mike707070 0 Posted December 9, 2015 Posted December 9, 2015 Thanks for the workaround !!!! My household only streams to rokus, so this worked for me. I was in the process of "retraining" the wife and kids on plex, so I'm happy to be able stick with emby.
Hengist 0 Posted December 11, 2015 Posted December 11, 2015 After days of struggling with this (packet analysis, network restructuring, the works), I finally ran across @BigBri41's fix. Works like a charm! Let's hope Roku gets this fixed sooner rather than later!
Luke 42242 Posted December 11, 2015 Posted December 11, 2015 For those of you still having issues without his fix, assuming you're on the latest server release, can you give me examples of content where it is still happening? e.g. media info from the web client. thanks.
whitestrat13 33 Posted December 11, 2015 Posted December 11, 2015 (edited) @@Luke I had issues again tonight with this one. Media Info Video CodecH264 ProfileHigh Level41 Resolution1920x1080 Aspect ratio16:9 AnamorphicNo InterlacedNo Framerate23.97602 Bitrate27251 kbps Bit depth8 bit Pixel formatyuv420p Ref frames4 CABACYes Audio Languageeng CodecDCA ProfileDTS-HD MA Layout5.1 Channels6 ch Sample rate48000 khz DefaultYes Audio Languageeng CodecDCA ProfileDTS Layout5.1 Channels6 ch Bitrate1500 kbps Sample rate48000 khz DefaultNo Subtitle Languageeng CodecPGSSUB DefaultNo ForcedNo ExternalNo Containermkv I caved and implemented @@BigBri41 's work around and everything seems to be working now. Edited December 11, 2015 by whitestrat13
whitestrat13 33 Posted December 12, 2015 Posted December 12, 2015 2 hours and 23 minutes. Sent from my HTC6525LVW using Tapatalk
mjktg99 35 Posted December 12, 2015 Posted December 12, 2015 (edited) 2hrs, 10min. Transcodes because of audio. VideoCodecH264ProfileMainLevel40Resolution1280x592Aspect ratio13600:6179AnamorphicNoInterlacedNoFramerate23.97602Bitrate3304 kbpsBit depth8 bitPixel formatyuv420pRef frames4CABACYes AudioLanguageengCodecAC3Layout5.1Channels6 chBitrate218 kbpsSample rate48000 khzDefaultYesContainermkv Edited December 12, 2015 by mjktg99
whitman27 1 Posted December 12, 2015 Posted December 12, 2015 I am finding using the fix in this thread it works but I am seeing an issue with the audio on a lot of movies and shows. It has this broken up sound at times. I was a watching one show that had an audience and I figured it was just that one show but the more stuff I watch I am noticing it. Hope roku fixes this ASAP, I really don't want to switch to Plex . When I have supported this product for a long time Sent from my iPhone using Tapatalk
speechles 2062 Posted December 12, 2015 Posted December 12, 2015 @@whitman27 http://emby.media/community/index.php?/topic/28067-Audio-distorted-when-playing-1080p-MKV's#entry275261 Please check this post. This may solve the issue. Experiment time! Sent from my Nexus 7 using Tapatalk
Luke 42242 Posted December 12, 2015 Posted December 12, 2015 i am going to put the query string change into the next server patch release, which as you guys have probably noticed we've been doing on a weekly basis. that was the change i mentioned earlier that if roku ever fixes the problem, the change will have to be reverted. 1
Luke 42242 Posted December 12, 2015 Posted December 12, 2015 For those who run the server dev build, it's in 3.0.5824.28310
Zeev 0 Posted December 13, 2015 Posted December 13, 2015 Thank you BigBri41. Followed your exact instructions with version 3.0.5781.5 Problem seems to be solved! Thank you!
EricE 2 Posted December 14, 2015 Posted December 14, 2015 I cannot say if I have the same exact issue but mine has been crashing for at least a week (likely two).Here is a server log of a crash when I tried to play Eclipse. rokucrash.txt
Luke 42242 Posted December 14, 2015 Posted December 14, 2015 I cannot say if I have the same exact issue but mine has been crashing for at least a week (likely two). Here is a server log of a crash when I tried to play Eclipse. Can you discuss the crash a little bit?
EricE 2 Posted December 14, 2015 Posted December 14, 2015 Can you discuss the crash a little bit? Let me elaborate. I haven't read the whole thread and once I do I may be able to prove my crash is the same as everyone elses here. I posted the logs in case it helps but the more I read of this thread the more I think my problem is exactly the same. Again, I need to consume more to know for sure. Basically, the crash happens right on start of playback on files that used to work in the past. It does seem to be related to the file type though because I can sometime convert the file format to something else and get it to play.
Luke 42242 Posted December 14, 2015 Posted December 14, 2015 The fix for this is now in the windows beta server. 2
mjktg99 35 Posted December 15, 2015 Posted December 15, 2015 I can confirm the fix in the latest server release resolves this issue.
QwEmby 2 Posted December 15, 2015 Posted December 15, 2015 I was still having the problem with 3.0.5781.4. I updated to the latest beta/dev releases and still the same. I completelly uninstalled the server (removed cache files, etc.) just to make sure that there wasn't something looming from before and reinstalled with the same results. So... I downloaded the code branch and found the function that outputs the manifest file to the device (GetVariantPlaylistInternal(StreamRequest request, bool isOutputVideo, string name) in DynamicHlsService.cs inside of the MediaBrowser.Api project under the Playback/Hls directory) and modified it to not include the query strings which apparently is what is causing the rokus to crash (manifest file is getting too big or something?). I've tested it with several movies that weren't working before and it isn't crashing the roku anymore. Here's what I did: 1. I installed server version 3.0.5781.4 and set it all up. 2. In the advanced system preferences I disabled automatic updating of the server. 3. Find where the server is installed. (My server installation was in this directory C:\Users\[userName]\AppData\Roaming\Emby-Server\System) 4. Exit out of the server program 5. In your server installation directory, rename MediaBrowser.Api.dll to MediaBrowser.Api.dll.old and copy the MediaBrowser.Api.dll that is in the attached zip file to the directory. 6. Start the server and cross your fingers. The dll was compiled with version 3.0.5781.4 so i don't know if it will work with other release versions of the product. I hope this helps some folks out there. This is by no means a fix, just a bandaid at best (and it probably breaks something else). Once Roku gets thier fix out, re-enabling automatic updates should overwrite this file when a new version of the server comes out and everything will be as it should be (codewise). If this doesn't work for you, you can just delete the file you copied over and rename the .old file back to its original name to put things back the way they were. EDIT: just realized that while any of the emby proprietary clients are smart enough to include the proper query strings even if they aren't sent from the server, playing through a non emby client isn't and i broke that part. Added a condition that looks for ROKU in the user agent string and only performs this manipulation if it is a roku but leaves everything as it was if it isn't a roku. File updated. This worked for me, too. Thanks a million, @@BigBri41. I can finally watch all my epics again.
BigBri41 8 Posted December 16, 2015 Posted December 16, 2015 @@Luke Looks like they released an update for the rokus today. I downgraded from the beta server to the stable one 3.0.5781.5 (where the work around wasn't deployed) and it looks like they resolved it from their side. You can probably remove that query string condition now after you test rokus fix out. Would you like me to remove that file I uploaded to that post in this thread so we don't risk folks messing their installations up?
Luke 42242 Posted December 16, 2015 Posted December 16, 2015 Yes please, and thanks. Bigger question is does the .6 beta still function on the roku update?
BigBri41 8 Posted December 16, 2015 Posted December 16, 2015 @@Luke Seems to work well for me on the beta also. Just a note; I thought that I noticed some sound anomalies after the query string manipulation but didn’t really care since the movies would play. I’m not sure if this was some kind of mental placebo thing or whether it was real . If the roku does have to retrieve some sound settings based on the query string in the manifest file though, it might be worth looking into removing the bandaid for the next stable release. Just a thought.
y2kse 5 Posted December 18, 2015 Author Posted December 18, 2015 The latest Roku update has resolved my issues. 1
above1 45 Posted December 19, 2015 Posted December 19, 2015 The latest Roku update has resolved my issues. I can also confirm! ROKU 7.0.9044 firmware also addresses the issue. I can now play "The Departed" which is 2h31m without issues. aBoVe1
fantaxp7 191 Posted December 22, 2015 Posted December 22, 2015 Hello, Has this issue been resolved with a emby server update or is it all related to the roku firmware? I have a lot of friends with roku's who have reported crashing as well, I hope this is an easy fix. Thanks
