cdarney3 6 Posted November 27, 2015 Posted November 27, 2015 I've been using Schedulesdirect for nearly two months and now I notice that I'm no longer showing any data when I look at Guide in LiveTV. I have: - Restarted the Emby server several times - Verified my Schedulesdirect account is good (it is - through 10/3/2016) - refreshed the information on the schedulesdirect site - re-input the information for the Guide Providers in the LiveTV section - Manually refreshed guide data - several times I just don't show any guide listings. I assume this has been going on for at least two weeks since it downloads 14 days worth. I turned up logging, restarted the server and refreshed Guide Data. The log is attached. ...Chuck server-63584227260.txt
Solution Luke 42237 Posted November 27, 2015 Solution Posted November 27, 2015 It's unable to access your tuner which is causing your channel list to get wiped out App: Error getting response from http://10.9.51.101 1
cdarney3 6 Posted November 27, 2015 Author Posted November 27, 2015 Well...That was true but I don't know why. The HDHomeRun still showed up as directly connected to the router but I wasn't able to access it. I restarted the HDHR (air gap reset) and noticed that the Tuners were available in the Live TV section of the Emby servers. I refreshed the guide data and they not show up!! Thanks for the help. I'll keep a closer eye on this for a while.
jkanoy 6 Posted December 31, 2015 Posted December 31, 2015 (edited) I'm having this problem, but I am able to access the tuner. I can watch it through the Channels app on my Apple TV 4 and I'm able to access it via its IP address. I get guide data for like 3 channels, everything else is blank. I've tried re-entering my credentials as well as my listings settings and still no luck. Any ideas? I'll post log files shortly. Edited December 31, 2015 by jkanoy
jkanoy 6 Posted December 31, 2015 Posted December 31, 2015 So, I found something interesting in SD website that said if you're using the JSON service you do not need to add a lineup. I deleted my lineup from SD and then refreshed guide data in Emby and it's all there now.
rkulagow 19 Posted January 1, 2016 Posted January 1, 2016 The XML service and the JSON service have two different upstream data sources. If you've been using the XML service, then there isn't an automatic sync to the JSON service. By the same token, if you're exclusively using the JSON service then the "Add a lineup" function on the website doesn't do anything; the JSON service is entirely driven by the API, so it's up to the client to manage all that.
jkanoy 6 Posted January 1, 2016 Posted January 1, 2016 I never found a clear explanation of that, so I had to figure that out on my own. Thanks for the feedback.
