Issue With Playback
Hello,
I've recently moved to emby docker and have had issues with kodi playback. I usually get no response when hitting play, then sometimes an error mentioning to check log.
Thanks
kodi.log
Edited by fantaxp7
Angelblue05
Post your Kodi log.
Post your Kodi log.
Sorry I uploaded but didn't attach. Fixed that, now posted.
thanks
  • Like 1
Angelblue05
Kodi can't read your path as they are formatted:
/mnt/user/media/movies/The 'Burbs (1989)/The 'Burbs.ISO
In the emby dashboard > library > you'll need to add a path substitution
What interesting is I can use the kodi file browser and play the files on my file server fine. Does that not matter?
Thanks
Angelblue05
Is Kodi located on the same device as your server?
If not, then you need to ensure your path are formatted so they can be accessed from network. Do you use smb? nfs?
Kodi is located on a different device.
SMB works as I can access my files on my windows laptop. I believe NFS is enabled on unraid as well.
Another thing is I can play files on my amazon firetv fine, but I suppose that is accessing a different way?
Angelblue05
If you use smb, your paths need to look like:
\\{computer}\{share}\
I'm not sure about nfs, you'd have to search the forums for examples.
edit: Kodi needs your path to be formatted a certain way to be able to access them. Honestly, you'd find your answer just searching the forums, it's been brought up so many times. :) It's just because the paths currently are I think, local unix paths? They would only be valid if Kodi was installed on the same device as your server.
Edited by Angelblue05
  • Like 1
I understand now. It is working, thanks!
Basically the way docker accesses the files on my unraid server is different that how I am able to access my files on other machines. Makes sense.
  • Like 1
Guest
