maronek 0 Posted November 8, 2015 Posted November 8, 2015 Ok, I am feeling really dense here... How do you actually use emby in kodi? I have the add-on installed, the only way I can see any of my media is by going to the add-on section in kodi and clicking on Mediabrowser. Then I can browse and launch my media. Is this what is suppose to happen? I was under the impression that Mediabrowser would be a back end and kodi would work as it did before.. clicking on a category (Movies or TV) and browsing the data from there. Thanks in advance G
bluemonkey07 590 Posted November 8, 2015 Posted November 8, 2015 Sounds like you may have installed the old xbmb3c addon rather than the newer emby for kodi one
maronek 0 Posted November 8, 2015 Author Posted November 8, 2015 Sounds like you may have installed the old xbmb3c addon rather than the newer emby for kodi one omg, thank you so much. Cant believe it was that simple. I managed to install the old version - xbmb3c I uninstalled that in kodi downloaded the new plugin from github - emby.kodi entered my server settings and quit and relaunched kodi! PROFIT Thanks.
im85288 1493 Posted November 8, 2015 Posted November 8, 2015 downloaded the new plugin from github - emby.kodi Why from github? It's available in both our stable and beta repo's and would then get automatically updated.
bluemonkey07 590 Posted November 8, 2015 Posted November 8, 2015 omg, thank you so much. Cant believe it was that simple. I managed to install the old version - xbmb3c I uninstalled that in kodi downloaded the new plugin from github - emby.kodi entered my server settings and quit and relaunched kodi! PROFIT Thanks. yep you managed to make something simple seem difficult
