Refresh IP Address
Go to solution Solved by Koleckai Silvestri,
dravokivich
If you go into Network and Sharing, do you have multiple network interfaces installed? If so, delete the ones you are not using. If you can connect via Ethernet and WiFi, try turning WiFi off to see if it changes.
Sound similar to this topic.
Hi Folks,
Only getting another look in on this now. I had read the linked thread earlier in the week, but haven't had a chance to do actions outlined in it until just now. The guidelines work. I needed to disable an unused network adaptor.
Cheers
