geotux 4 Posted November 14, 2015 Posted November 14, 2015 Hi, i'm trying to get the playon plugin to work and noted in other threads that the IP should be set to 127.0.0.1 in the settings of the plugin. I've tried that but, from what can understand there is no response to port 54479 on localhost. Is that the port on which the playon plugin is listening? I've attached the log of the relevant sections. CHeers Antonio
Luke 42252 Posted November 14, 2015 Posted November 14, 2015 We'll need some help from the plugin author, @@snazy2000
bluemonkey07 590 Posted November 15, 2015 Posted November 15, 2015 So playon is running on the same device as your emby server right?
geotux 4 Posted November 15, 2015 Author Posted November 15, 2015 Yes, indeed. Both on the same server. Am I suppose to install some other server system for PlayOn? I thought all i needed to do was install the plugin.
Luke 42252 Posted November 15, 2015 Posted November 15, 2015 Yes, indeed. Both on the same server. Am I suppose to install some other server system for PlayOn? I thought all i needed to do was install the plugin. You still need the standalone playon software up and running and fully functional, if that's what you mean: https://www.playon.tv/ The emby playon plugin will then talk to the playon software.
geotux 4 Posted November 15, 2015 Author Posted November 15, 2015 Ah, I see. So PlayOn is a wrapper for some sort of other streaming server: Mmm, I don't like the idea of some closed source beast running on my server. Does this mean that I have no other way of having the BBC iplayer or Netflix streamed through Emby?
Luke 42252 Posted December 4, 2015 Posted December 4, 2015 Did you read post #6? He never understood what PlayOn was. Once he learned it required external software outside of Emby, he didn't want to continue with it.
