e123enitan 276 Posted November 28, 2015 Posted November 28, 2015 (edited) I am not sure what is going on but this process will not stop, just came home powered up my box, the syn process kicks in and kept goin for mins, then stopped, then continued non stop. I have just come off beta into stable, waiting on syn, I shall post further thereafter. Logs in order of recent pull http://xbmclogs.com/puvpzl31s http://xbmclogs.com/pifgwuq8g http://xbmclogs.com/pnuh2osiu http://xbmclogs.com/pdutejxdo http://xbmclogs.com/poftalavj http://xbmclogs.com/psrmmokn9 http://xbmclogs.com/p0zezmqxr http://xbmclogs.com/pvtoaixvg Edited November 28, 2015 by e123enitan
Angelblue05 4132 Posted November 28, 2015 Posted November 28, 2015 (edited) I'm sorry, but I don't understand what you expect? Looking at your logs, I don't see anything odd? The incremental sync works when your server sends a message via websocket. Can you maybe explain the issue or the outcome you expect? Edited November 28, 2015 by Angelblue05
e123enitan 276 Posted November 28, 2015 Author Posted November 28, 2015 I'm sorry, but I don't understand what you expect? Looking at your logs, I don't see anything odd? The incremental sync works when your server sends a message via websocket. Can you maybe explain the issue or the outcome you expect? The process will not stop, I just moved to stable, I did not experienced same issue, after the initial syn, and reboot several times, I did not experienced repeated syn logs http://xbmclogs.com/pyfbd2al3#line-45 http://xbmclogs.com/pxpv3fg83 http://xbmclogs.com/pyfbd2al3
e123enitan 276 Posted November 28, 2015 Author Posted November 28, 2015 (edited) The process will not stop, I just moved to stable, I did not experienced same issue, after the initial syn, and reboot several times, I did not experienced repeated syn logs http://xbmclogs.com/pyfbd2al3#line-45 http://xbmclogs.com/pxpv3fg83 http://xbmclogs.com/pyfbd2al3 Another logs after I rebooted Kodi, this is what I expected ( as below logs), if there is no recent activity in the emby server, why shold the sny process populates so much data, and why is it repeating frequently ( noted is previous logs), practically every second non stop. ANYWAY I AM OK since I moved to stable. loghttp://xbmclogs.com/pu7psprfq http://xbmclogs.com/pqhv0pftc Edited November 28, 2015 by e123enitan
e123enitan 276 Posted November 29, 2015 Author Posted November 29, 2015 The server sends stuff and the client processes it, I think you might be looking in the wrong place and asking the wrong question, the question should be, why is the server sending so many updates. If you can answer that then you can find the root cause. Ok I will research server side, -Thanks
