piejanssens 3 Posted November 13, 2015 Posted November 13, 2015 Emby connect works on my desktop, in the new app however I can't get logged into my server. For host I enter 'https://emby.xxxxxx.synology.me' port 443. This works fine for my desktop or just browsing https://emby.xxxxx.synology.me.
piejanssens 3 Posted November 13, 2015 Author Posted November 13, 2015 I have a gut feeling that this is due to self signed certificates. Luke, can you please allow self signed certificates for your NSURLConnection (or third party HTTP library)?
Luke 42243 Posted November 13, 2015 Posted November 13, 2015 Yes it's related to self signed certs. We'll have to look into allowing them. 1
piejanssens 3 Posted March 16, 2016 Author Posted March 16, 2016 Yes it's related to self signed certs. We'll have to look into allowing them. What's the status? I paid 5€ for the app and still can't use it... Verzonden vanaf mijn iPhone met Tapatalk
Luke 42243 Posted March 16, 2016 Posted March 16, 2016 Right now you would need a trusted cert on the server and installed on the device. We are not going to continue pursuing workarounds with self-signed certs due to the work required by every single app to handle them. Instead our plan is to revamp the server ssl around LetsEncrypt. I think the end result is going to be great but I can't offer an ETA on it. Thanks.
piejanssens 3 Posted March 16, 2016 Author Posted March 16, 2016 Self signed certificates are very common among home server owners. I can't get a signed certificate because I'd need a wildcard domain certificate and that's just too expensive. From experience I know that supporting self signed certificates in iOS is as easy as copy pasting a few lines of code... Verzonden vanaf mijn iPhone met Tapatalk
horstepipe 423 Posted March 22, 2016 Posted March 22, 2016 hey here is a workaround which works good for me. - Create a letsencrypt certificate with the Synology assistant. - export it - you'll get 3 files (cert.pem, chain.pem, privkey.pem) - convert them to .pfx format with openssl pkcs12 -inkey privkey.pem -in cert.pem -certfile chain.pem -export -out mycert.pfx - import the .pfx certificate in Emby Regards
