Trailers, Fast Forward and Rewind not working.
Go to solution Solved by urbantech,
Hi all,
I have an issue with Emby Theatre for WMC and/or Emby Server running on my QNAP TVS-471.
Since I have moved my Emby Server to my new QNAP TVS-471 Trailers no longer play from the movie menu, but .mov files still playback.
Fast forward & Rewind also have stopped working.
I initially thought the issue was to do with codecs, so I spent a couple of hours meticulously uninstalling Shark 007 codec pack, and installing first FFDShow & then LAV filters but all with no change.
I am not even really sure where I should be looking for the issue, so any guidance would be a great help.
Cheers
bluemonkey07
Check the other thread you double posted in
  • Solution
Ok problem solved, path substitution did the trick. All is now working great!
