LongMan 116 Posted November 9, 2015 Posted November 9, 2015 The Directors node in the music video section of the library does not show any info. It worked previously. Tested with the last stable version 1.1.39 and it was still working. So somewhere between 1.1.39 and 1.1.53 it stopped working. I am not sure if a log is needed for this. Let me know. Cheers, Long Man
Angelblue05 4132 Posted November 9, 2015 Posted November 9, 2015 (edited) Can you explain what you mean by "any info"? Mine show directors in the directors node in music video so I'm wondering what you are talking specifically. Edit: I have tested both 1.1.39 and 1.1.55 and had the same outcome, directors show up in the directors node for music video. Edited November 9, 2015 by Angelblue05
LongMan 116 Posted November 9, 2015 Author Posted November 9, 2015 Ok. I will do a full re-sync and test it again. Cheers, Long Man
LongMan 116 Posted November 9, 2015 Author Posted November 9, 2015 Tested again and got the same results. Using two clients connecting to the same sever. To reproduce. In Confluence Videos>Library>Directors. In 1.1.39, it shows a list of directors which when one is selected, it shows the music videos of that director. In 1.1.54 it is an 'empty' list. (could have happened before 1.1.54 not sure at what point the regression to place), Cheers, Long Man
Angelblue05 4132 Posted November 9, 2015 Posted November 9, 2015 Ok so if I understand correctly, you are saying directors list is empty? How are your directors added in the metadata manager for your music videos? As I said previously, I do not have this issue so we'll need to find out why it's not working for you. Sent from my iPhone using Tapatalk
LongMan 116 Posted November 10, 2015 Author Posted November 10, 2015 (edited) All my music videos have an associated nfo. Some contain director information. <director>foo</director>. I am sure the data is in the Emby database. I can see it in the web client under People>Director. In addition, I tested with another client 1.1.39 and the information shows. But in 1.1.52 client it does not. Cheers Edit: The Server Version is 3.0.5781.1 Edited November 10, 2015 by LongMan 1
Angelblue05 4132 Posted November 10, 2015 Posted November 10, 2015 (edited) Ok, I think I somehow managed to reproduce that issue. I'm looking into it. Edit: Yes, totally a derp moment on my part. Edited November 10, 2015 by Angelblue05
Angelblue05 4132 Posted November 10, 2015 Posted November 10, 2015 @@LongMan It will be fixed in the next version.
LongMan 116 Posted November 10, 2015 Author Posted November 10, 2015 Thanks. Looking forward to it. Cheers
Angelblue05 4132 Posted November 10, 2015 Posted November 10, 2015 @@LongMan Please try the latest beta version 1.1.57 and let me know that it fixes your issue. Thanks for your patience
LongMan 116 Posted November 10, 2015 Author Posted November 10, 2015 Got the master and the directors list is working again. Thanks, Long Man 1
