totalhavoc 13 Posted November 15, 2015 Posted November 15, 2015 I just installed the trailer plugin and turned on cinema mode but I can't seem to get it to work. Do I have to use the archive function in the trailer plugin for cinema mode to play trailers? I have tried to get cinema mode to work on the iOS app, kodi, and the web interface and all I get is the movie no trailers beforehand. I did make sure it is enable for my profile too. Thanks for any help.
ebr 16342 Posted November 15, 2015 Posted November 15, 2015 Do any trailers show up under the Trailers plug-in?
totalhavoc 13 Posted November 15, 2015 Author Posted November 15, 2015 In the web interface I see a trailers tab and I can play trailers. I also have a trailer button on most but not all movies in the web interface. I do not have a trailer tab in the iOS app but I do have a trailer button when going into a movie. I just can't seem to get the trailers to play when choosing a movie to play.
Luke 42252 Posted November 15, 2015 Posted November 15, 2015 You shouldn't have to enable the archive but I will test this and verify
totalhavoc 13 Posted November 16, 2015 Author Posted November 16, 2015 So it started working on my Kodi boxes. I checked just to see this morning and it was working. I will check when I get home tonight to see if it is working on iOS and web.
totalhavoc 13 Posted November 16, 2015 Author Posted November 16, 2015 It's odd that it just started working. I didn't do a thing, just waited. Is that normal?
ebr 16342 Posted November 16, 2015 Posted November 16, 2015 I have seen a couple of people say it takes a day or two to start working but I'm not sure what process needs to complete before it does.
totalhavoc 13 Posted November 16, 2015 Author Posted November 16, 2015 Thanks for the responses. It does seem to be working everywhere I use it except in the new iOS app. I get two playback failure messages and then the movie starts to play. I assume the failures are the two trailers.
mgworek 134 Posted November 18, 2015 Posted November 18, 2015 When trailers were not working, did you're movie every play? I have tried a few times to get trailers to work but whenever I enable Cinema Mode, i cant even get my movies to play on the web interface. I have the plugin and see trailers within the plugin but if I go start a movie, it spins and just stops. If I disable Cinema Mode, the movie starts playing right away. I will leave it turned on and wait a day or two and test again.
ebr 16342 Posted November 18, 2015 Posted November 18, 2015 When trailers were not working, did you're movie every play? I have tried a few times to get trailers to work but whenever I enable Cinema Mode, i cant even get my movies to play on the web interface. I have the plugin and see trailers within the plugin but if I go start a movie, it spins and just stops. If I disable Cinema Mode, the movie starts playing right away. I will leave it turned on and wait a day or two and test again. That actually sounds more like a playback issue with the trailers themselves.
mgworek 134 Posted November 18, 2015 Posted November 18, 2015 That actually sounds more like a playback issue with the trailers themselves. I never actually tried playing a trailer from the plugin. Just tried and nothing happened. Spun and just stopped. My server is in the middle of doing a scan so once it is done, I will try again and grab the logs. Would love to get this working. My wife always asks me what happened to the trailers when watching a movie.
mgworek 134 Posted November 18, 2015 Posted November 18, 2015 Here is my log. I just tried to play a trailer and it failed then I copied the log. Thanks
