posted December 2, 2015 Author Posted December 2, 2015 thanks for the reply. I tried what you suggested and it did not work just by doing this, I then changed my language and region settings to Poland, rebooted, now they play in Emby just fine. cheers
