Ian-Highlander 147 Posted November 21, 2015 Posted November 21, 2015 Last minor niggle for now I hope @ebr Now that the sub views work as expected again and we can re-customise the images for them, all is good in the world on that side of things. However, if I enable the sub views I no longer get the backdrops at the top level at all. For example: With sub-views switched off for TV, I quite rightly get the rotating backdrops from the TV shows. If I turn on sub-views for TV Shows to get the next level of views (genres etc) I get no backdrops at all at the top level (the picture on this one is my WMC theme not a backdrop). Then just to throw another level of complexity in, if I put backdrops on the sub levels so that they look like this: At that point the top level seems to inherit those backdrops instead: I can't seem to win Please save my sanity
ebr 16333 Posted November 21, 2015 Posted November 21, 2015 Your first example isn't correct either. "Bones" is selected but the backdrop is for NCIS.
Ian-Highlander 147 Posted November 21, 2015 Author Posted November 21, 2015 (edited) Your first example isn't correct either. "Bones" is selected but the backdrop is for NCIS. That's not how it works, it cycles randomly through all available backdrops in the TV Shows folder changing every few seconds at the top level, not displaying what's selected as by default there wouldn't be anything selected. Edited November 21, 2015 by Ian-Highlander
