rmiesner69 0 Posted November 29, 2015 Posted November 29, 2015 Library scan fails immediately and just spins when access through manage server library. Here is the log: 2015-11-28 23:26:04.8633 Info - App: Executing Scan media library 2015-11-28 23:26:04.8676 Info - App: Validating media library 2015-11-28 23:26:04.8684 Error - BaseItem: Error refreshing owned items for /var/lib/emby-server/root *** Error Report *** Version: 3.0.5781.3 Command line: /usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe -programdata /var/lib/emby-server -restartpath /usr/lib/emby-server/restart.sh Operating system: Unix 2.6.32.573 Processor count: 4 64-Bit OS: True 64-Bit Process: True Program data path: /var/lib/emby-server Mono: 4.0.3 (Stable 4.0.3.20/d6946b4 Thu Aug 13 12:36:56 UTC 2015) Application Path: /usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe Argument cannot be null. Parameter name: path System.ArgumentNullException at CommonIO.ManagedFileSystem.NormalizePath (System.String path) [0x00000] in <filename unknown>:0 at MediaBrowser.Server.Startup.Common.MbLinkShortcutHandler.Resolve (System.String shortcutPath) [0x00000] in <filename unknown>:0 at CommonIO.ManagedFileSystem.ResolveShortcut (System.String filename) [0x00000] in <filename unknown>:0 at MediaBrowser.Controller.IO.FileData.GetFilteredFileSystemEntries (IDirectoryService directoryService, System.String path, IFileSystem fileSystem, ILogger logger, MediaBrowser.Controller.Library.ItemResolveArgs args, Int32 flattenFolderDepth, Boolean resolveShortcuts) [0x00000] in <filename unknown>:0 at MediaBrowser.Controller.IO.FileData.GetFilteredFileSystemEntries (IDirectoryService directoryService, System.String path, IFileSystem fileSystem, ILogger logger, MediaBrowser.Controller.Library.ItemResolveArgs args, Int32 flattenFolderDepth, Boolean resolveShortcuts) [0x00000] in <filename unknown>:0 at MediaBrowser.Controller.IO.FileData.GetFilteredFileSystemEntries (IDirectoryService directoryService, System.String path, IFileSystem fileSystem, ILogger logger, MediaBrowser.Controller.Library.ItemResolveArgs args, Int32 flattenFolderDepth, Boolean resolveShortcuts) [0x00000] in <filename unknown>:0 at MediaBrowser.Controller.Entities.AggregateFolder.CreateResolveArgs (IDirectoryService directoryService) [0x00000] in <filename unknown>:0 at MediaBrowser.Controller.Entities.AggregateFolder.GetFileSystemChildren (IDirectoryService directoryService) [0x00000] in <filename unknown>:0 at MediaBrowser.Controller.Entities.BaseItem+<RefreshMetadata>c__async1.MoveNext () [0x00000] in <filename unknown>:0 2015-11-28 23:26:04.8697 Error - App: Error *** Error Report *** Version: 3.0.5781.3 Command line: /usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe -programdata /var/lib/emby-server -restartpath /usr/lib/emby-server/restart.sh Operating system: Unix 2.6.32.573 Processor count: 4 64-Bit OS: True 64-Bit Process: True Program data path: /var/lib/emby-server Mono: 4.0.3 (Stable 4.0.3.20/d6946b4 Thu Aug 13 12:36:56 UTC 2015) Application Path: /usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe Argument cannot be null. Parameter name: path System.ArgumentNullException at CommonIO.ManagedFileSystem.NormalizePath (System.String path) [0x00000] in <filename unknown>:0 at MediaBrowser.Server.Startup.Common.MbLinkShortcutHandler.Resolve (System.String shortcutPath) [0x00000] in <filename unknown>:0 at CommonIO.ManagedFileSystem.ResolveShortcut (System.String filename) [0x00000] in <filename unknown>:0 at MediaBrowser.Controller.IO.FileData.GetFilteredFileSystemEntries (IDirectoryService directoryService, System.String path, IFileSystem fileSystem, ILogger logger, MediaBrowser.Controller.Library.ItemResolveArgs args, Int32 flattenFolderDepth, Boolean resolveShortcuts) [0x00000] in <filename unknown>:0 at MediaBrowser.Controller.IO.FileData.GetFilteredFileSystemEntries (IDirectoryService directoryService, System.String path, IFileSystem fileSystem, ILogger logger, MediaBrowser.Controller.Library.ItemResolveArgs args, Int32 flattenFolderDepth, Boolean resolveShortcuts) [0x00000] in <filename unknown>:0 at MediaBrowser.Controller.IO.FileData.GetFilteredFileSystemEntries (IDirectoryService directoryService, System.String path, IFileSystem fileSystem, ILogger logger, MediaBrowser.Controller.Library.ItemResolveArgs args, Int32 flattenFolderDepth, Boolean resolveShortcuts) [0x00000] in <filename unknown>:0 at MediaBrowser.Controller.Entities.AggregateFolder.CreateResolveArgs (IDirectoryService directoryService) [0x00000] in <filename unknown>:0 at MediaBrowser.Controller.Entities.AggregateFolder.GetFileSystemChildren (IDirectoryService directoryService) [0x00000] in <filename unknown>:0 at MediaBrowser.Controller.Entities.Folder.GetNonCachedChildren (IDirectoryService directoryService) [0x00000] in <filename unknown>:0 at MediaBrowser.Controller.Entities.AggregateFolder.GetNonCachedChildren (IDirectoryService directoryService) [0x00000] in <filename unknown>:0 at MediaBrowser.Controller.Entities.Folder+<ValidateChildrenInternal>c__async1.MoveNext () [0x00000] in <filename unknown>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x00000] in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x00000] in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00000] in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00000] in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.GetResult () [0x00000] in <filename unknown>:0 at MediaBrowser.Server.Implementations.Library.LibraryManager+<PerformLibraryValidation>c__async3.MoveNext () [0x00000] in <filename unknown>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x00000] in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x00000] in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00000] in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00000] in <filename unknown>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <filename unknown>:0 at MediaBrowser.Server.Implementations.Library.LibraryManager+<ValidateMediaLibraryInternal>c__async2.MoveNext () [0x00000] in <filename unknown>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x00000] in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x00000] in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00000] in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00000] in <filename unknown>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <filename unknown>:0 at MediaBrowser.Common.Implementations.ScheduledTasks.ScheduledTaskWorker+<ExecuteInternal>c__async2.MoveNext () [0x00000] in <filename unknown>:0 2015-11-28 23:26:04.8697 Info - App: Scan media library Failed after 0 minute(s) and 0 seconds 2015-11-28 23:26:04.8703 Debug - NotificationManager: Sending notification via Dashboard Notifications to user Rusty 2015-11-28 23:26:04.8703 Info - ServerManager: Sending web socket message NotificationAdded 2015-11-28 23:26:04.8703 Info - ServerManager: Sending web socket message ScheduledTaskEnded 2015-11-28 23:26:04.9196 Info - HttpServer: HTTP POST http://192.168.0.18:8096/emby/Sessions/Playing/Progress?itemId=19e5571dd2f60a8ab76f4c015a02d08e&PositionTicks=18150000000&isPaused=false&canSeek=true&PlayMethod=Transcode&QueueableMediaTypes=Video&MediaSourceId=19e5571dd2f60a8ab76f4c015a02d08e&PlaySessionId=9009964eba8b430f92c6e0ad25e6f246&AudioStreamIndex=1 Ip: 192.168.0.3:36288. Headers: User-Agent=Roku/DVP-7.0 (067.00E09021A),Host=192.168.0.18:8096,Accept=*/*,Accept-Encoding=deflate, gzip,X-Emby-Authorization=MediaBrowser Client="Roku", Device="Roku 2", DeviceId="1RG4CS002810", Version="2.15", UserId="ebc18afde2a60efc52da7647ddd6d41a",X-MediaBrowser-Token=fcc0d75e7ab44c0a847e7d3d02592be5,Content-Length=0,Content-Type=application/x-www-form-urlencoded 2015-11-28 23:26:04.9205 Debug - App: PingTranscodingJob PlaySessionId=9009964eba8b430f92c6e0ad25e6f246 2015-11-28 23:26:04.9205 Info - HttpServer: HTTP Response 204 to 192.168.0.3. Time: 1ms. http://192.168.0.18:8096/emby/Sessions/Playing/Progress?itemId=19e5571dd2f60a8ab76f4c015a02d08e&PositionTicks=18150000000&isPaused=false&canSeek=true&PlayMethod=Transcode&QueueableMediaTypes=Video&MediaSourceId=19e5571dd2f60a8ab76f4c015a02d08e&PlaySessionId=9009964eba8b430f92c6e0ad25e6f246&AudioStreamIndex=1 2015-11-28 23:26:05.0429 Info - HttpServer: HTTP POST http://192.168.0.18:8096/emby/ScheduledTasks/Running/2d67d886717cdade18d9640d4ebbb9cb Ip: 192.168.0.14:55194. Headers: Host=192.168.0.18:8096,Connection=keep-alive,Content-Length=0,Accept=*/*,X-MediaBrowser-Token=1dfeeff0e2704d6280e5732e2003d339,User-Agent=Mozilla/5.0 (Windows NT 10.0; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/46.0.2490.86 Safari/537.36,X-Emby-Authorization=MediaBrowser Client="Emby Web Client", Device="Chrome 46.0.2490.86", DeviceId="6201cc9ec2aebc56a9eea504d6ce9d55d7333b0a", Version="3.0.5781.3", UserId="ebc18afde2a60efc52da7647ddd6d41a",Origin=http://192.168.0.18:8096,Accept-Encoding=gzip, deflate,Accept-Language=en-US,en;q=0.8 2015-11-28 23:26:05.0436 Info - App: Executing Scan media library 2015-11-28 23:26:05.0470 Info - App: Validating media library 2015-11-28 23:26:05.0479 Error - BaseItem: Error refreshing owned items for /var/lib/emby-server/root *** Error Report *** Version: 3.0.5781.3 Command line: /usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe -programdata /var/lib/emby-server -restartpath /usr/lib/emby-server/restart.sh Operating system: Unix 2.6.32.573 Processor count: 4 64-Bit OS: True 64-Bit Process: True Program data path: /var/lib/emby-server Mono: 4.0.3 (Stable 4.0.3.20/d6946b4 Thu Aug 13 12:36:56 UTC 2015) Application Path: /usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe Argument cannot be null. Parameter name: path System.ArgumentNullException at CommonIO.ManagedFileSystem.NormalizePath (System.String path) [0x00000] in <filename unknown>:0 at MediaBrowser.Server.Startup.Common.MbLinkShortcutHandler.Resolve (System.String shortcutPath) [0x00000] in <filename unknown>:0 at CommonIO.ManagedFileSystem.ResolveShortcut (System.String filename) [0x00000] in <filename unknown>:0 at MediaBrowser.Controller.IO.FileData.GetFilteredFileSystemEntries (IDirectoryService directoryService, System.String path, IFileSystem fileSystem, ILogger logger, MediaBrowser.Controller.Library.ItemResolveArgs args, Int32 flattenFolderDepth, Boolean resolveShortcuts) [0x00000] in <filename unknown>:0 at MediaBrowser.Controller.IO.FileData.GetFilteredFileSystemEntries (IDirectoryService directoryService, System.String path, IFileSystem fileSystem, ILogger logger, MediaBrowser.Controller.Library.ItemResolveArgs args, Int32 flattenFolderDepth, Boolean resolveShortcuts) [0x00000] in <filename unknown>:0 at MediaBrowser.Controller.IO.FileData.GetFilteredFileSystemEntries (IDirectoryService directoryService, System.String path, IFileSystem fileSystem, ILogger logger, MediaBrowser.Controller.Library.ItemResolveArgs args, Int32 flattenFolderDepth, Boolean resolveShortcuts) [0x00000] in <filename unknown>:0 at MediaBrowser.Controller.Entities.AggregateFolder.CreateResolveArgs (IDirectoryService directoryService) [0x00000] in <filename unknown>:0 at MediaBrowser.Controller.Entities.AggregateFolder.GetFileSystemChildren (IDirectoryService directoryService) [0x00000] in <filename unknown>:0 at MediaBrowser.Controller.Entities.BaseItem+<RefreshMetadata>c__async1.MoveNext () [0x00000] in <filename unknown>:0 2015-11-28 23:26:05.0492 Error - App: Error *** Error Report *** Version: 3.0.5781.3 Command line: /usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe -programdata /var/lib/emby-server -restartpath /usr/lib/emby-server/restart.sh Operating system: Unix 2.6.32.573 Processor count: 4 64-Bit OS: True 64-Bit Process: True Program data path: /var/lib/emby-server Mono: 4.0.3 (Stable 4.0.3.20/d6946b4 Thu Aug 13 12:36:56 UTC 2015) Application Path: /usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe Argument cannot be null. Parameter name: path System.ArgumentNullException at CommonIO.ManagedFileSystem.NormalizePath (System.String path) [0x00000] in <filename unknown>:0 at MediaBrowser.Server.Startup.Common.MbLinkShortcutHandler.Resolve (System.String shortcutPath) [0x00000] in <filename unknown>:0 at CommonIO.ManagedFileSystem.ResolveShortcut (System.String filename) [0x00000] in <filename unknown>:0 at MediaBrowser.Controller.IO.FileData.GetFilteredFileSystemEntries (IDirectoryService directoryService, System.String path, IFileSystem fileSystem, ILogger logger, MediaBrowser.Controller.Library.ItemResolveArgs args, Int32 flattenFolderDepth, Boolean resolveShortcuts) [0x00000] in <filename unknown>:0 at MediaBrowser.Controller.IO.FileData.GetFilteredFileSystemEntries (IDirectoryService directoryService, System.String path, IFileSystem fileSystem, ILogger logger, MediaBrowser.Controller.Library.ItemResolveArgs args, Int32 flattenFolderDepth, Boolean resolveShortcuts) [0x00000] in <filename unknown>:0 at MediaBrowser.Controller.IO.FileData.GetFilteredFileSystemEntries (IDirectoryService directoryService, System.String path, IFileSystem fileSystem, ILogger logger, MediaBrowser.Controller.Library.ItemResolveArgs args, Int32 flattenFolderDepth, Boolean resolveShortcuts) [0x00000] in <filename unknown>:0 at MediaBrowser.Controller.Entities.AggregateFolder.CreateResolveArgs (IDirectoryService directoryService) [0x00000] in <filename unknown>:0 at MediaBrowser.Controller.Entities.AggregateFolder.GetFileSystemChildren (IDirectoryService directoryService) [0x00000] in <filename unknown>:0 at MediaBrowser.Controller.Entities.Folder.GetNonCachedChildren (IDirectoryService directoryService) [0x00000] in <filename unknown>:0 at MediaBrowser.Controller.Entities.AggregateFolder.GetNonCachedChildren (IDirectoryService directoryService) [0x00000] in <filename unknown>:0 at MediaBrowser.Controller.Entities.Folder+<ValidateChildrenInternal>c__async1.MoveNext () [0x00000] in <filename unknown>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x00000] in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x00000] in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00000] in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00000] in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.GetResult () [0x00000] in <filename unknown>:0 at MediaBrowser.Server.Implementations.Library.LibraryManager+<PerformLibraryValidation>c__async3.MoveNext () [0x00000] in <filename unknown>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x00000] in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x00000] in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00000] in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00000] in <filename unknown>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <filename unknown>:0 at MediaBrowser.Server.Implementations.Library.LibraryManager+<ValidateMediaLibraryInternal>c__async2.MoveNext () [0x00000] in <filename unknown>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x00000] in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x00000] in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00000] in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00000] in <filename unknown>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <filename unknown>:0 at MediaBrowser.Common.Implementations.ScheduledTasks.ScheduledTaskWorker+<ExecuteInternal>c__async2.MoveNext () [0x00000] in <filename unknown>:0 2015-11-28 23:26:05.0492 Info - App: Scan media library Failed after 0 minute(s) and 0 seconds 2015-11-28 23:26:05.0497 Debug - NotificationManager: Sending notification via Dashboard Notifications to user Rusty 2015-11-28 23:26:05.0497 Info - ServerManager: Sending web socket message NotificationAdded 2015-11-28 23:26:05.0497 Info - ServerManager: Sending web socket message ScheduledTaskEnded 2015-11-28 23:26:05.9660 Debug - App: OnTranscodeEndRequest job.ActiveRequestCount=0 2015-11-28 23:26:05.9660 Debug - App: Changing kill timer to 1800000ms. JobId aaeb78d0190e40a0b201f29df1f5b6ea PlaySessionId 9009964eba8b430f92c6e0ad25e6f246 2015-11-28 23:26:05.9660 Info - HttpServer: HTTP Response 200 to 192.168.0.3. Time: 2713ms. http://192.168.0.18:8096/emby/videos/19e5571dd2f60a8ab76f4c015a02d08e/hlsdynamic/main/680.ts?DeviceId=1RG4CS002810&MediaSourceId=19e5571dd2f60a8ab76f4c015a02d08e&VideoCodec=h264&AudioCodec=aac&AudioStreamIndex=1&VideoBitrate=1872000&AudioBitrate=128000&MaxAudioChannels=2&MaxFramerate=30&MaxWidth=1920&MaxHeight=1080&Level=41&ClientTime=635843667112362910&MaxRefFrames=8&MaxVideoBitDepth=8&Profile=high&PlaySessionId=9009964eba8b430f92c6e0ad25e6f246&api_key=fcc0d75e7ab44c0a847e7d3d02592be5 2015-11-28 23:26:06.1120 Info - HttpServer: HTTP GET http://192.168.0.18:8096/emby/videos/19e5571dd2f60a8ab76f4c015a02d08e/hlsdynamic/main/681.ts?DeviceId=1RG4CS002810&MediaSourceId=19e5571dd2f60a8ab76f4c015a02d08e&VideoCodec=h264&AudioCodec=aac&AudioStreamIndex=1&VideoBitrate=1872000&AudioBitrate=128000&MaxAudioChannels=2&MaxFramerate=30&MaxWidth=1920&MaxHeight=1080&Level=41&ClientTime=635843667112362910&MaxRefFrames=8&MaxVideoBitDepth=8&Profile=high&PlaySessionId=9009964eba8b430f92c6e0ad25e6f246&api_key=fcc0d75e7ab44c0a847e7d3d02592be5 Ip: 192.168.0.3:36315. Headers: Host=192.168.0.18:8096,User-Agent=Roku/DVP-7.0 (067.00E09021A) 2015-11-28 23:26:06.1130 Debug - App: Cannot stream copy video due to missing keyframe info 2015-11-28 23:26:06.3082 Info - HttpServer: HTTP POST http://192.168.0.18:8096/emby/ScheduledTasks/Running/2d67d886717cdade18d9640d4ebbb9cb Ip: 192.168.0.14:55195. Headers: Host=192.168.0.18:8096,Connection=keep-alive,Content-Length=0,Accept=*/*,X-MediaBrowser-Token=1dfeeff0e2704d6280e5732e2003d339,User-Agent=Mozilla/5.0 (Windows NT 10.0; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/46.0.2490.86 Safari/537.36,X-Emby-Authorization=MediaBrowser Client="Emby Web Client", Device="Chrome 46.0.2490.86", DeviceId="6201cc9ec2aebc56a9eea504d6ce9d55d7333b0a", Version="3.0.5781.3", UserId="ebc18afde2a60efc52da7647ddd6d41a",Origin=http://192.168.0.18:8096,Accept-Encoding=gzip, deflate,Accept-Language=en-US,en;q=0.8 2015-11-28 23:26:06.3089 Info - App: Executing Scan media library 2015-11-28 23:26:06.3127 Info - App: Validating media library 2015-11-28 23:26:06.3136 Error - BaseItem: Error refreshing owned items for /var/lib/emby-server/root *** Error Report *** Version: 3.0.5781.3 Command line: /usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe -programdata /var/lib/emby-server -restartpath /usr/lib/emby-server/restart.sh Operating system: Unix 2.6.32.573 Processor count: 4 64-Bit OS: True 64-Bit Process: True Program data path: /var/lib/emby-server Mono: 4.0.3 (Stable 4.0.3.20/d6946b4 Thu Aug 13 12:36:56 UTC 2015) Application Path: /usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe Argument cannot be null. Parameter name: path System.ArgumentNullException at CommonIO.ManagedFileSystem.NormalizePath (System.String path) [0x00000] in <filename unknown>:0 at MediaBrowser.Server.Startup.Common.MbLinkShortcutHandler.Resolve (System.String shortcutPath) [0x00000] in <filename unknown>:0 at CommonIO.ManagedFileSystem.ResolveShortcut (System.String filename) [0x00000] in <filename unknown>:0 at MediaBrowser.Controller.IO.FileData.GetFilteredFileSystemEntries (IDirectoryService directoryService, System.String path, IFileSystem fileSystem, ILogger logger, MediaBrowser.Controller.Library.ItemResolveArgs args, Int32 flattenFolderDepth, Boolean resolveShortcuts) [0x00000] in <filename unknown>:0 at MediaBrowser.Controller.IO.FileData.GetFilteredFileSystemEntries (IDirectoryService directoryService, System.String path, IFileSystem fileSystem, ILogger logger, MediaBrowser.Controller.Library.ItemResolveArgs args, Int32 flattenFolderDepth, Boolean resolveShortcuts) [0x00000] in <filename unknown>:0 at MediaBrowser.Controller.IO.FileData.GetFilteredFileSystemEntries (IDirectoryService directoryService, System.String path, IFileSystem fileSystem, ILogger logger, MediaBrowser.Controller.Library.ItemResolveArgs args, Int32 flattenFolderDepth, Boolean resolveShortcuts) [0x00000] in <filename unknown>:0 at MediaBrowser.Controller.Entities.AggregateFolder.CreateResolveArgs (IDirectoryService directoryService) [0x00000] in <filename unknown>:0 at MediaBrowser.Controller.Entities.AggregateFolder.GetFileSystemChildren (IDirectoryService directoryService) [0x00000] in <filename unknown>:0 at MediaBrowser.Controller.Entities.BaseItem+<RefreshMetadata>c__async1.MoveNext () [0x00000] in <filename unknown>:0 2015-11-28 23:26:06.3151 Error - App: Error *** Error Report *** Version: 3.0.5781.3 Command line: /usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe -programdata /var/lib/emby-server -restartpath /usr/lib/emby-server/restart.sh Operating system: Unix 2.6.32.573 Processor count: 4 64-Bit OS: True 64-Bit Process: True Program data path: /var/lib/emby-server Mono: 4.0.3 (Stable 4.0.3.20/d6946b4 Thu Aug 13 12:36:56 UTC 2015) Application Path: /usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe Argument cannot be null. Parameter name: path System.ArgumentNullException at CommonIO.ManagedFileSystem.NormalizePath (System.String path) [0x00000] in <filename unknown>:0 at MediaBrowser.Server.Startup.Common.MbLinkShortcutHandler.Resolve (System.String shortcutPath) [0x00000] in <filename unknown>:0 at CommonIO.ManagedFileSystem.ResolveShortcut (System.String filename) [0x00000] in <filename unknown>:0 at MediaBrowser.Controller.IO.FileData.GetFilteredFileSystemEntries (IDirectoryService directoryService, System.String path, IFileSystem fileSystem, ILogger logger, MediaBrowser.Controller.Library.ItemResolveArgs args, Int32 flattenFolderDepth, Boolean resolveShortcuts) [0x00000] in <filename unknown>:0 at MediaBrowser.Controller.IO.FileData.GetFilteredFileSystemEntries (IDirectoryService directoryService, System.String path, IFileSystem fileSystem, ILogger logger, MediaBrowser.Controller.Library.ItemResolveArgs args, Int32 flattenFolderDepth, Boolean resolveShortcuts) [0x00000] in <filename unknown>:0 at MediaBrowser.Controller.IO.FileData.GetFilteredFileSystemEntries (IDirectoryService directoryService, System.String path, IFileSystem fileSystem, ILogger logger, MediaBrowser.Controller.Library.ItemResolveArgs args, Int32 flattenFolderDepth, Boolean resolveShortcuts) [0x00000] in <filename unknown>:0 at MediaBrowser.Controller.Entities.AggregateFolder.CreateResolveArgs (IDirectoryService directoryService) [0x00000] in <filename unknown>:0 at MediaBrowser.Controller.Entities.AggregateFolder.GetFileSystemChildren (IDirectoryService directoryService) [0x00000] in <filename unknown>:0 at MediaBrowser.Controller.Entities.Folder.GetNonCachedChildren (IDirectoryService directoryService) [0x00000] in <filename unknown>:0 at MediaBrowser.Controller.Entities.AggregateFolder.GetNonCachedChildren (IDirectoryService directoryService) [0x00000] in <filename unknown>:0 at MediaBrowser.Controller.Entities.Folder+<ValidateChildrenInternal>c__async1.MoveNext () [0x00000] in <filename unknown>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x00000] in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x00000] in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00000] in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00000] in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.GetResult () [0x00000] in <filename unknown>:0 at MediaBrowser.Server.Implementations.Library.LibraryManager+<PerformLibraryValidation>c__async3.MoveNext () [0x00000] in <filename unknown>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x00000] in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x00000] in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00000] in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00000] in <filename unknown>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <filename unknown>:0 at MediaBrowser.Server.Implementations.Library.LibraryManager+<ValidateMediaLibraryInternal>c__async2.MoveNext () [0x00000] in <filename unknown>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x00000] in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x00000] in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00000] in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00000] in <filename unknown>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <filename unknown>:0 at MediaBrowser.Common.Implementations.ScheduledTasks.ScheduledTaskWorker+<ExecuteInternal>c__async2.MoveNext () [0x00000] in <filename unknown>:0 2015-11-28 23:26:06.3151 Info - App: Scan media library Failed after 0 minute(s) and 0 seconds 2015-11-28 23:26:06.3156 Debug - NotificationManager: Sending notification via Dashboard Notifications to user Rusty 2015-11-28 23:26:06.3156 Info - ServerManager: Sending web socket message NotificationAdded 2015-11-28 23:26:06.3156 Info - ServerManager: Sending web socket message ScheduledTaskEnded 2015-11-28 23:26:07.3333 Info - HttpServer: HTTP POST http://192.168.0.18:8096/emby/ScheduledTasks/Running/2d67d886717cdade18d9640d4ebbb9cb Ip: 192.168.0.14:55196. Headers: Host=192.168.0.18:8096,Connection=keep-alive,Content-Length=0,Accept=*/*,X-MediaBrowser-Token=1dfeeff0e2704d6280e5732e2003d339,User-Agent=Mozilla/5.0 (Windows NT 10.0; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/46.0.2490.86 Safari/537.36,X-Emby-Authorization=MediaBrowser Client="Emby Web Client", Device="Chrome 46.0.2490.86", DeviceId="6201cc9ec2aebc56a9eea504d6ce9d55d7333b0a", Version="3.0.5781.3", UserId="ebc18afde2a60efc52da7647ddd6d41a",Origin=http://192.168.0.18:8096,Accept-Encoding=gzip, deflate,Accept-Language=en-US,en;q=0.8 2015-11-28 23:26:07.3333 Info - App: Executing Scan media library 2015-11-28 23:26:07.3375 Info - App: Validating media library 2015-11-28 23:26:07.3383 Error - BaseItem: Error refreshing owned items for /var/lib/emby-server/root *** Error Report *** Version: 3.0.5781.3 Command line: /usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe -programdata /var/lib/emby-server -restartpath /usr/lib/emby-server/restart.sh Operating system: Unix 2.6.32.573 Processor count: 4 64-Bit OS: True 64-Bit Process: True Program data path: /var/lib/emby-server Mono: 4.0.3 (Stable 4.0.3.20/d6946b4 Thu Aug 13 12:36:56 UTC 2015) Application Path: /usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe Argument cannot be null. Parameter name: path System.ArgumentNullException at CommonIO.ManagedFileSystem.NormalizePath (System.String path) [0x00000] in <filename unknown>:0 at MediaBrowser.Server.Startup.Common.MbLinkShortcutHandler.Resolve (System.String shortcutPath) [0x00000] in <filename unknown>:0 at CommonIO.ManagedFileSystem.ResolveShortcut (System.String filename) [0x00000] in <filename unknown>:0 at MediaBrowser.Controller.IO.FileData.GetFilteredFileSystemEntries (IDirectoryService directoryService, System.String path, IFileSystem fileSystem, ILogger logger, MediaBrowser.Controller.Library.ItemResolveArgs args, Int32 flattenFolderDepth, Boolean resolveShortcuts) [0x00000] in <filename unknown>:0 at MediaBrowser.Controller.IO.FileData.GetFilteredFileSystemEntries (IDirectoryService directoryService, System.String path, IFileSystem fileSystem, ILogger logger, MediaBrowser.Controller.Library.ItemResolveArgs args, Int32 flattenFolderDepth, Boolean resolveShortcuts) [0x00000] in <filename unknown>:0 at MediaBrowser.Controller.IO.FileData.GetFilteredFileSystemEntries (IDirectoryService directoryService, System.String path, IFileSystem fileSystem, ILogger logger, MediaBrowser.Controller.Library.ItemResolveArgs args, Int32 flattenFolderDepth, Boolean resolveShortcuts) [0x00000] in <filename unknown>:0 at MediaBrowser.Controller.Entities.AggregateFolder.CreateResolveArgs (IDirectoryService directoryService) [0x00000] in <filename unknown>:0 at MediaBrowser.Controller.Entities.AggregateFolder.GetFileSystemChildren (IDirectoryService directoryService) [0x00000] in <filename unknown>:0 at MediaBrowser.Controller.Entities.BaseItem+<RefreshMetadata>c__async1.MoveNext () [0x00000] in <filename unknown>:0 2015-11-28 23:26:07.3396 Error - App: Error *** Error Report *** Version: 3.0.5781.3 Command line: /usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe -programdata /var/lib/emby-server -restartpath /usr/lib/emby-server/restart.sh Operating system: Unix 2.6.32.573 Processor count: 4 64-Bit OS: True 64-Bit Process: True Program data path: /var/lib/emby-server Mono: 4.0.3 (Stable 4.0.3.20/d6946b4 Thu Aug 13 12:36:56 UTC 2015) Application Path: /usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe Argument cannot be null. Parameter name: path System.ArgumentNullException at CommonIO.ManagedFileSystem.NormalizePath (System.String path) [0x00000] in <filename unknown>:0 at MediaBrowser.Server.Startup.Common.MbLinkShortcutHandler.Resolve (System.String shortcutPath) [0x00000] in <filename unknown>:0 at CommonIO.ManagedFileSystem.ResolveShortcut (System.String filename) [0x00000] in <filename unknown>:0 at MediaBrowser.Controller.IO.FileData.GetFilteredFileSystemEntries (IDirectoryService directoryService, System.String path, IFileSystem fileSystem, ILogger logger, MediaBrowser.Controller.Library.ItemResolveArgs args, Int32 flattenFolderDepth, Boolean resolveShortcuts) [0x00000] in <filename unknown>:0 at MediaBrowser.Controller.IO.FileData.GetFilteredFileSystemEntries (IDirectoryService directoryService, System.String path, IFileSystem fileSystem, ILogger logger, MediaBrowser.Controller.Library.ItemResolveArgs args, Int32 flattenFolderDepth, Boolean resolveShortcuts) [0x00000] in <filename unknown>:0 at MediaBrowser.Controller.IO.FileData.GetFilteredFileSystemEntries (IDirectoryService directoryService, System.String path, IFileSystem fileSystem, ILogger logger, MediaBrowser.Controller.Library.ItemResolveArgs args, Int32 flattenFolderDepth, Boolean resolveShortcuts) [0x00000] in <filename unknown>:0 at MediaBrowser.Controller.Entities.AggregateFolder.CreateResolveArgs (IDirectoryService directoryService) [0x00000] in <filename unknown>:0 at MediaBrowser.Controller.Entities.AggregateFolder.GetFileSystemChildren (IDirectoryService directoryService) [0x00000] in <filename unknown>:0 at MediaBrowser.Controller.Entities.Folder.GetNonCachedChildren (IDirectoryService directoryService) [0x00000] in <filename unknown>:0 at MediaBrowser.Controller.Entities.AggregateFolder.GetNonCachedChildren (IDirectoryService directoryService) [0x00000] in <filename unknown>:0 at MediaBrowser.Controller.Entities.Folder+<ValidateChildrenInternal>c__async1.MoveNext () [0x00000] in <filename unknown>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x00000] in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x00000] in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00000] in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00000] in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.GetResult () [0x00000] in <filename unknown>:0 at MediaBrowser.Server.Implementations.Library.LibraryManager+<PerformLibraryValidation>c__async3.MoveNext () [0x00000] in <filename unknown>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x00000] in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x00000] in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00000] in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00000] in <filename unknown>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <filename unknown>:0 at MediaBrowser.Server.Implementations.Library.LibraryManager+<ValidateMediaLibraryInternal>c__async2.MoveNext () [0x00000] in <filename unknown>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x00000] in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x00000] in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00000] in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00000] in <filename unknown>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <filename unknown>:0 at MediaBrowser.Common.Implementations.ScheduledTasks.ScheduledTaskWorker+<ExecuteInternal>c__async2.MoveNext () [0x00000] in <filename unknown>:0 2015-11-28 23:26:07.3396 Info - App: Scan media library Failed after 0 minute(s) and 0 seconds 2015-11-28 23:26:07.3396 Debug - NotificationManager: Sending notification via Dashboard Notifications to user Rusty 2015-11-28 23:26:07.3396 Info - ServerManager: Sending web socket message NotificationAdded 2015-11-28 23:26:07.3403 Info - ServerManager: Sending web socket message ScheduledTaskEnded 2015-11-28 23:26:07.9573 Info - HttpServer: HTTP POST http://192.168.0.18:8096/emby/Sessions/Playing/Progress?itemId=19e5571dd2f60a8ab76f4c015a02d08e&PositionTicks=18180000000&isPaused=false&canSeek=true&PlayMethod=Transcode&QueueableMediaTypes=Video&MediaSourceId=19e5571dd2f60a8ab76f4c015a02d08e&PlaySessionId=9009964eba8b430f92c6e0ad25e6f246&AudioStreamIndex=1 Ip: 192.168.0.3:36288. Headers: User-Agent=Roku/DVP-7.0 (067.00E09021A),Host=192.168.0.18:8096,Accept=*/*,Accept-Encoding=deflate, gzip,X-Emby-Authorization=MediaBrowser Client="Roku", Device="Roku 2", DeviceId="1RG4CS002810", Version="2.15", UserId="ebc18afde2a60efc52da7647ddd6d41a",X-MediaBrowser-Token=fcc0d75e7ab44c0a847e7d3d02592be5,Content-Length=0,Content-Type=application/x-www-form-urlencoded 2015-11-28 23:26:07.9573 Debug - App: PingTranscodingJob PlaySessionId=9009964eba8b430f92c6e0ad25e6f246 2015-11-28 23:26:07.9587 Info - HttpServer: HTTP Response 204 to 192.168.0.3. Time: 1ms. http://192.168.0.18:8096/emby/Sessions/Playing/Progress?itemId=19e5571dd2f60a8ab76f4c015a02d08e&PositionTicks=18180000000&isPaused=false&canSeek=true&PlayMethod=Transcode&QueueableMediaTypes=Video&MediaSourceId=19e5571dd2f60a8ab76f4c015a02d08e&PlaySessionId=9009964eba8b430f92c6e0ad25e6f246&AudioStreamIndex=1 2015-11-28 23:26:09.1587 Debug - App: OnTranscodeEndRequest job.ActiveRequestCount=0 2015-11-28 23:26:09.1587 Debug - App: Changing kill timer to 1800000ms. JobId aaeb78d0190e40a0b201f29df1f5b6ea PlaySessionId 9009964eba8b430f92c6e0ad25e6f246 2015-11-28 23:26:09.1587 Info - HttpServer: HTTP Response 200 to 192.168.0.3. Time: 3047ms. http://192.168.0.18:8096/emby/videos/19e5571dd2f60a8ab76f4c015a02d08e/hlsdynamic/main/681.ts?DeviceId=1RG4CS002810&MediaSourceId=19e5571dd2f60a8ab76f4c015a02d08e&VideoCodec=h264&AudioCodec=aac&AudioStreamIndex=1&VideoBitrate=1872000&AudioBitrate=128000&MaxAudioChannels=2&MaxFramerate=30&MaxWidth=1920&MaxHeight=1080&Level=41&ClientTime=635843667112362910&MaxRefFrames=8&MaxVideoBitDepth=8&Profile=high&PlaySessionId=9009964eba8b430f92c6e0ad25e6f246&api_key=fcc0d75e7ab44c0a847e7d3d02592be5 2015-11-28 23:26:09.3098 Info - HttpServer: HTTP GET http://192.168.0.18:8096/emby/videos/19e5571dd2f60a8ab76f4c015a02d08e/hlsdynamic/main/682.ts?DeviceId=1RG4CS002810&MediaSourceId=19e5571dd2f60a8ab76f4c015a02d08e&VideoCodec=h264&AudioCodec=aac&AudioStreamIndex=1&VideoBitrate=1872000&AudioBitrate=128000&MaxAudioChannels=2&MaxFramerate=30&MaxWidth=1920&MaxHeight=1080&Level=41&ClientTime=635843667112362910&MaxRefFrames=8&MaxVideoBitDepth=8&Profile=high&PlaySessionId=9009964eba8b430f92c6e0ad25e6f246&api_key=fcc0d75e7ab44c0a847e7d3d02592be5 Ip: 192.168.0.3:36315. Headers: Host=192.168.0.18:8096,User-Agent=Roku/DVP-7.0 (067.00E09021A) 2015-11-28 23:26:09.3109 Debug - App: Cannot stream copy video due to missing keyframe info Any help would be appreciated.
Luke 42243 Posted November 29, 2015 Posted November 29, 2015 what have you done since the last successful scan?
rmiesner69 0 Posted November 30, 2015 Author Posted November 30, 2015 the only thing I'm aware of is doing a yum update. I have not added any plugins. Only have 2 plugins. Auto box set and roku thumbnails. When I go to the library in gui it just has a spinning circle and doesn't even list my media paths.
rmiesner69 0 Posted December 1, 2015 Author Posted December 1, 2015 updated to latest development release and still no luck. It blows to download new media and can't view it.
Luke 42243 Posted December 1, 2015 Posted December 1, 2015 Hi, sorry. i'm not really sure how this would have happened, but what i would do is go to the server's program data folder, then under the /root subfolder search for files with the *.mblink extension. inside those files should be paths. see if you have any empty ones and if so, delete them.
Luke 42243 Posted December 1, 2015 Posted December 1, 2015 In addition, I will make sure the next patch release traps this error. If you're building from source it will be checked in tonight.
rmiesner69 0 Posted December 1, 2015 Author Posted December 1, 2015 there were a couple of files in that directory that were blank. I deleted them and restarted with no luck. Can I wipe them out completely and start from scratch? I have not been building from source just installing via rpm
rmiesner69 0 Posted December 1, 2015 Author Posted December 1, 2015 I delete all the mblink files and it gives the same result. When accessing the library gui the circle just spins.
Luke 42243 Posted December 1, 2015 Posted December 1, 2015 please make sure to provide your log again, thanks.
rmiesner69 0 Posted December 1, 2015 Author Posted December 1, 2015 server-63584520126.txtserver-63584520126.txt
rmiesner69 0 Posted December 2, 2015 Author Posted December 2, 2015 Any further hints things to try. My media server is useless at this point. server.txt
Luke 42243 Posted December 2, 2015 Posted December 2, 2015 Well that look has no evidence that you tried to run a scan. but there is one error that is the same as before. i don't know why you're ending up with bad .mblink files. it's almost as if the server is allowing you to enter bad input when it shouldn't. i have the error trapped and handled for the next release. in the meantime i would just clean them up again.
rmiesner69 0 Posted December 3, 2015 Author Posted December 3, 2015 Since the update 2 nights ago It will scan and add media successfully. But when I go the the library page it still has a spinning circle and does not show my media paths or would it allow me to add or edit these paths. Rusty
Luke 42243 Posted December 3, 2015 Posted December 3, 2015 The fix I mentioned hasn't been released yet, unless you're able to run from source. It will be in the next patch release. So until then it's really the same thing that I mentioned in post 13.
jmperezbeth 0 Posted December 4, 2015 Posted December 4, 2015 Same problem here, but I didn't have any empty .mblink files. Have just installed brand new Ubuntu 15.10 repo tough... have also posted in http://emby.media/community/index.php?/topic/28188-massive-update-for-debian-and-ubuntu/.
