Guest petwri Posted November 5, 2015 Posted November 5, 2015 I am using Emby for Kodi 1.1.53, and in my music library, when I sort music albums after "Tracks", multidisc albums don't get split up into their individual albums. The titles are ordered like 01 - foo 01 - foobar 02 - foofoo 02 - foofoobar ... This same thing worked without problems when scanning the same audiofiles directly to kodi. Music is properly tagged, either MP3 or FLAC, with the disc tag set.
Angelblue05 4132 Posted November 5, 2015 Posted November 5, 2015 (edited) Bug confirmed. Hopefully it's something we can fix. Trello card: https://trello.com/c/yzDDbuee/178-music-multi-disc-track-number-not-followed Edited November 5, 2015 by Angelblue05
Angelblue05 4132 Posted November 8, 2015 Posted November 8, 2015 (edited) You issue is resolved in beta version 1.1.55. You will need to reset your kodi database for it to take effect. @@petwri Let me know that it works correctly for you, thanks. Edited November 10, 2015 by Angelblue05
Guest petwri Posted November 12, 2015 Posted November 12, 2015 Working now! Thanks @@Angelblue05 , you're AWESOME! 1
