Dizzy49 99 Posted November 13, 2015 Posted November 13, 2015 I finally got Kodi and Emby playing well together. I moved the box to the TV in my bedroom and it only plays videos in the upper left corner of the screen. You can see that Emby is using the entire screen as it still has the time in the upper right, and the menu along the bottom. I did a video calibration and everything appears fine. Ideas?
Angelblue05 4132 Posted November 13, 2015 Posted November 13, 2015 (edited) All of your content does that when you playback in Kodi? Whatever the answer, it is not an issue with our add-on but with Kodi itself. Maybe try to delete the guisettings.xml file: In your \kodi\userdata\guisettings.xml Edited November 13, 2015 by Angelblue05
SwanStream 64 Posted November 14, 2015 Posted November 14, 2015 I get this when there's a retiming issue with the HDMI signal. For me toggling fullscreen off/on fixes the layout problem w/Kodi.
