tacticalcity 12 Posted November 22, 2015 Posted November 22, 2015 ServerMC is finding all the channels I have turned on in Media Center. But it is only transferring 3 of them to clients? So I am only getting 3 channels to watch. Any clue how to fix this and force it to transfer all the channels it finds and make it so I can watch them all?
mjktg99 35 Posted November 22, 2015 Posted November 22, 2015 Did you run the guide update task on the server?
krustyreturns 191 Posted November 22, 2015 Posted November 22, 2015 Hard to say for sure without the serverwmc log, but try going to the 'channels' tab in serverwmc and unchecking 'Hide DRM Channels'. Then restart emby and see if that makes a difference.
tacticalcity 12 Posted November 28, 2015 Author Posted November 28, 2015 Once I get back from vacation I will both post the log and run the guide update. The hide drm channels is not checked. I;m trying to get it to show the basic channels, like NBC and CBS local affiliates. For some strange reason they are not being made available to be served despite being found.
crunch 0 Posted December 20, 2015 Posted December 20, 2015 had all my channels then did a reboot and half the channel are blocked. these channels are copy freely flagged non drm. nothing is cxhecked off as hidden. i tried checking off hidden and encripted and it does not change the amount of channels that will show see the below log 2015/12/19 18:32:01.694 Non-default Config Settings -------------2015/12/19 18:32:01.694 isAutoStart: True >>Default: False2015/12/19 18:32:01.694 StartupMinimized: True >>Default: False2015/12/19 18:32:01.694 IsCloseToSysTray: True >>Default: False2015/12/19 18:32:01.694 StartWcfService: True >>Default: False2015/12/19 18:32:01.694 Updates_CheckForUpdates: False >>Default: True2015/12/19 18:32:01.694 HideContentProtectedRec: False >>Default: True2015/12/19 18:32:01.694 useEncryptedChannelString: False >>Default: True2015/12/19 18:32:01.694 useDRMChannelString: False >>Default: True2015/12/19 18:32:01.694 Sports_EpisodeInTitle: False >>Default: True2015/12/19 18:32:01.694 HideAllDRMChannels: False >>Default: True2015/12/19 18:32:01.694 UseServiceName: True >>Default: False2015/12/19 18:32:01.694 PrimeViewTimeStart: 18 >>Default: 62015/12/19 18:32:01.694 PrimeViewTimeEnd: 24 >>Default: 232015/12/19 18:32:01.694 RemuxActiveRecordings: False >>Default: True2015/12/19 18:32:01.694 ----------------------------------------- 2015/12/19 18:32:02.099 EnumerateRecorders> Name: Ceton InfiniTV Ethernet (00-80-80-1a) Tuner 6 (00-00-22-00-00-80-80-1a), Space: Digital Cable2015/12/19 18:32:02.099 EnumerateRecorders> Guid: 0a511e69-d85e-4142-9a2c-f0abe879abb72015/12/19 18:32:02.162 EnumerateRecorders> done2015/12/19 18:32:02.193 GetLineUpsAndChannels> started2015/12/19 18:32:02.848 GetLineUpsAndChannels> Total LineUps: 1, Total channels imported: 2352015/12/19 18:32:02.848 GetLineUpsAndChannels> Channels found in database: 5332015/12/19 18:32:02.848 GetLineUpsAndChannels> Ignored Channels> Blocked in WMC: 298, User hidden: 02015/12/19 18:32:02.848 GetLineUpsAndChannels> Strange Channels> Null space: 0, Out-of-range(ignored): 02015/12/19 18:32:02.848 GetLineUpsAndChannels> Radio Channels> TV(audio-only): 0, Presets: 02015/12/19 18:32:02.848 GetLineUpsAndChannels> RadioPresets> Registry: 0, Config: 02015/12/19 18:32:02.848 GetLineUpsAndChannels> Protected Channels> encrypted: 0 DRM: 02015/12/19 18:32:02.848 GetLineUpsAndChannels> Edited Channels> Callsigns: 0, Numbers: 02015/12/19 18:32:02.848 GetLineUpsAndChannels> Channel Groups> Found: 12015/12/19 18:32:02.848 GetLineUpsAndChannels> Ignored Channel Groups> Blocked in WMC: 0, Empty groups: 02015/12/19 18:32:02.848 GetLineUpsAndChannels> done
