arrbee99 1836 Posted November 15, 2015 Posted November 15, 2015 Some help would be appreciated to find my missing TV tuner. On Win 10 pro 64bit I have a Hauppauge DVB-S card installed in main PC, which has disappeared from Emby (see attached screenshot) and hence no TV guide. The card works fine using the Hauppauge app, including TV guide and NPVR also works fine, including TV guide. Think this is since the latest NPVR Emby plug-in update. Am using Dev versions. server-63583252412.txt server-63583228959.txt
Sven 136 Posted November 15, 2015 Posted November 15, 2015 What do you get if you browse to " http://localhost:8866"? I see in the logs "Internal Server Error". So it looks like you have a problem with nextpvr.
arrbee99 1836 Posted November 15, 2015 Author Posted November 15, 2015 I get this 'unable to write' thingy........
Sven 136 Posted November 15, 2015 Posted November 15, 2015 Then you should ask on the NextPVR forums what's wrong. Because something is wrong with the program...
arrbee99 1836 Posted November 15, 2015 Author Posted November 15, 2015 Ok, I'll do that then, though NPVR seems to work OK (took this shot 2 min ago), maybe the plugin...
bluemonkey07 590 Posted November 16, 2015 Posted November 16, 2015 The address you typed in its to access nextpvr web interface so you definately have a issue with nextpvr that needs to be fixed before the plugin will work
Solution arrbee99 1836 Posted November 16, 2015 Author Solution Posted November 16, 2015 Seems to be fixed by following an idea from the NPVR guys, so thanks for making that suggestion. Following this http://forums.nextpvr.com/showthread...049#post490049 thread, involving adding directory "Temporary ASP.NET Files" to the relevant location and restarting the NPVR Service works a charm. Also restarting Emby and refreshing the guide now shows the tuners available and shows an up to date guide. Think it was caused by updating Windows 10 to the latest Build 1511 version. 1
rikiwi 32 Posted November 16, 2015 Posted November 16, 2015 (edited) Please ignore this, as I had same problem after the Windows 10 update. Got it sorted. If this helps anyone else , create the folder - Temporary ASP.NET Files in this directory - C:\Windows\Microsoft.NET\Framework\v4.0.30319\ Thanks so much as I was missing my TV in Emby. Edited November 16, 2015 by rikiwi
