Installation location
b0dyr0ck2006
Possibly a simple one here but I can't find anything in the forums or wiki on it. I want to install the server in a different location than default but I don't get the option. How can I do this?
Thanks
  • 3 weeks later...
b0dyr0ck2006
Apparently not then, the reason why I asked is because I only have a 128GB SSD as my main drive and found the caching files were taking up a large amount of space in the hidden roaming folder. After some rooting about I worked out that I can point the cache file to a different drive and help to save the building space.
