DrWatson 62 Posted November 27, 2015 Posted November 27, 2015 Recently I changed from nextpvr to serverwmc (and I am not sure if this is as a result of that or something else) but i now have double entries in the tv guide - see image. Is there a way I can delete the extra entries or reset it back to scratch. Cheers
Luke 42241 Posted November 27, 2015 Posted November 27, 2015 The refresh guide operation should do it.
DrWatson 62 Posted November 28, 2015 Author Posted November 28, 2015 Yes I would have thought so but that is not the case. The problem is actually that I have a hd homerun hooked to sever wmc and emby is finding it as well (see attached logs). No matter how many times i remove the detected hd homerun emby re adds it. I have to use a 3rd party ltv provider due to the fact that sched direct doesn't cover au and emby doesn't read the in band guide (the direct reading of the hd homerun is what is causing the blank guide entries). On another note the logs that i have posted are missing the first part of the log since emby doesn't sanitize the logs at all and I don't want private information posted here (maybe Emby should have a clean log function to remove all person info like ddns etc). https://dl.dropboxusercontent.com/u/1349444/server-63584299551-clean.zip
mellomade 141 Posted November 28, 2015 Posted November 28, 2015 From the server dashboard - select Live TV - Tuners. Here you see the HDHomerun tuners listed by IP. Click on each tuner and deselect 'enable this tuner' and save. The problem you are having is that EmbyTV (the default LiveTV/DVR system for Emby) autodiscovers your tuners and configures it for you (there is no way to turn this off). This is great for EmbyTV but if you are using a plugin like NextPVR or ServerWMC the tuners are seen twice - once for EmbyTV and once for the plugin. So you just have to disable them for EmbyTV. 1
DrWatson 62 Posted November 28, 2015 Author Posted November 28, 2015 (edited) Yes i must have removed the tuner at least 20 times now as soon there is a lib scan it gets re added and the blanks appear in the guide again. Surely it would make more sense if there is a ltv plugin the ltv from the core should be totally disabled? Edited November 28, 2015 by DrWatson
Olywa123 46 Posted November 28, 2015 Posted November 28, 2015 (edited) I also had this when I was using nextpvr (now just using native support for my HDHomerun), are you definitely doing as mellomade suggests? i.e. clicking on the tuner, unticking 'enable this tuner' and then save? You don't want to 'remove' the tuner (as you say emby will find it again), only disable it. Genuinely don't mean to sound condescending, I just wanted to point out that clicking the black dustbin icon next to the tuner is not the same thing as disabling it. If you disable it (IP address should still be shown), save and then refresh your guide I think this is what worked for me at the time. Edited November 28, 2015 by Olywa123 2
DrWatson 62 Posted November 28, 2015 Author Posted November 28, 2015 Oh ffs now I am retarded into the bargain the tuner is clickable doh Thanks guys 1
