SHSPVR 125 Posted November 3, 2015 Posted November 3, 2015 I still get that problem under IE but under Chrome it start but dosen't play rigth with anything with ac3 audio the video be coming really jecky where in IE just give me video error but both dose play reg aac audio just fine and iPad is all but useless with a Spininng Loading screen as it to has no problem playing reg aac audio just fine but not anything with ac3 audio. No problem with Emby Theater nor Windows 10 Emby App as far I can tell Must all file MP4 with AC3 2.0 or 5.1 with handful AAC and few AVI, Divx and Xvid which also AC3 2.0 or 5.1. logs.zip
SHSPVR 125 Posted November 10, 2015 Author Posted November 10, 2015 (edited) Hmm 3.0.5781.1 but still dose not work with IE nor Chrome Edited November 17, 2015 by SHSPVR
SHSPVR 125 Posted November 17, 2015 Author Posted November 17, 2015 Hmm 3.0.5781.2 but still dose not work with IE nor Chrome
SHSPVR 125 Posted November 25, 2015 Author Posted November 25, 2015 3.0.5781.3 still dose not work with IE11 with getting this message (Video Error: There was an error playing the video) under Windows 7 will this be getting fix ?. The good news I happy to report Chrome is working so that good.
Luke 42185 Posted November 25, 2015 Posted November 25, 2015 Video playback on IE for Windows 7 is not an easy thing to accomplish. Yes - IE11 under windows 8/10 has additional features that the Windows 7 version does not. Of course we will keep trying to improve it, but on older operating systems Chrome is recommended.
SHSPVR 125 Posted November 25, 2015 Author Posted November 25, 2015 Luke, on 25 Nov 2015 - 10:40 AM, said:Video playback on IE for Windows 7 is not an easy thing to accomplish. Yes - IE11 under windows 8/10 has additional features that the Windows 7 version does not. Of course we will keep trying to improve it, but on older operating systems Chrome is recommended. Thanks Luke but I perf used IE I don't even like MS new Edge software Ekk!!
Luke 42185 Posted November 25, 2015 Posted November 25, 2015 If you really want to stick with IE then I would at least consider upgrading to windows 8.1 or 10, because the browser has support for newer techniques and will be faster and more stable. We are getting to the point where the web interface is being held back due to these old browsers. It's possible next year we may end up in a scenario where the basic ability to setup the server and manage your library is supported in older browsers, but perhaps other things won't be if it helps the application move forward.
