seshapiro 0 Posted November 18, 2015 Posted November 18, 2015 I recently added the iphone app. When I sign in, the app sees my server but when click on the server, I get the message Connection Failure. I know the server is running. Why will it not connect?
MSattler 390 Posted November 18, 2015 Posted November 18, 2015 I recently added the iphone app. When I sign in, the app sees my server but when click on the server, I get the message Connection Failure. I know the server is running. Why will it not connect? Are you connecting via wifi, or remotely? Can you access the same emby server via a browser? Is Emby running on a Windows machine, if so did you open port 8096 through the firewall? If accessing remotely did you port forward port 8096 through your router?
Luke 42243 Posted November 18, 2015 Posted November 18, 2015 Hi. Have you ever connected to your Emby Server before with other devices? You might want to check out our wiki article on connectivity: https://github.com/MediaBrowser/Wiki/wiki/Connectivity It goes over common troubleshooting steps. Let us know if you are still having issues, thanks!
cch 0 Posted December 25, 2015 Posted December 25, 2015 Trying to connect for the first time via iphone 5s on the same wi-fi home network. When I first open emby on my iphone, I enter the email and password associated with my emby.connect account. I can see the server as one of the selection, but when I try to connect, I receive the following error Connection Failure We're unable to connect to the selected server right now. Please ensure it is running and try again. Emby server hosted on windows 10 I believe the emby server is running as I see the icon tray Followed the instructions to open the ports 8096 and 8920 on emby server's windows firewall: There is no anti-virus and windows defender is disabled. I'm able to connect on the same machine as the emby server and see the movies that I've added to the library in chrome. I cannot connect via: - the emby app from the iphone - chrome on the iphone. - chrome on another tablet (this is on the same network as the emby server). Is there a different window network setting I need to enable/disable? The error message from the iphone and tablet's chrome.is that ERR_CONNECTION_TIMED_OUT
Luke 42243 Posted December 25, 2015 Posted December 25, 2015 if you're within your home network you could try entering your server's ip address manually rather than using emby connect. see if that works.
