Iorifly 15 Posted April 3, 2016 Posted April 3, 2016 managed to solve with this line ... However I am afraid to not be able to write to the share, because I'm using a User "guest" Do I have to replace the User root? \\10.1.0.1\Disk_0_0\Seriados /mnt/Seriados cifs auto,guest,uid=1000,iocharset=utf8 0 0
Iorifly 15 Posted April 3, 2016 Posted April 3, 2016 (edited) Still is not riding to start .... I need to give the command: sudo mount -a _-------------------------------------------------------------------------------- That's personal, I need you to drive mount without the need for command sudo mount -a Anyone know why this not riding .... ONLY AFTER THE COMMAND .... Edited April 3, 2016 by Iorifly
Iorifly 15 Posted April 3, 2016 Posted April 3, 2016 (edited) Friends, another problem, not being saved files in the folders of the movie ... fanart, poster ... Edited April 3, 2016 by Iorifly
jds828 24 Posted April 3, 2016 Posted April 3, 2016 (edited) Is there a client for Pi? I was looking at the Pi 3 but it seems a bit overkill to have it as a server. Maybe something like OpenELEC or OSMC with ET as the main media player. Could that be an option in time? Edited April 3, 2016 by jds828
Iorifly 15 Posted April 3, 2016 Posted April 3, 2016 Note: When you access the folder by WinSCP, logged in as User "pi", I can write and delete files in the share .... I need to figure out how to allow Emby save the metadata in the folder. The option of salver metadata in the media folder is already enabled. My Emby keeps crashing and I am to shut down the raspberry to all back.
Iorifly 15 Posted April 3, 2016 Posted April 3, 2016 (edited) I will list my problems: 1 - Emby locking and closing (After a few hours in use) 2 - I can not save the fanart, poster in the movie folder 3 - Whenever the raspberry starts, required the command "sudo mount -a" to mount the units. Please I need help! Impossible to use Emby this way. ---------------- I tried putting this option in the Share line: file_mode=0777,dir_mode=0777 thus it is: \\10.1.0.31\Public\WWW\TR-Downloads\Filmes /mnt/FilmesHD3tb/ cifs auto,guest,uid=1000,iocharset=utf8,file_mode=0777,dir_mode=0777 0 0 -------------------------------------------------------------------------------- Good news!!! It seems that the addition of the line solved my fanart writing problem and poster ... Edited April 4, 2016 by Iorifly
djonnie 14 Posted April 4, 2016 Posted April 4, 2016 Also trying to view some video files on my PC through browser and it wont play avi or mkv files? Is there anything I can do other than change the file types? Webbrowsers can only play MP4 with H264 video and AAC stereo audio you need to convert your files or use a client (like MB Theater) and setup (SMB) sharing
Iorifly 15 Posted April 4, 2016 Posted April 4, 2016 (edited) I'll post my log. I'm still with Emby closing problem .... http://pastebin.com/uBLz2cta Edited April 4, 2016 by Iorifly
Iorifly 15 Posted April 5, 2016 Posted April 5, 2016 Friend, unfeasible use Emby ..... it crashes after some time running! Can someone help me ? Analyzing the logs with me ....
Luke 42245 Posted April 5, 2016 Author Posted April 5, 2016 that particular log above looks fine to me,
Iorifly 15 Posted April 5, 2016 Posted April 5, 2016 (edited) Information that may be important. While I'm using Emby, it does not lock ... Only when I close the browser and I'm not moving .... I will generate more logs, clean and post here. Thanks Luke! note.: If I get 10 hours stirring in Emby it is ok ..... Just 10 hours I forget Emby, go to sleep or spend hours without moving to a crash Dismissed the raspberry option go to sleep .... It should not be this .... even because the SSH opens normally ... Edited April 5, 2016 by Iorifly
Iorifly 15 Posted April 6, 2016 Posted April 6, 2016 (edited) Luke, What was done well? -------------------------------------------------------------------- The following new log. However I confess I found nothing wrong in this log as well. However the Emby closes when I sleep .... http://pastebin.com/nsLxmvy9 Edited April 7, 2016 by Iorifly
ChunkyKev 0 Posted April 8, 2016 Posted April 8, 2016 Hi Guys, my install keeps stopping. Raspberry Pi is still running and seems fine, but Emby is just constantly stopping and I need to restart it. Any ideas what might be wrong?
Luke 42245 Posted April 8, 2016 Author Posted April 8, 2016 Hi Guys, my install keeps stopping. Raspberry Pi is still running and seems fine, but Emby is just constantly stopping and I need to restart it. Any ideas what might be wrong? If you're running any plugins, the first thing to try is removing them and seeing if the issue persists with the core server. Barring that, please see how to report a problem so that we can best help you. Thanks.
Iorifly 15 Posted April 8, 2016 Posted April 8, 2016 (edited) @@ChunkyKev, I have the same problem here. My Emby overnight is closed. During the day usually works ...... When I go to sleep and wake up he is no longer working, there need to start it again. I'm turning off some scheduled tasks to see if I can find what is causing the problem. Detail, all my logs look good! Edited April 8, 2016 by Iorifly
Iorifly 15 Posted April 9, 2016 Posted April 9, 2016 (edited) Follows a new log. I think this shows an error. http://pastebin.com/DQpLSF9t Once locked same error msg at the end. see: http://pastebin.com/ic9czu02 The great mystery is that Emby closed only at night! During the day it works normally. Edited April 9, 2016 by Iorifly
Iorifly 15 Posted April 10, 2016 Posted April 10, 2016 (edited) I disabled some "scheduled tasks" unnecessary for me, and I am currently 48 hours without Emby end. Edited April 10, 2016 by Iorifly
Iorifly 15 Posted April 10, 2016 Posted April 10, 2016 (edited) Check for application updates (*) Refresh Channels Chapter image extraction Clean Database (*) Download missing subtitles Convert media * these are the tasks that I think have great potential break Emby I'll stay a week with him working and analyze ... After calling back one by one to determine if it really is an activity that breaks it. @@ChunkyKev, Take this test to see if it helps. Edited April 10, 2016 by Iorifly
Iorifly 15 Posted April 11, 2016 Posted April 11, 2016 My 100% Emby, to try to remove something from my library ... I had a crash when trying to remove an empty collection. Soon I think that catches my Emby is this option: Clean Database (*) but I will do more test
ChunkyKev 0 Posted April 12, 2016 Posted April 12, 2016 It has crashed so often I have lost track. It was doing it at times within minutes of being started, sometimes a while after. It happened so often, when not doing anything I think there must be something else to it. I started a new thread to see if I get any answers, along with server log. http://emby.media/community/index.php?/topic/33683-service-keeps-stopping/
Iorifly 15 Posted April 14, 2016 Posted April 14, 2016 (edited) 2016-04-13 21:43:21.3200 Debug LibraryMonitor: Ignoring change to /mnt/FilmesHD4tb/Filmes/Harry Potter Order of the Phoenix/Harry.Potter.Order.of.the.Phoenix.2007.1080p.BluRay.H264.AAC-RARBG.nfo 2016-04-13 21:43:21.3241 Debug LibraryMonitor: Changed detected of type Changed to /mnt/FilmesHD4tb/Filmes/Harry Potter Order of the Phoenix/Harry.Potter.Order.of.the.Phoenix.2007.1080p.BluRay.H264.AAC-RARBG.nfo 2016-04-13 21:43:21.3259 Debug LibraryMonitor: Ignoring change to /mnt/FilmesHD4tb/Filmes/Harry Potter Order of the Phoenix/Harry.Potter.Order.of.the.Phoenix.2007.1080p.BluRay.H264.AAC-RARBG.nfo 2016-04-13 21:43:21.3284 Debug ProviderManager: Saving /mnt/FilmesHD4tb/Filmes/Harry Potter e as Reliquias Da Morte Parte 1/Harry Potter e as Reliquias Da Morte Parte 1.mp4 to Nfo. 2016-04-13 21:43:21.3939 Info HttpServer: HTTP Response 200 to 10.1.0.3. Time: 1381ms (slow). http://10.1.0.37:8096/emby/Items/423698b16c26b0ebc3378f92fa58e0c2/Images/Primary?MaxWidth=400&MaxHeight=400&Index=0&Tag=a2dff43260996be50230fa0a95c6476a 2016-04-13 21:43:21.4034 Info HttpServer: HTTP HEAD http://10.1.0.37:8096/emby/Items/423698b16c26b0ebc3378f92fa58e0c2/Images/Primary?MaxWidth=400&MaxHeight=400&Index=0&Tag=a2dff43260996be50230fa0a95c6476a. UserAgent: Kodi/15.0-ISENGARD (Windows NT 10.0; WOW64) App_Bitness/32 Version/15.0-ISENGARD-Git:kodibrasil.net 2016-04-13 21:43:21.4307 Info HttpServer: HTTP Response 200 to 10.1.0.3. Time: 30ms. http://10.1.0.37:8096/emby/Items/423698b16c26b0ebc3378f92fa58e0c2/Images/Primary?MaxWidth=400&MaxHeight=400&Index=0&Tag=a2dff43260996be50230fa0a95c6476a 2016-04-13 21:43:21.4393 Info HttpServer: HTTP HEAD http://10.1.0.37:8096/emby/Items/423698b16c26b0ebc3378f92fa58e0c2/Images/Primary?MaxWidth=400&MaxHeight=400&Index=0&Tag=a2dff43260996be50230fa0a95c6476a. UserAgent: Kodi/15.0-ISENGARD (Windows NT 10.0; WOW64) App_Bitness/32 Version/15.0-ISENGARD-Git:kodibrasil.net 2016-04-13 21:43:21.4646 Info HttpServer: HTTP Response 200 to 10.1.0.3. Time: 28ms. http://10.1.0.37:8096/emby/Items/423698b16c26b0ebc3378f92fa58e0c2/Images/Primary?MaxWidth=400&MaxHeight=400&Index=0&Tag=a2dff43260996be50230fa0a95c6476a 2016-04-13 21:43:21.4742 Info HttpServer: HTTP GET http://10.1.0.37:8096/emby/Items/423698b16c26b0ebc3378f92fa58e0c2/Images/Primary?MaxWidth=400&MaxHeight=400&Index=0&Tag=a2dff43260996be50230fa0a95c6476a. UserAgent: Kodi/15.0-ISENGARD (Windows NT 10.0; WOW64) App_Bitness/32 Version/15.0-ISENGARD-Git:kodibrasil.net 2016-04-13 21:43:21.5051 Info HttpServer: HTTP Response 206 to 10.1.0.3. Time: 33ms. http://10.1.0.37:8096/emby/Items/423698b16c26b0ebc3378f92fa58e0c2/Images/Primary?MaxWidth=400&MaxHeight=400&Index=0&Tag=a2dff43260996be50230fa0a95c6476a 2016-04-13 21:43:21.8674 Info HttpServer: HTTP HEAD http://10.1.0.37:8096/emby/Items/3ae220a9a6658ccffea319bb61e12787/Images/Primary?MaxWidth=400&MaxHeight=400&Index=0&Tag=e61f93be540366e090e5fbec4a921fcd. UserAgent: Kodi/15.0-ISENGARD (Windows NT 10.0; WOW64) App_Bitness/32 Version/15.0-ISENGARD-Git:kodibrasil.net 2016-04-13 21:43:21.8815 Debug App: ConvertImageToLocal item 3ae220a9-a665-8ccf-fea3-19bb61e12787 - image url: http://image.tmdb.org/t/p/original/kp8EIlf3VH0SO3log1mX9RQk0RD.jpg 2016-04-13 21:43:21.8831 Info HttpClient: HttpClientManager GET: http://image.tmdb.org/t/p/original/kp8EIlf3VH0SO3log1mX9RQk0RD.jpg 2016-04-13 21:43:21.9596 Info HttpServer: HTTP HEAD http://10.1.0.37:8096/emby/Items/2b7266c2461a78ad34403cb8daed3011/Images/Primary?MaxWidth=400&MaxHeight=400&Index=0&Tag=c7ddda75c5fbe9e23476eefdb489621e. UserAgent: Kodi/15.0-ISENGARD (Windows NT 10.0; WOW64) App_Bitness/32 Version/15.0-ISENGARD-Git:kodibrasil.net 2016-04-13 21:43:21.9673 Debug ProviderManager: Saving /mnt/FilmesHD4tb/Filmes/Harry Potter e as Reliquias Da Morte Parte 2/Harry Potter e as Reliquias Da Morte Parte 2.mp4 to Nfo. 2016-04-13 21:43:21.9778 Debug App: ConvertImageToLocal item 2b7266c2-461a-78ad-3440-3cb8daed3011 - image url: http://image.tmdb.org/t/p/original/wMlcjLBQouQjE0iceseNTxUF3BF.jpg 2016-04-13 21:43:21.9893 Error Main: UnhandledException *** Error Report *** Version: 3.0.5911.0 Command line: /usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe -programdata /var/lib/emby-server -ffmpeg /usr/local/bin/ffmpeg -ffprobe /usr/local/bin/ffprobe -restartpath /usr/lib/emby-server/restart.sh Operating system: Unix 4.1.19.7 Processor count: 4 64-Bit OS: False 64-Bit Process: False Program data path: /var/lib/emby-server Mono: 4.2.1 (Stable 4.2.1.102/6dd2d0d Thu Dec 3 05:10:20 UTC 2015) Application Path: /usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe Object reference not set to an instance of an object System.NullReferenceException at System.IO.InotifyWatcher.ProcessEvents (System.Byte[] buffer, Int32 length) <0x723f0000 + 0x00244> in <filename unknown>:0 at System.IO.InotifyWatcher.Monitor () <0x7009cd38 + 0x00097> in <filename unknown>:0 at System.Threading.ThreadHelper.ThreadStart_Context (System.Object state) <0x7542b160 + 0x000c7> in <filename unknown>:0 at System.Threading.ExecutionContext.RunInternal (System.Threading.ExecutionContext executionContext, System.Threading.ContextCallback callback, System.Object state, Boolean preserveSyncCtx) <0x7542981c + 0x001af> in <filename unknown>:0 at System.Threading.ExecutionContext.Run (System.Threading.ExecutionContext executionContext, System.Threading.ContextCallback callback, System.Object state, Boolean preserveSyncCtx) <0x754297e8 + 0x0002b> in <filename unknown>:0 at System.Threading.ExecutionContext.Run (System.Threading.ExecutionContext executionContext, System.Threading.ContextCallback callback, System.Object state) <0x75429744 + 0x0005b> in <filename unknown>:0 at System.Threading.ThreadHelper.ThreadStart () <0x7542b330 + 0x00037> in <filename unknown>:0 My Emby closed, I see an error ..... I believe it is in the image conversion. --------------------------------------------------------------------------------------------------------- I realized that my Emby crashes when have performed the following action: ***Refresh people*** Edited April 14, 2016 by Iorifly
Raspi2 Server 0 Posted April 14, 2016 Posted April 14, 2016 Webbrowsers can only play MP4 with H264 video and AAC stereo audio you need to convert your files or use a client (like MB Theater) and setup (SMB) sharing @@djonnie I too have this problem. At least I think I do. I've tried playing various formats of videos through the web interface of Emby and I get the following error whenever playing anything other than .webm or .mp4 files: "Video Error There was an error playing the video" I think what's happening is that the codec to transcode .mkv or .avi files for the web interface to play is missing. Here the relevant errors from my log files: 2016-04-13 18:22:29.0959 Warn App: ffmpeg is missing decoder h264_qsv 2016-04-13 18:22:29.2146 Warn App: ffmpeg is missing decoder mpeg2_qsv 2016-04-13 18:22:29.2842 Info SqliteProviderInfoRepository: Sqlite 3.8.7.1 opening /var/lib/emby-server/data/refreshinfo.db 2016-04-13 18:22:29.3341 Warn App: ffmpeg is missing decoder vc1_qsv 2016-04-13 18:22:29.4794 Warn App: ffmpeg is missing encoder libx265 2016-04-13 18:22:29.5386 Info SqliteUserDataRepository: Sqlite 3.8.7.1 opening /var/lib/emby-server/data/userdata_v2.db 2016-04-13 18:22:29.6139 Warn App: ffmpeg is missing encoder libmp3lame 2016-04-13 18:24:19.1618 Error DtoUtils: ServiceBase<TRequest>::Service Exception *** Error Report *** Version: 3.0.5912.0 Command line: /usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe -programdata /var/lib/emby-server -ffmpeg /usr/local/bin/ffmpeg -ffprobe /usr/local/bin/ffprobe -restartpath /usr/lib/emby-server/restart.sh Operating system: Unix 4.1.19.7 Processor count: 4 64-Bit OS: False 64-Bit Process: False Program data path: /var/lib/emby-server Mono: 4.2.1 (Stable 4.2.1.102/6dd2d0d Thu Dec 3 05:10:20 UTC 2015) Application Path: /usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe Access to the path "/mnt/emby_disk/transcoding-temp" is denied. System.UnauthorizedAccessException at System.IO.Directory.CreateDirectoriesInternal (System.String path) <0x7563fa68 + 0x00134> in <filename unknown>:0 at System.IO.Directory.CreateDirectory (System.String path) <0x7563f89c + 0x000c7> in <filename unknown>:0 at CommonIO.ManagedFileSystem.CreateDirectory (System.String path) <0x73104618 + 0x00017> in <filename unknown>:0 at MediaBrowser.Api.Playback.BaseStreamingService+<StartFfMpeg>c__async1.MoveNext () <0x67cb0918 + 0x00197> in <filename unknown>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () <0x754bc6a8 + 0x00024> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) <0x754ba2dc + 0x000ab> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) <0x754ba264 + 0x0006f> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) <0x754ba21c + 0x0003f> in <filename unknown>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () <0x754ba8e0 + 0x0001b> in <filename unknown>:0 at MediaBrowser.Api.Playback.Progressive.BaseProgressiveStreamingService+<GetStreamResult>c__async1.MoveNext () <0x67caed00 + 0x007cb> in <filename unknown>:0 2016-04-13 18:24:19.1618 Error DtoUtils: ServiceBase<TRequest>::Service Exception *** Error Report *** Version: 3.0.5912.0 Command line: /usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe -programdata /var/lib/emby-server -ffmpeg /usr/local/bin/ffmpeg -ffprobe /usr/local/bin/ffprobe -restartpath /usr/lib/emby-server/restart.sh Operating system: Unix 4.1.19.7 Processor count: 4 64-Bit OS: False 64-Bit Process: False Program data path: /var/lib/emby-server Mono: 4.2.1 (Stable 4.2.1.102/6dd2d0d Thu Dec 3 05:10:20 UTC 2015) Application Path: /usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe Access to the path "/mnt/emby_disk/transcoding-temp" is denied. System.UnauthorizedAccessException at System.IO.Directory.CreateDirectoriesInternal (System.String path) <0x7563fa68 + 0x00134> in <filename unknown>:0 at System.IO.Directory.CreateDirectory (System.String path) <0x7563f89c + 0x000c7> in <filename unknown>:0 at CommonIO.ManagedFileSystem.CreateDirectory (System.String path) <0x73104618 + 0x00017> in <filename unknown>:0 at MediaBrowser.Api.Playback.BaseStreamingService+<StartFfMpeg>c__async1.MoveNext () <0x67cb0918 + 0x00197> in <filename unknown>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () <0x754bc6a8 + 0x00024> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) <0x754ba2dc + 0x000ab> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) <0x754ba264 + 0x0006f> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) <0x754ba21c + 0x0003f> in <filename unknown>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () <0x754ba8e0 + 0x0001b> in <filename unknown>:0 at MediaBrowser.Api.Playback.Progressive.BaseProgressiveStreamingService+<GetStreamResult>c__async1.MoveNext () <0x67caed00 + 0x007cb> in <filename unknown>:0 2016-04-13 18:24:19.2111 Error HttpServer: Error processing request for /emby/videos/4d3bc4d2641c7d5dcdead14e3e2b68a5/stream.webm?DeviceId=d278d5650393773d95c6e7f54186e1677b06e88e&MediaSourceId=4d3bc4d2641c7d5dcdead14e3e2b68a5&VideoCodec=vpx&AudioCodec=vorbis&AudioStreamIndex=1&VideoBitrate=64682126&AudioBitrate=128000&MaxAudioChannels=6&PlaySessionId=6c90c8a9deb34ed095dd4fa49eface56&api_key=42ce73dfd00846bbb9c5a6a41621f300&CopyTimestamps=false&EnableAutoStreamCopy=false *** Error Report *** Version: 3.0.5912.0 Command line: /usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe -programdata /var/lib/emby-server -ffmpeg /usr/local/bin/ffmpeg -ffprobe /usr/local/bin/ffprobe -restartpath /usr/lib/emby-server/restart.sh Operating system: Unix 4.1.19.7 Processor count: 4 64-Bit OS: False 64-Bit Process: False Program data path: /var/lib/emby-server Mono: 4.2.1 (Stable 4.2.1.102/6dd2d0d Thu Dec 3 05:10:20 UTC 2015) Application Path: /usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe Access to the path "/mnt/emby_disk/transcoding-temp" is denied. ServiceStack.HttpError No Stack Trace Available 2016-04-13 18:24:19.2111 Error HttpServer: Error processing request for /emby/videos/4d3bc4d2641c7d5dcdead14e3e2b68a5/stream.webm?DeviceId=d278d5650393773d95c6e7f54186e1677b06e88e&MediaSourceId=4d3bc4d2641c7d5dcdead14e3e2b68a5&VideoCodec=vpx&AudioCodec=vorbis&AudioStreamIndex=1&VideoBitrate=64682126&AudioBitrate=128000&MaxAudioChannels=6&PlaySessionId=6c90c8a9deb34ed095dd4fa49eface56&api_key=42ce73dfd00846bbb9c5a6a41621f300&CopyTimestamps=false&EnableAutoStreamCopy=false *** Error Report *** Version: 3.0.5912.0 Command line: /usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe -programdata /var/lib/emby-server -ffmpeg /usr/local/bin/ffmpeg -ffprobe /usr/local/bin/ffprobe -restartpath /usr/lib/emby-server/restart.sh Operating system: Unix 4.1.19.7 Processor count: 4 64-Bit OS: False 64-Bit Process: False Program data path: /var/lib/emby-server Mono: 4.2.1 (Stable 4.2.1.102/6dd2d0d Thu Dec 3 05:10:20 UTC 2015) Application Path: /usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe Access to the path "/mnt/emby_disk/transcoding-temp" is denied. ServiceStack.HttpError No Stack Trace Available On a post you made on the thread "Emby Server on Raspberry Pi 2" you asked the OP if they had "include[d] x264 when compiling ffmpeg?" Your guide on page 6 of this thread was done after your post on the Emby Server on Raspberry Pi 2 thread. Did you forget to include the instructions to compile x264 into ffmpeg? If so at what point in your guide should we include them?
Luke 42245 Posted April 14, 2016 Author Posted April 14, 2016 Also Access to the path "/mnt/emby_disk/transcoding-temp" is denied. System.UnauthorizedAccessException That's something you'll need to fix. That's emby server trying to write to a path and getting denied by your OS.
