Laurent_Hubaut 0 Posted February 16, 2016 Posted February 16, 2016 Hi, I succesfully installed emby on a banana pi (jessie). Sometimes, the server gets killed by the low memory killer killing 'mono-sgen' to free XXX on behalf of kswapd0 because cache 5112KB is below 6144kB for oom_score_adj Any advice? Thanks
Bernie V 7 Posted February 16, 2016 Posted February 16, 2016 Hi, I succesfully installed emby on a banana pi (jessie). Sometimes, the server gets killed by the low memory killer Any advice? Thanks I use a USB stick in my pi for swapping.
Laurent_Hubaut 0 Posted February 16, 2016 Posted February 16, 2016 Thanks for the advice. I tested with a USB stick (2GB), but same issue. Seems that there is a leak My server version : 3.0.5870.0
hurricanehrndz 149 Posted February 16, 2016 Posted February 16, 2016 Try adjusting the memory options for Mono. Look at /etc/default/emby-sever Sent from my D6603 using Tapatalk
Bernie V 7 Posted February 16, 2016 Posted February 16, 2016 It was hard for me to find all the info to tweak the rpi for Emby. With the default settings running OSMC the device crashed a lot. This is a short list what I did to prevent crashing due to memory: - USB stick to swap of 2GB with vm.swappiness=70 in /etc/sysctl.conf - tweak mono options: MONO_ENV="MONO_THREADS_PER_CPU=500 MONO_GC_PARAMS=soft-heap-limit=256m,nursery-size=64m" MONO_OPTS="--optimize=all" in /etc/emby-server.conf - Memory management (add in/etc/sysctl.conf)vm.min_free_kbytes = 32768vm.vfs_cache_pressure = 300 - Overlcloaking -> don't use this. In the begin I tried but I had regular crashes. These are my overcloak settings in /boot/config.txt: arm_freq 850sdram_freq 400core_freq 375init_turbo 0over_voltage 0sdram_over_voltage 0 force turbo 0 - Memory split settings in /boot/config.txt: gpu_mem_256=112 gpu_mem_512=144 gpu_mem_1024=256 - Emby service in /etc/systemd/system/multi-user.target.wants/emby-server.service set restart=Always -> when the service should crash it restarts automatic Hope this helps you 1
Laurent_Hubaut 0 Posted February 17, 2016 Posted February 17, 2016 Thank you I will test with your settings
Laurent_Hubaut 0 Posted February 18, 2016 Posted February 18, 2016 the config file is /etc/default/emby-server or /etc/emby-server.conf
hurricanehrndz 149 Posted February 18, 2016 Posted February 18, 2016 First is an example, do not touch. Second is where you can write your changes. Copy the line you wish to change from the first file to the second and edit in second file as you wish Sent from my D6603 using Tapatalk
Laurent_Hubaut 0 Posted February 18, 2016 Posted February 18, 2016 Thanks to both of you, it seems more stable now
dimitrijp 0 Posted February 22, 2016 Posted February 22, 2016 Hi, Since I'm planning to move away from Plex, and like Emby more, I have problems with setup on RPI2. Everything installs ok, I added test media to my server, but I cant play it to remote client. I don’t want to use transcoding, but this doesn’t seem to work in emby at least on RPI2. I have 100/100Mb internet line, so bandwidth is not a problem. All media including flac music is being transcoded even if I try to use external player on Android like MX player. (BTW this was working for me on plex). Does someone have any idea how to use direct play only with RPI2 and Emby? If I go to user settings and disable option to play transcoded media, I get notification on client side that no suitable streams are available. Also in server logs I can see error: Info App: Bitrate exceeds DirectPlay limit thanks for help server_log.txt transcoding_log.txt
Luke 42245 Posted February 22, 2016 Author Posted February 22, 2016 the video is missing all media info. try refreshing it from the detail screen.
Iorifly 15 Posted February 27, 2016 Posted February 27, 2016 Friends, I bought my raspberry ... .Aguardando get to install Emby !!!!!
Iorifly 15 Posted February 29, 2016 Posted February 29, 2016 (edited) Reading calmly instruction of the first post ... Which system should I run the commands? OSMC ?? This being taken in considering which system installed in raspberry? ***************************************************** ****** Forget I saw that is / raspbian-jessie Edited February 29, 2016 by Iorifly
blindpet 0 Posted March 9, 2016 Posted March 9, 2016 I'd like to make a request to add libav-tools support instead of ffmpeg. Compiling from source is a pain for the end user and as far as I know it offers no benefit compared to the new (non-contentious) libav-tools. All current debian-based repositories do have libav-tools and no ffmpeg. WIth other media software like Madsonic and Subsonic you can use libav by symlinking it to /usr/bin/ffmpeg (same with avprobe to /usr/bin/ffprobe). I did that with this installation to test transcoding in the web browser but it fails, the logs only tell me this (even with debug logging enabled): Warn, App, ffmpeg is missing decoder h264_qsv Warn, App, ffmpeg is missing decoder mpeg2_qsv Warn, App, ffmpeg is missing decoder vc1_qsv Warn, App, ffmpeg is missing encoder libx265 Warn, App, ffmpeg is missing encoder srt
hurricanehrndz 149 Posted March 11, 2016 Posted March 11, 2016 There is precompiled ffmpeg I have posted earlier. That is statically built other than one library. Its in my plans to finish developing the static builds ffmpeg, I have just been super busy and I have a ton on my plate. I'm only one guy and it's a lot of work. Sent from my D6603 using Tapatalk
djonnie 14 Posted March 11, 2016 Posted March 11, 2016 (edited) I re-installed my RPI 2 Model B with Emby today since I couldn't find a 100% working procedure, I thought I'd share it here: write Raspbian Jessie to a micro SD card and boot your RPI 2 from it configure your network connect to the RPI using Putty sudo raspi-config choose option 1 to expand the filesystem to the size of the micro SD card choose option 3, B2 Console Autologin if you do not want to boot the GUI close raspi-config and reboot your RPI (sudo reboot) Installing Emby: wget -qO - http://download.opensuse.org/repositories/home:emby/xUbuntu_14.04/Release.key | sudo apt-key add - sudo sh -c "echo 'deb http://download.opensuse.org/repositories/home:/emby/xUbuntu_14.04/ /' >> /etc/apt/sources.list.d/emby-server.list" sudo apt-get update sudo apt-get install emby-server Make Emby autostart on boot: sudo systemctl enable emby-server Compile ffmpeg or you won't be able to play anything: cd /usr/src sudo git clone git://git.videolan.org/x264 cd x264 sudo ./configure --host=arm-unknown-linux-gnueabi --enable-static --disable-opencl sudo make sudo make install cd .. sudo git clone git://source.ffmpeg.org/ffmpeg.git cd ffmpeg sudo ./configure --arch=armel --target-os=linux --enable-gpl --enable-libx264 sudo make sudo make install Make Emby use this ffmpeg version: sudo nano /usr/bin/emby-server change: FFMPEG_BIN=$(command -v ffmpeg) to #FFMPEG_BIN=$(command -v ffmpeg) FFMPEG_BIN=/usr/local/bin/ffmpeg and change: FFPROBE_BIN=$(command -v ffprobe) to #FFPROBE_BIN=$(command -v ffprobe) FFPROBE_BIN=/usr/local/bin/ffprobe sudo service emby-server restart Almost ready... follow the wizard on the Emby server using http://<IP>:8096 in Emby Configuration add an "On application startup" trigger to the "Scan media library" task or you'll end up with an empty library after restarting Emby Edited March 19, 2016 by djonnie 2
Raspi2 Server 0 Posted March 18, 2016 Posted March 18, 2016 (edited) Make Emby use this ffmpeg version: sudo nano /usr/bin/emby-server change: FFMPEG_BIN=$(which ffmpeg) to #FFMPEG_BIN=$(which ffmpeg) FFMPEG_BIN=/usr/local/bin/ffmpeg and change: FFPROBE_BIN=$(which ffprobe) to #FFPROBE_BIN=$(which ffprobe) FFPROBE_BIN=/usr/local/bin/ffprobe Regarding this part of your post, When I nano /usr/bin/emby-server, I can only find this which doesn't quite match your example: # ffmpeg FFMPEG_BIN=$(command -v ffmpeg) [ -n "$FFMPEG_BIN" ] && FFMPEG_OPTS="-ffmpeg $FFMPEG_BIN" # ffprobe FFPROBE_BIN=$(command -v ffprobe) [ -n "$FFPROBE_BIN" ] && FFPROBE_OPTS="-ffprobe $FFPROBE_BIN" Should I comment out both "FFMPEG_BIN=$(command -v ffmpeg)" and "[ -n "$FFMPEG_BIN" ] && FFMPEG_OPTS="-ffmpeg $FFMPEG_BIN" as well as "FFPROBE_BIN=$(command -v ffprobe)" and "[ -n "$FFPROBE_BIN" ] && FFPROBE_OPTS="-ffprobe $FFPROBE_BIN"? If I do comment those line out, do I replace it with "FFMPEG_BIN=/usr/local/bin/ffmpeg)" and "FFPROBE_BIN=/usr/local/bin/ffprobe" respectively? Thanks! Edited March 18, 2016 by Raspi2 Server
djonnie 14 Posted March 19, 2016 Posted March 19, 2016 Sorry, there was an error in these steps. I updated the instructions.
Raspi2 Server 0 Posted March 19, 2016 Posted March 19, 2016 Sorry, there was an error in these steps. I updated the instructions. Thanks. My /usr/bin/emby-server file now looks like this: # ffmpeg #FFMPEG_BIN=$(command -v ffmpeg) FFMPEG_BIN=/usr/local/bin/ffmpeg [ -n "$FFMPEG_BIN" ] && FFMPEG_OPTS="-ffmpeg $FFMPEG_BIN" # ffprobe #FFPROBE_BIN=$(command -v ffprobe) FFPROBE_BIN=/usr/local/bin/ffprobe [ -n "$FFPROBE_BIN" ] && FFPROBE_OPTS="-ffprobe $FFPROBE_BIN" I followed through the wizard on the Emby server and selected /mnt as the source directory for my music collection. I have a 16GB thumb drive attached to the Pi for testing purposes with a bunch of music on it. Eventually I want to use a 1.5TB HDD. Both are formatted as NTFS. I am not able to see any of the music files. I've tried with my computer's browser and my Android App but it still won't show anything. I click on "Suggestions", "Albums", "Album Artists", etc. and nothing appears. I SSH'd into the Pi and there's nothing in the /mnt folder. Do I have to do something to get the Pi to recognize the thumb drive? Also, how do I edit the "Emby Configuration"? I looked through the "Advance Options" in the left pane of the Emby dashboard and couldn't find anything. In post #133 of this thread they mention that there is a configuration file in /etc/emby-server.conf . Is that where I add the trigger? If so how do I do that? Thanks!
djonnie 14 Posted March 19, 2016 Posted March 19, 2016 Also, how do I edit the "Emby Configuration"? I looked through the "Advance Options" in the left pane of the Emby dashboard and couldn't find anything. In post #133 of this thread they mention that there is a configuration file in /etc/emby-server.conf . Is that where I add the trigger? If so how do I do that? Connect to the Emby Server using your webbrowser, http://<IP-adres>:8096, go to the settings page, scroll down to scheduled tasks, find " Scan media library" and click on it and then add the trigger
djonnie 14 Posted March 19, 2016 Posted March 19, 2016 (edited) I followed through the wizard on the Emby server and selected /mnt as the source directory for my music collection. I have a 16GB thumb drive attached to the Pi for testing purposes with a bunch of music on it. Eventually I want to use a 1.5TB HDD. Both are formatted as NTFS. I am not able to see any of the music files. I've tried with my computer's browser and my Android App but it still won't show anything. I click on "Suggestions", "Albums", "Album Artists", etc. and nothing appears. I SSH'd into the Pi and there's nothing in the /mnt folder. Do I have to do something to get the Pi to recognize the thumb drive? you can try these steps from a SSH session: sudo fdisk -l find your USB device (easiest is to check the size column) and note the device name, for example /dev/sda1 sudo mkdir /mnt/emby_disk sudo nano /etc/fstab at the end of the file add a new line: <the device name> /mnt/emby_disk auto for example: /dev/sda1 /mnt/emby_disk auto close the file sudo mount -a the disk is mounted and now you can add libraries containing the files on this disk to your Emby Server configuration The disk must be available during boot, or Raspberry will not boot. So when replacing your USB stick with an USB HDD, you need to remove the USB stick from the fstab file before rebooting. Edited March 20, 2016 by djonnie
Raspi2 Server 0 Posted March 20, 2016 Posted March 20, 2016 @@djonnie Thank you for all your help! This worked perfectly.
FlyYX 2 Posted March 22, 2016 Posted March 22, 2016 My Ubuntu sever died so I got a rpi3 and followed the instructions from djonnie thanks btw but cant see my nas now. ( wd my cloud). I set it up just like Ubuntu but must have forgot something. I can see it if I go to its address in the address bar. but if I put it in the address in add media in emby it will not see it.
ChunkyKev 0 Posted March 27, 2016 Posted March 27, 2016 Hi Djonnie, an excelent post explaining how to set up Emby on Raspberry PI 2, something I have been looking for, for some time. I am not hugely techie so this was easy to follow. I dont seem to be able to get into emby via webpage though. I have checked my IP address is correct, I set it to static at beginning of tutorial, but when I go to browser nothing, cannot connect. Any ideas? I have now tried by enabling the Gui on start up, hoping to see Emby running, and I don't see anything there either? Any help would be great.
Raspi2 Server 0 Posted March 27, 2016 Posted March 27, 2016 I dont seem to be able to get into emby via webpage though. I have checked my IP address is correct, I set it to static at beginning of tutorial, but when I go to browser nothing, cannot connect. Any ideas? I have now tried by enabling the Gui on start up, hoping to see Emby running, and I don't see anything there either? Did you make sure that Emby starts up automatically when the Pi boots? It's the 3rd step in Djonnie's guide. At the command line enter: sudo systemctl enable emby-server Reboot your Pi and see if you can access Emby's server on the Pi.
