kim_lombard 2 Posted November 15, 2015 Posted November 15, 2015 Trying my hand at doing a Emby build using Emby-master. Visual Studio 2015. Just did a download from GetHub, so I know it's current. Severity Code Description Project File Line Tool Error The "Fody.WeavingTask" task could not be loaded from the assembly C:\Projects\Emby-master\packages\Fody.1.29.3\build\dotnet\..\packages\Fody.1.29.3\Fody.dll. Could not load file or assembly 'file:///C:\Projects\Emby-master\packages\Fody.1.29.3\build\packages\Fody.1.29.3\Fody.dll' or one of its dependencies. The system cannot find the file specified. Confirm that the <UsingTask> declaration is correct, that the assembly and all its dependencies are available, and that the task contains a public class that implements Microsoft.Build.Framework.ITask. MediaBrowser.Model Then, this if I unload the above project to get a clean compile Severity Code Description Project File Line Tool Error An error occurred while signing: SignTool.exe not found. MediaBrowser.ServerApplication Any help greatly appreciated.
Cheesegeezer 3106 Posted November 15, 2015 Posted November 15, 2015 Do you not need to grab the package from nuget and add the assembly.
kim_lombard 2 Posted November 15, 2015 Author Posted November 15, 2015 (edited) Fody.1.29.3 is the latest from nuget. I updated all projects that use it. For some reason, mediabrowser.model is being difficult. I tried removing fody from mediabrowser.model, just in case it didn't really need it. Same error Media.brower theater compiles / runs / plays video / plays live tv. (Emby.Theater-master) Sure would like to get the server working... Any hints, gratefully accepted (windows 10 Enterprise, Visual Studio 2015) I just installed the Windows Software Development Kit (SDK) for Windows 10 to fix the SignTool.exe not found error, but no help. Edited November 15, 2015 by kim_lombard
Cheesegeezer 3106 Posted November 15, 2015 Posted November 15, 2015 Update your mediabrowser.Common nuget I think which contains the model assembly too.
kim_lombard 2 Posted November 15, 2015 Author Posted November 15, 2015 (edited) Found this is the offending MediaBrowser.Model.csproj <Import Project="..\packages\Fody.1.29.2\build\dotnet\Fody.targets" Condition="Exists('..\packages\Fody.1.29.2\build\dotnet\Fody.targets')" /> <Target Name="EnsureNuGetPackageBuildImports" BeforeTargets="PrepareForBuild"> <PropertyGroup> <ErrorText>This project references NuGet package(s) that are missing on this computer. Use NuGet Package Restore to download them. For more information, see http://go.microsoft.com/fwlink/?LinkID=322105. The missing file is {0}.</ErrorText> </PropertyGroup> <Error Condition="!Exists('..\packages\Fody.1.29.2\build\dotnet\Fody.targets')" Text="$([system.String]::Format('$(ErrorText)', '..\packages\Fody.1.29.2\build\dotnet\Fody.targets'))" /> <Error Condition="!Exists('..\packages\Fody.1.29.3\build\dotnet\Fody.targets')" Text="$([system.String]::Format('$(ErrorText)', '..\packages\Fody.1.29.3\build\dotnet\Fody.targets'))" /> </Target> THE ABOVE LINES WERE IN ERROR IN THE MediaBrowser.Model.csproj REPLACE WITH THIS <Import Project="..\packages\Fody.1.29.3\build\dotnet\Fody.targets" Condition="Exists('..\packages\Fody.1.29.3\build\dotnet\Fody.targets')" /> Edited November 16, 2015 by kim_lombard
danergo 40 Posted December 9, 2015 Posted December 9, 2015 Hello, I have a similar problem: Severity Code Description Project File Line Suppression State Error Fody: An unhandled exception occurred: Exception: Unknown custom metadata item kind: 7 StackTrace: at Microsoft.Cci.Pdb.PdbFunction.ReadCustomMetadata(BitAccess bits) in c:\Code\cecil\symbols\pdb\Microsoft.Cci.Pdb\PdbFunction.cs:line 359 at Microsoft.Cci.Pdb.PdbFunction..ctor(ManProcSym proc, BitAccess bits) in c:\Code\cecil\symbols\pdb\Microsoft.Cci.Pdb\PdbFunction.cs:line 270 at Microsoft.Cci.Pdb.PdbFunction.LoadManagedFunctions(BitAccess bits, UInt32 limit, Boolean readStrings) in c:\Code\cecil\symbols\pdb\Microsoft.Cci.Pdb\PdbFunction.cs:line 136 at Microsoft.Cci.Pdb.PdbFile.LoadFuncsFromDbiModule(BitAccess bits, DbiModuleInfo info, IntHashTable names, ArrayList funcList, Boolean readStrings, MsfDirectory dir, Dictionary`2 nameIndex, PdbReader reader) in c:\Code\cecil\symbols\pdb\Microsoft.Cci.Pdb\PdbFile.cs:line 273 at Microsoft.Cci.Pdb.PdbFile.LoadFunctions(Stream read, Dictionary`2& tokenToSourceMapping, String& sourceServerData, Int32& age, Guid& guid) in c:\Code\cecil\symbols\pdb\Microsoft.Cci.Pdb\PdbFile.cs:line 382 at Mono.Cecil.Pdb.PdbReader.PopulateFunctions() in c:\Code\cecil\symbols\pdb\Mono.Cecil.Pdb\PdbReader.cs:line 94 at Mono.Cecil.Pdb.PdbReader.ProcessDebugHeader(ImageDebugDirectory directory, Byte[] header) in c:\Code\cecil\symbols\pdb\Mono.Cecil.Pdb\PdbReader.cs:line 75 at Mono.Cecil.ModuleDefinition.ProcessDebugHeader() in c:\Code\cecil\Mono.Cecil\ModuleDefinition.cs:line 786 at Mono.Cecil.ModuleDefinition.ReadSymbols(ISymbolReader reader) in c:\Code\cecil\Mono.Cecil\ModuleDefinition.cs:line 859 at Mono.Cecil.ModuleReader.ReadSymbols(ModuleDefinition module, ReaderParameters parameters) in c:\Code\cecil\Mono.Cecil\AssemblyReader.cs:line 108 at Mono.Cecil.ModuleReader.CreateModuleFrom(Image image, ReaderParameters parameters) in c:\Code\cecil\Mono.Cecil\AssemblyReader.cs:line 83 at Mono.Cecil.ModuleDefinition.ReadModule(Stream stream, ReaderParameters parameters) in c:\Code\cecil\Mono.Cecil\ModuleDefinition.cs:line 890 at Mono.Cecil.ModuleDefinition.ReadModule(String fileName, ReaderParameters parameters) in c:\Code\cecil\Mono.Cecil\ModuleDefinition.cs:line 874 at InnerWeaver.ReadModule() in c:\TeamCity\buildAgent\work\7495521761d392b9\FodyIsolated\ModuleReader.cs:line 23 at InnerWeaver.Execute() in c:\TeamCity\buildAgent\work\7495521761d392b9\FodyIsolated\InnerWeaver.cs:line 28 Source: Mono.Cecil.Pdb TargetSite: Void ReadCustomMetadata(Microsoft.Cci.Pdb.BitAccess) MediaBrowser.Model I just downloaded the source from git, and put inside VS 2015. I'm trying to compile for Mono with "Release Mono" configuration, however "Debug" failed also with the same error.
t.andre 69 Posted December 14, 2015 Posted December 14, 2015 Hi, I have successful compile with VS 2015 doing these steps. Open MediaBrowser.Model.csproj from the folder MediaBrowser.Model and MediaBrowser.Model.Portable.csproj from the folder MediaBrowser.Model.Portable with a text editor and removed this line: <FodyPath>..\packages\Fody.1.19.1.0</FodyPath> Then update PropertyChanged.Fody from NuGet package for the two projects. Cheers, 1
plastrd 0 Posted January 25, 2016 Posted January 25, 2016 Any chance t.andre's fix will be committed to the github tree? I've been using it for my own builds of the beta branch with no ill effects (this is the result when I followed the steps above).
