Problem when running Emby from Windows PC
Go to solution Solved by emab,
Hi,
My network setup is as follows:
Windows PC connected through ethernet to router.
Macbook Pro connected via router to WiFi.
Chromecast connected to TV.
When I run Emby server from laptop, and connect my windows PC via a network drive, I can stream videos from PC to the chromecast via my laptop.
However, I'd rather have the server running from my windows PC. When I set it up from there, all devices can connect and login fine, and can also view all videos. From my laptop, I can connect to my PC and watch videos. I can also connect my laptop to the chromecase so the "Ready to cast" screen comes up. If I press play, nothing happens at all.
This only happens when the server is running on my windows PC. Any ideas on why this is an issue?
Thanks,
Eddy.
EDIT: I can cast from the Android mobile app, but not from my laptop.
EDIT2: I cannot appear to be able to cast from the Desktop PC.
Edited by emab
hedgehogg
I know it's obvious but have you checked firewalls?
I have disabled the firewall on my router. Since it worked from my phone I don't think it's an issue with the desktop PC's firewall (which is just windows defender).
I'll try disabling it and see what happens.
EDIT: Tried disabling firewall on both desktop PC and Macbook - didn't seem to make a difference.
Edited by emab
  • Solution
Another weird thing is: although I cannot cast Emby from my wired desktop PC, I can cast a webpage through google chrome.
EDIT: Think I have found the problem. The host PC has a static IP address on my local network: 192.168.0.2. The chromecast is on the same subdomain.
However, in Emby, it says the local address is something completely different (starting with 25.xx.xx.xx). Why is this?
EDIT2: FIXED!
For those who have this problem do this:
On the host computer, go to "Network and Sharing Center"  --->  "Change adapter settings".
Make sure the ethernet connection is the default connection. Maybe disable the others if you're not using them.
Edited by emab
  • Like 1
hedgehogg
Good to see you fixed it and thanks for posting the fix it will help others :)
  • 2 weeks later...
Took some searches to find this topic, but BIG SUGGESTION TO PUT THIS IN THE WIKI or FAQ's.  I had the same thing happen, and it was the combination of changing the binding and disabling the WIFI adaptor.
Thanks for those that contributed.
