Dan64 32 Posted November 21, 2015 Posted November 21, 2015 (edited) I have asked using a client to transcode a file with the following name: "E.T. L'Extra Terrestre - Anniversary Edition (1982) [1080p].mkv" Here a summary of transcoding log: /usr/bin/ffmpeg -i file:"/RAID/EMBY/Movies/Films/Famiglia/E.T. L'Extra Terrestre (1982)/E.T. L'Extra Terrestre - Anniversary Edition (1982) [1080p].mkv" -map_metadata -1 -threads 0 -map 0:0 -map 0:1 -codec:v:0 libx264 -pix_fmt yuv420p -preset superfast -crf 23 -b:v 2789252 -maxrate 2789252 -bufsize 5578504 -vsync vfr -profile:v high -level 41 -force_key_frames "expr:gte(t,n_forced*3)" -copyts -vf "scale=trunc(oh*a/2)*2:min(ih\,1080),subtitles='/RAID/EMBY/Movies/Films/Famiglia/E.T. L'\\\''Extra Terrestre (1982)/E.T. L'\\\''Extra Terrestre - Anniversary Edition (1982) [1080p].mkv:si=0',setpts=PTS -0/TB" -flags -global_header -sc_threshold 0 -codec:a:0 aac -strict experimental -ab 320000 -af "adelay=1,aresample=async=1,asetpts=PTS-0/TB" -hls_time 3 -start_number 0 -hls_list_size 0 -y "/var/lib/emby-server/transcoding-temp/9d60fc450155d8530cb619a063a94223.m3u8" ffmpeg version 2.6.2-1 Copyright (c) 2000-2015 the FFmpeg developers built with gcc 4.9.2 (Debian 4.9.2-10) configuration: --prefix=/usr --extra-version=1 --build-suffix=-ffmpeg --toolchain=hardened --libdir=/usr/lib/x86_64-linux-gnu --incdir=/usr/include/x86_64-linux-gnu --enable-gpl --enable-shared --disable-stripping --enable-avresample --enable-avisynth --enable-ladspa --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libmodplug --enable-libmp3lame --enable-libopenjpeg --enable-libopus --enable-libpulse --enable-libschroedinger --enable-libshine --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvorbis --enable-libwavpack --enable-libwebp --enable-libxvid --enable-opengl --enable-x11grab --enable-libdc1394 --enable-libiec61883 --enable-libzvbi --enable-libzmq --enable-frei0r --enable-libvpx --enable-libx264 --enable-libsoxr --enable-gnutls --enable-openal --enable-libopencv --enable-librtmp --enable-libx265 WARNING: library configuration mismatch Chapter #0:19: start 6574.160000, end 6869.129000 Metadata: title : Chapter 20 Stream #0:0(eng): Video: h264 (High), yuv420p(tv, bt709), 1920x1040, SAR 1:1 DAR 24:13, 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default) Stream #0:1(ita): Audio: ac3, 48000 Hz, 5.1(side), fltp, 448 kb/s (default) Stream #0:2(eng): Audio: aac (LC), 48000 Hz, 5.1, fltp Stream #0:3(ita): Subtitle: subrip (default) (forced) Metadata: title : Sub. Ita. Forced Stream #0:4(ita): Subtitle: subrip Metadata: title : Sub. Ita. Stream #0:5(eng): Subtitle: subrip Metadata: title : Sub. Eng. Not Hearing [Parsed_subtitles_1 @ 0x916cc0] Shaper: FriBidi 0.19.7 (SIMPLE) HarfBuzz-ng 1.0.1 (COMPLEX) [Parsed_subtitles_1 @ 0x916cc0] Unable to open /RAID/EMBY/Movies/Films/Famiglia/E.T. LExtra Terrestre (1982)/E.T. L\Extra Terrestre - Anniversary Edition (1982) [1080p].mkv [AVFilterGraph @ 0x9c4420] Error initializing filter 'subtitles' with args '/RAID/EMBY/Movies/Films/Famiglia/E.T. L\Extra Terrestre (1982)/E.T. L\\Extra Terrestre - Anniversary Edition (1982) [1080p].mkv:si=0' Error opening filters! The name has been changed in: "E.T. L\Extra Terrestre - Anniversary Edition (1982) [1080p].mkv" and with this name is not found ! Edited November 21, 2015 by Dan64
Luke 42243 Posted November 21, 2015 Posted November 21, 2015 We'll look into the characters, but the second part is expected behavior. You renamed the file. You need to refresh that folder or run a library scan.
Dan64 32 Posted November 21, 2015 Author Posted November 21, 2015 (edited) The file has not been renamed, the character ' has been substituted by the backslah during the transcoding process maybe by AVFilterGraph Edited November 21, 2015 by Dan64
