steve1977 67 Posted December 7, 2013 Posted December 7, 2013 I just realized one problem with TV shows for those of us (like me) using Sickbeard. The renaming function is great and I am using it. Situation: thumb is being scraped nicely for every episode, but the naming convention (with XBMC compatibility) is "Show name s01e20-thumb.jpg" is not supported by Sickbeard. So if MBS scrapes the thumb and I later rename with Sickbeard, I have redundant thumb as SB only remains the episode and not the corresponding art. One way would be to follow the XBMC/SB naming convention: Season##\filename.tbn. Any chance or other idea how to keep the renaming function working in SB and still use MBS?
sfnetwork 514 Posted December 7, 2013 Posted December 7, 2013 (edited) yeah, SB should change to latest Frodo naming convention.... http://wiki.xbmc.org/index.php?title=Frodo_FAQ#Local_images Maybe request it on the forum... Anyway, you don't need SB to do metadata or images, just the episode renaming (that you can control 100%) Do you use the XBMC saver? You could use the saver to do all metadata and images using the Frodo XBMC naming convention... If I understood your issue correctly.... Edited December 7, 2013 by sfnetwork 1
steve1977 67 Posted December 7, 2013 Author Posted December 7, 2013 Yes, you understood it perfectly. Agree with you that it is SB that should change. I have just posted on their forum: http://sickbeard.com/forums/viewtopic.php?f=4&t=8358. What happens sometimes is that the episode name changes twice (e.g., fixing a typo on thetvdb) and in this case, I would like to use the renaming function. In this case, MBS would not delete the old posters and I would have plenty of duplicates. You know what I mean? Let's hope that the SB folks will follow the new naming convention soon!
dannypcf 2 Posted December 8, 2013 Posted December 8, 2013 (edited) Hello, Not sure which branch of SB are you using, but the one I am using actually have XBMC v12+ image naming convention in place. Feel free to PM if you want to know more details. Edited December 8, 2013 by dannypcf
steve1977 67 Posted December 8, 2013 Author Posted December 8, 2013 Thanks, this is great to know. I am using the latest master release for windows (build 502). Hope that the changes you are posting will be pushed to the master soon. Is above a developer version or a fork?
sfnetwork 514 Posted December 8, 2013 Posted December 8, 2013 Hello, Not sure which branch of SB are you using, but the one I am using actually have XBMC v12+ image naming convention in place. Feel free to PM if you want to know more details. Ok you got me interested. Where did you get this version? I just do the update as they they come and I don't see that.
sfnetwork 514 Posted December 8, 2013 Posted December 8, 2013 @@dannypcf My version is Alpha 502 and I don't see this. Is there a more recent version or you manually updated the XBMC saver?
Luke 42288 Posted December 8, 2013 Posted December 8, 2013 he's probably running SB from source. they take a while to introduce new versions. i ran from source for several months earlier this year while waiting for web-dl support to be pushed to release.
sfnetwork 514 Posted December 8, 2013 Posted December 8, 2013 he's probably running SB from source. they take a while to introduce new versions. i ran from source for several months earlier this year while waiting for web-dl support to be pushed to release. You mean grab it directly from GitHub?
Luke 42288 Posted December 8, 2013 Posted December 8, 2013 yea. it's kind of a pain to setup so i wouldn't bother. plus it's like our dev builds, things might be broken and/or in-progress.
sfnetwork 514 Posted December 8, 2013 Posted December 8, 2013 yea. it's kind of a pain to setup so i wouldn't bother. plus it's like our dev builds, things might be broken and/or in-progress. Ok, was just curious anyway. The way I do it (and how I think users should) is to only focus on the episode renaming but no metadata or images; let MB server (or MetaBrowser, etc...) handle the rest.
dannypcf 2 Posted December 9, 2013 Posted December 9, 2013 Hello, Yes, it is from GIT, I installed SB in my synology NAS, the SB package points to this GIT source directly. https://github.com/mr-orange/Sick-Beard At first I installed the same version as yours, but I found that there was no support for the latest XBMC naming convention, so I changed to this source. Somehow I found MB3 manages metadata of XBMC very well, so I use MB3 for metadata management now, SB for downloading TV shows and auto-file movement only. 1
Luke 42288 Posted December 9, 2013 Posted December 9, 2013 you can thank sfnetwork for our xbmc metadata management. he really stepped up and helped make it solid. 1
steve1977 67 Posted December 9, 2013 Author Posted December 9, 2013 Hello, Yes, it is from GIT, I installed SB in my synology NAS, the SB package points to this GIT source directly. https://github.com/mr-orange/Sick-Beard At first I installed the same version as yours, but I found that there was no support for the latest XBMC naming convention, so I changed to this source. Somehow I found MB3 manages metadata of XBMC very well, so I use MB3 for metadata management now, SB for downloading TV shows and auto-file movement only. Oh, this one. I prefer not to use this fork as it includes some spyware. Forgot what it was, but some counter or so. Hope that it will be implemented in the masterbranch soon.
