mjktg99 35 Posted November 13, 2015 Posted November 13, 2015 Why does a premier subscription require the device to be on same lan as the server? I pay for a subscription so it should just recognize that no matter where I am. 1
Luke 42244 Posted November 13, 2015 Posted November 13, 2015 It's only required once and then it will be remembered. Are you able to sign in once on the local lan?
mjktg99 35 Posted November 13, 2015 Author Posted November 13, 2015 It works. I'm just at work and installed the new ios app on my work iphone and it will probably never go home so the new app is pretty much useless unless I bring it home.
