Hi, whenever I start Media Browser on 3840×2160 resolution I get this weird flickering on the right side. Sometimes it starts when browsing folders or while watching a video, the only cure for this is resizing the MCE window when playing new content. I tried it on a 4k TV with HDMI 1.4 @ 30Hz and on a 4k Monitor with DP 1.2 @ 60Hz and I got the same results. This only happens when MCE is set to UHD res, 1080p works fine. I filmed it to better illustrate the problem:
I get "This video is private."
But, it sounds similar to an issue I have with WMC on my 2560x1440 screen - it's an MCE issue and nothing to do with Emby. You can get around it by using an external player (I use MPC-HC).
Sorry, accidentally set it to private, should work now.
I just tried this on mine and it helped - in EMC go into the config menu and scroll all the way to the right to "Advanced" and try adjusting the setting for "right" in the Over/Underscan section to -1.
  • Like 2
  • 1 month later...
Didn't help. The problem is with media center itself.
