Ian-Highlander 147 Posted January 5, 2016 Posted January 5, 2016 To get those icons working you need to add folders in the metadata/general folder for them.
fraenhawk 61 Posted January 5, 2016 Posted January 5, 2016 Okay, that's what I was thinking as well. Should one of the releases not added those folders with generic icons already??
ebr 16333 Posted January 5, 2016 Posted January 5, 2016 Should one of the releases not added those folders with generic icons already?? No, because they are server-side and this is a manual customization that is only used by this one app.
fraenhawk 61 Posted January 5, 2016 Posted January 5, 2016 No, because they are server-side and this is a manual customization that is only used by this one app. Gotcha, thanks!
lja 51 Posted February 7, 2016 Author Posted February 7, 2016 To get those icons working you need to add folders in the metadata/general folder for them. @@Ian-Highlander Where is the metadata/general folder located?
Ian-Highlander 147 Posted February 7, 2016 Posted February 7, 2016 (edited) @@Ian-Highlander Where is the metadata/general folder located? You have to create a folder called general in the root of your main server metadata folder, it's not there by default. Edited February 7, 2016 by Ian-Highlander
