Ingleby 0 Posted November 12, 2015 Posted November 12, 2015 I just got a new Amazon Fire Stick - plugged into the TV (old samsung) audio going to the TV speakers. I'm trying to watch a DVD but I don't get the main voice channels. I do hear background music etc. The same DVD played with the Emby Web Client on my MacBook Pro sounds fine. This shows the transcoding (same for both Emby FireStick and MBP): Output #0, hls, to 'C:\Users\Media\AppData\Roaming\MediaBrowser-Server\transcoding-temp\a8604f4a13b4dea333900d745f3d14d1.m3u8': Metadata: encoder : Lavf57.2.100 Stream #0:0: Video: h264 (libx264), yuv420p, 720x480 [sAR 32:27 DAR 16:9], q=-1--1, 11571 kb/s, 29.97 fps, 90k tbn, 29.97 tbc Metadata: encoder : Lavc57.3.100 libx264 Stream #0:1: Audio: aac, 48000 Hz, 5.1, fltp, 320 kb/s Metadata: encoder : Lavc57.3.100 aac Stream mapping: Stream #0:1 -> #0:0 (mpeg2video (native) -> h264 (libx264)) Stream #0:4 -> #0:1 (ac3 (native) -> aac (native)) I tried setting the sound to Compatible on the FireStick but that made no difference. Should the FireStick be capable of playing an AC3 5.1 track / AAC? Where would the down-mix occur on the stick or on the TV? I plugged the fire stick into a new (2015 75" Samsung) and it had the same audio issue.
Ingleby 0 Posted November 12, 2015 Author Posted November 12, 2015 I tried using VLC on the FireStick and connected to the Emby server - played the same DVD as above and it sounded OK. I checked the transcoding and it was identical. So that makes it look like an issue with the Emby for Android TV not handling the audio correctly to me.
ebr 16336 Posted November 12, 2015 Posted November 12, 2015 The app is handling it correctly but your TV is not. The app is sending 5.1 audio and your TV is only letting you hear the L/R channels. You can easily solve this by going into settings in the app and forcing your audio into "Compatible" mode.
drueter 0 Posted December 15, 2015 Posted December 15, 2015 (edited) FWIW, I experience this same problem (dialog channel missing from AC3 5.1 audio) on the Kindle Fire TV Stick on some (but not all) titles. I found a work-around to the problem: If I experience the problem, from the Emby Fire TV app I can turn on Closed Captions. Then the audio dialog channel works as expected. I can then usually turn off Subtitles, and the dialog channel continues to work. In my case, my projector is providing me with analog audio out, which I have connected to a two-channel stereo amplifier. I hope this helps. Edited December 15, 2015 by drueter
