cherup 3 Posted November 24, 2015 Posted November 24, 2015 (edited) Hi, I am using Emby on OpenElec and just have problems that not all Movies are shown and synced correctly. Using other devices like Android, iOS, Web everything is shown - so I expect a problem with the Kodi Version. Some examples in the Log Files: In my case - Supernatural - Episode 2 is not shown Log File: 20:50:40 T:2684474432 NOTICE: EMBY WriteKodiVideoDB -> SKIP adding episode to Kodi Library, no season assigned - ID: 7868dc1008b82046dc3f4d78447f0edb - Supernatural - Staffel 2 - s02e01 - Während ich starb 20:50:40 T:2684474432 NOTICE: EMBY WriteKodiVideoDB -> Episode Id: 6e871dee109707581004d8537098ceae not found. Same for Vikings: 20:59:10 T:2600588352 NOTICE: EMBY WriteKodiVideoDB -> Episode Id: d9c4100cc09782fb6388c8ff65f6fff0 not found. 20:59:10 T:2600588352 NOTICE: EMBY WriteKodiVideoDB -> SKIP adding episode to Kodi Library, no season assigned - ID: d9c4100cc09782fb6388c8ff65f6fff0 - Vikings - Staffel 1 Attached the full Log. Any Ideas what to do here ? 01_KODI.log Edited November 24, 2015 by cherup
cherup 3 Posted November 24, 2015 Author Posted November 24, 2015 hmm this is working for all other apps without additional information. I am using the "Auto Box Set" Plugin which works great. If for the Kodi app something special needed as for the othert apps or is this a Bug ? I have added the screenshots how it looks like from the GUI and the Metadata...
Angelblue05 4132 Posted November 24, 2015 Posted November 24, 2015 Working with Kodi is not just a matter of displaying the content like other apps. We are actually importing your content into the Kodi database. Since we are doing this, your metadata need to be correct in emby. Make sure in the metadata manager, your episodes have a season number in the season field (not the name field). Make sure your season level also has a season number assigned in the season field (not the name field). From the looks of your screenshot, it looks like your content is not properly identified. You could try to identify your content to see if it properly populate this information. Sent from my iPhone using Tapatalk
cherup 3 Posted November 26, 2015 Author Posted November 26, 2015 Thanks for the support. After tagging is corrected everything is working fine. Gesendet von meinem SM-G900F mit Tapatalk 1
