geotux 4 Posted November 8, 2015 Posted November 8, 2015 Hi, installed Emby last night as I want to replace Plex (don't like closed source). Quite impressed up to now although still haven't managed to see one film yet. Can't see film in web client or android client, both saying "There was an error playing the video.".Music plays correctly. Emby Version 3.0.5781.0 with ffmpeg version 0.8.17-6:0.8.17-1 (basically a fully updated Debian Wheezy to a few minutes ago) Now, this I think it's a transcode problem as I see "Unrecognized option 'codec:v:0'" in the transcode log (see below). One thing that I did like of Plex is the "Direct streaming" option which i think Emby doesn't have. It tries to transcode even videos that are not transcoded on Plex (I have Plex also running on the same machine). Am i correct in thinking that there is no direct streaming with Emby? ThanksAntonio TRANSCODE LOG (also attached) http://192.168.1.3:8096/emby/videos/6920af97c4418d11be79207c0722539b/stream.webm?DeviceId=434bb81cd4e118556dc1d12dd153978d13b005c7&MediaSourceId=6920af97c4418d11be79207c0722539b&VideoCodec=vpx&AudioCodec=vorbis&VideoBitrate=426538666&AudioBitrate=128000&MaxHeight=1080&ClientTime=635826086455268210&PlaySessionId=731ea850d5c84351bea90945b1f93770&api_key=f3f331d238e44921a1e2401c4216a9e1{"Protocol":"File","Id":"6920af97c4418d11be79207c0722539b","Path":"/exports/zeusmedia/Movies/Good Copy Bad Copy (2007)/Good Copy Bad Copy (2007).mp4","Type":"Default","Container":"mp4","Name":"","ReadAtNativeFramerate":false,"SupportsTranscoding":true,"SupportsDirectStream":true,"SupportsDirectPlay":true,"RequiresOpening":false,"RequiresClosing":false,"VideoType":"VideoFile","MediaStreams":[],"PlayableStreamFileNames":[],"Formats":[],"RequiredHttpHeaders":{}}/usr/bin/ffmpeg -loglevel debug -fflags +genpts -i file:"/exports/zeusmedia/Movies/Good Copy Bad Copy (2007)/Good Copy Bad Copy (2007).mp4" -sn -codec:v:0 libvpx -force_key_frames expr:gte(t,n_forced*5) -vf "scale=trunc(oh*a/2)*2:min(ih\,1080)" -pix_fmt yuv420p -speed 16 -quality good -profile:v 0 -slices 8 -crf 10 -qmin 0 -qmax 50 -maxrate:v 426538666 -bufsize:v (426538666*2) -b:v 426538666 -vsync vfr -map_metadata -1 -threads 2 -codec:a:0 libvorbis -ab 128000 -af "aresample=async=1" -y "/exports/zeusmedia/Transcode/transcoding-temp/cccb19f385a90c3a51960df3b51d1b23.webm"ffmpeg version 0.8.17-6:0.8.17-1, Copyright (c) 2000-2014 the Libav developers built on Mar 15 2015 17:31:12 with gcc 4.7.2 configuration: --arch=i386 --enable-pthreads --enable-runtime-cpudetect --extra-version='6:0.8.17-1' --libdir=/usr/lib/i386-linux-gnu --prefix=/usr --enable-bzlib --enable-libdc1394 --enable-libdirac --enable-libfreetype --enable-frei0r --enable-gnutls --enable-libgsm --enable-libmp3lame --enable-librtmp --enable-libopencv --enable-libopenjpeg --enable-libpulse --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-vaapi --enable-vdpau --enable-libvorbis --enable-libvpx --enable-zlib --enable-gpl --enable-postproc --enable-swscale --enable-libcdio --enable-x11grab --enable-libx264 --enable-libxvid --shlibdir=/usr/lib/i386-linux-gnu --enable-shared --disable-static avutil configuration: --arch=i386 --enable-pthreads --enable-runtime-cpudetect --extra-version='6:0.8.17-1' --libdir=/usr/lib/i386-linux-gnu --prefix=/usr --enable-bzlib --enable-libdc1394 --enable-libdirac --enable-libfreetype --enable-frei0r --enable-gnutls --enable-libgsm --enable-libmp3lame --enable-librtmp --enable-libopencv --enable-libopenjpeg --enable-libpulse --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-vaapi --enable-vdpau --enable-libvorbis --enable-libvpx --enable-zlib --enable-gpl --enable-postproc --enable-swscale --enable-libcdio --enable-x11grab --enable-libx264 --enable-libxvid --shlibdir=/usr/lib/i386-linux-gnu/i686/cmov --cpu=i686 --enable-shared --disable-static avcodec configuration: --arch=i386 --enable-pthreads --enable-runtime-cpudetect --extra-version='6:0.8.17-1' --libdir=/usr/lib/i386-linux-gnu --prefix=/usr --enable-bzlib --enable-libdc1394 --enable-libdirac --enable-libfreetype --enable-frei0r --enable-gnutls --enable-libgsm --enable-libmp3lame --enable-librtmp --enable-libopencv --enable-libopenjpeg --enable-libpulse --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-vaapi --enable-vdpau --enable-libvorbis --enable-libvpx --enable-zlib --enable-gpl --enable-postproc --enable-swscale --enable-libcdio --enable-x11grab --enable-libx264 --enable-libxvid --shlibdir=/usr/lib/i386-linux-gnu/i686/cmov --cpu=i686 --enable-shared --disable-static avformat configuration: --arch=i386 --enable-pthreads --enable-runtime-cpudetect --extra-version='6:0.8.17-1' --libdir=/usr/lib/i386-linux-gnu --prefix=/usr --enable-bzlib --enable-libdc1394 --enable-libdirac --enable-libfreetype --enable-frei0r --enable-gnutls --enable-libgsm --enable-libmp3lame --enable-librtmp --enable-libopencv --enable-libopenjpeg --enable-libpulse --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-vaapi --enable-vdpau --enable-libvorbis --enable-libvpx --enable-zlib --enable-gpl --enable-postproc --enable-swscale --enable-libcdio --enable-x11grab --enable-libx264 --enable-libxvid --shlibdir=/usr/lib/i386-linux-gnu/i686/cmov --cpu=i686 --enable-shared --disable-static avdevice configuration: --arch=i386 --enable-pthreads --enable-runtime-cpudetect --extra-version='6:0.8.17-1' --libdir=/usr/lib/i386-linux-gnu --prefix=/usr --enable-bzlib --enable-libdc1394 --enable-libdirac --enable-libfreetype --enable-frei0r --enable-gnutls --enable-libgsm --enable-libmp3lame --enable-librtmp --enable-libopencv --enable-libopenjpeg --enable-libpulse --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-vaapi --enable-vdpau --enable-libvorbis --enable-libvpx --enable-zlib --enable-gpl --enable-postproc --enable-swscale --enable-libcdio --enable-x11grab --enable-libx264 --enable-libxvid --shlibdir=/usr/lib/i386-linux-gnu/i686/cmov --cpu=i686 --enable-shared --disable-static avfilter configuration: --arch=i386 --enable-pthreads --enable-runtime-cpudetect --extra-version='6:0.8.17-1' --libdir=/usr/lib/i386-linux-gnu --prefix=/usr --enable-bzlib --enable-libdc1394 --enable-libdirac --enable-libfreetype --enable-frei0r --enable-gnutls --enable-libgsm --enable-libmp3lame --enable-librtmp --enable-libopencv --enable-libopenjpeg --enable-libpulse --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-vaapi --enable-vdpau --enable-libvorbis --enable-libvpx --enable-zlib --enable-gpl --enable-postproc --enable-swscale --enable-libcdio --enable-x11grab --enable-libx264 --enable-libxvid --shlibdir=/usr/lib/i386-linux-gnu/i686/cmov --cpu=i686 --enable-shared --disable-static swscale configuration: --arch=i386 --enable-pthreads --enable-runtime-cpudetect --extra-version='6:0.8.17-1' --libdir=/usr/lib/i386-linux-gnu --prefix=/usr --enable-bzlib --enable-libdc1394 --enable-libdirac --enable-libfreetype --enable-frei0r --enable-gnutls --enable-libgsm --enable-libmp3lame --enable-librtmp --enable-libopencv --enable-libopenjpeg --enable-libpulse --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-vaapi --enable-vdpau --enable-libvorbis --enable-libvpx --enable-zlib --enable-gpl --enable-postproc --enable-swscale --enable-libcdio --enable-x11grab --enable-libx264 --enable-libxvid --shlibdir=/usr/lib/i386-linux-gnu/i686/cmov --cpu=i686 --enable-shared --disable-static postproc configuration: --arch=i386 --enable-pthreads --enable-runtime-cpudetect --extra-version='6:0.8.17-1' --libdir=/usr/lib/i386-linux-gnu --prefix=/usr --enable-bzlib --enable-libdc1394 --enable-libdirac --enable-libfreetype --enable-frei0r --enable-gnutls --enable-libgsm --enable-libmp3lame --enable-librtmp --enable-libopencv --enable-libopenjpeg --enable-libpulse --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-vaapi --enable-vdpau --enable-libvorbis --enable-libvpx --enable-zlib --enable-gpl --enable-postproc --enable-swscale --enable-libcdio --enable-x11grab --enable-libx264 --enable-libxvid --shlibdir=/usr/lib/i386-linux-gnu/i686/cmov --cpu=i686 --enable-shared --disable-static libavutil 51. 22. 3 / 51. 22. 3 libavcodec 53. 35. 0 / 53. 35. 0 libavformat 53. 21. 1 / 53. 21. 1 libavdevice 53. 2. 0 / 53. 2. 0 libavfilter 2. 15. 0 / 2. 15. 0 libswscale 2. 1. 0 / 2. 1. 0 libpostproc 52. 0. 0 / 52. 0. 0The ffmpeg program is only provided for script compatibility and will be removedin a future release. It has been deprecated in the Libav project to allow forincompatible command line syntax improvements in its replacement called avconv(see Changelog for details). Please use avconv instead.[mov,mp4,m4a,3gp,3g2,mj2 @ 0x81008e0] Probed with size=2048 and score=100[mov,mp4,m4a,3gp,3g2,mj2 @ 0x81008e0] ISO: File Type Major Brand: mp42[h264 @ 0x81030c0] err{or,}_recognition separate: 1; 1[h264 @ 0x81030c0] err{or,}_recognition combined: 1; 1[h264 @ 0x81030c0] Unsupported bit depth: 0[aac @ 0x8105240] err{or,}_recognition separate: 1; 1[aac @ 0x8105240] err{or,}_recognition combined: 1; 1[aac @ 0x8105240] Unsupported bit depth: 0[mov,mp4,m4a,3gp,3g2,mj2 @ 0x81008e0] All info foundInput #0, mov,mp4,m4a,3gp,3g2,mj2, from 'file:/exports/zeusmedia/Movies/Good Copy Bad Copy (2007)/Good Copy Bad Copy (2007).mp4': Metadata: major_brand : mp42 minor_version : 0 compatible_brands: isommp42 creation_time : 2014-02-07 03:47:34 Duration: 00:58:35.36, start: 0.000000, bitrate: 559 kb/s Stream #0.0(und), 13, 1/50: Video: h264 (Constrained Baseline), yuv420p, 640x356 [PAR 801:800 DAR 9:5], 1/50, 461 kb/s, 25 fps, 25 tbr, 50 tbn, 50 tbc Stream #0.1(und), 1, 1/44100: Audio: aac, 44100 Hz, stereo, s16, 96 kb/s Metadata: creation_time : 2014-02-07 03:48:00Unrecognized option 'codec:v:0'Failed to set value 'libvpx' for option 'codec:v:0' TranscodeLog.txt ServerLog.txt
Luke 42240 Posted November 8, 2015 Posted November 8, 2015 Hi, welcome. Your installed version of ffmpeg is really old and is missing a number of libraries that we need 2015-11-08 19:03:24.0516 Warn - App: ffmpeg is missing encoder libx264 2015-11-08 19:03:24.0516 Warn - App: ffmpeg is missing encoder mpeg4 2015-11-08 19:03:24.0516 Warn - App: ffmpeg is missing encoder msmpeg4 2015-11-08 19:03:24.0516 Warn - App: ffmpeg is missing encoder libvpx 2015-11-08 19:03:24.0516 Warn - App: ffmpeg is missing encoder aac 2015-11-08 19:03:24.0516 Warn - App: ffmpeg is missing encoder ac3 2015-11-08 19:03:24.0516 Warn - App: ffmpeg is missing encoder libmp3lame 2015-11-08 19:03:24.0516 Warn - App: ffmpeg is missing encoder libvorbis 2015-11-08 19:03:24.0516 Warn - App: ffmpeg is missing encoder srt
