EsDeeEm 1 Posted December 14, 2015 Posted December 14, 2015 Thanks! If I'm correct, Jessie is distributed through the NOOB image, isn't it?
frankp 1 Posted December 14, 2015 Posted December 14, 2015 Yes, or just download the full image and put it on a SD-card. https://www.raspberrypi.org/downloads/raspbian/
frankp 1 Posted December 14, 2015 Posted December 14, 2015 Transcoding seems to be a problem for the RPI2. Installed ffmpeg through the jessie backport. Managed to get some video running through the web app, but no video in emby theater. The video in the web client is lagging like crazy, so unwatchable. Maybe someone can see somthing in the logs what's happening, but i'm about to give up on emby-server on the raspberry pi 2. log.txt serverlog.txt
hurricanehrndz 149 Posted December 14, 2015 Posted December 14, 2015 frankp, There is no way the RPI2 will ever have enough juice to transcode. The trick to getting emby-server working on RPI2 or any RPI is to have transcoding disabled as much as possible. If you would like some guidance on this, please see the following thread: http://emby.media/community/index.php?/topic/28419-emby-docker-image-for-arm-armhf-arch-mini-computers-raspeberry-pi2-cubietruck-odroid-etc/
frankp 1 Posted December 14, 2015 Posted December 14, 2015 That's a bummer. I need the transcoding because i also run media on my Samsung Smart TV. Direct play through the mediaserver of my synology nas would be the answer, but no idea if that's ever gonna happen.
hurricanehrndz 149 Posted December 14, 2015 Posted December 14, 2015 Are you certain, I would check what the TV supports and adjust the media profiles. That is how most users accomplish supporting their tvs from an RPI.
frankp 1 Posted December 14, 2015 Posted December 14, 2015 Yes, i already asked in the Samsung-app board http://emby.media/community/index.php?/topic/27326-direct-stream-on-es5500/
djonnie 14 Posted December 15, 2015 Posted December 15, 2015 @@frankp I think your nas supports smb sharing use this with path substitution and mb theater won't ask the server for transcoding
frankp 1 Posted December 15, 2015 Posted December 15, 2015 According to the developer of the Samsung Smart TV Emby app, the app doesn't support direct play but always wants to use decoding. Path substitution does work with my mediaplayer with Kodi.
hurricanehrndz 149 Posted December 15, 2015 Posted December 15, 2015 Maybe a roku would be a good investment.
frankp 1 Posted December 15, 2015 Posted December 15, 2015 The problem is that the Pi was already an investment because emby isn't available for my Synology NAS (DS213+). I think i just gonna wait untill it becomes available for my NAS or I have the money to replace my NAS.
hurricanehrndz 149 Posted December 15, 2015 Posted December 15, 2015 Another option is to use the pi 2 play the videos as well. Stick kodi on it.
Luke 42245 Posted December 15, 2015 Author Posted December 15, 2015 Once the current beta goes stable, the web client with the Chrome browser will be a very robust choice that won't require much transcoding. See the blog post to learn more.
chacawaca 109 Posted December 16, 2015 Posted December 16, 2015 Hi i installed emby-server on a ubuntu-mate raspberry pi2 and server keep crash and i get this error : Error HttpServer: Error this.ProcessRequest(context)(Exception while writing error to the response) *** Error Report *** Version: 3.0.5781.5 Command line: /usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe -programdata /var/lib/emby-server -ffmpeg /usr/bin/ffmpeg -ffprobe /usr/bin/ffprobe -restartpath /usr/lib/emby-server/restart.sh Operating system: Unix 4.1.10.7 Processor count: 4 64-Bit OS: False 64-Bit Process: False Program data path: /var/lib/emby-server Mono: 4.2.1 (Stable 4.2.1.102/6dd2d0d Thu Dec 3 05:10:20 UTC 2015) Application Path: /usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe Cannot access a disposed object. Object name: 'SocketHttpListener.Net.HttpListenerResponse'. System.ObjectDisposedException at SocketHttpListener.Net.HttpListenerResponse.set_StatusCode (Int32 value) <0x70fc3a38 + 0x00080> in <filename unknown>:0 at MediaBrowser.Server.Implementations.HttpServer.SocketSharp.WebSocketSharpResponse.set_StatusCode (Int32 value) <0x70fc39e8 + 0x00027> in <filename unknown>:0 at MediaBrowser.Server.Implementations.HttpServer.HttpListenerHost.ErrorHandler (System.Exception ex, IRequest httpReq) <0x70fc0000 + 0x0038f> in <filename unknown>:0
hurricanehrndz 149 Posted December 18, 2015 Posted December 18, 2015 Which package did you install? Sent from my D6603 using Tapatalk
chacawaca 109 Posted December 19, 2015 Posted December 19, 2015 wget -qO - http://download.opensuse.org/repositories/home:emby/xUbuntu_14.04/Release.key | sudo apt-key add -sudo sh -c "echo 'deb http://download.opensuse.org/repositories/home:/emby/xUbuntu_14.04/ /' >> /etc/apt/sources.list.d/emby-server.list" sudo apt-get updatesudo apt-get install mono-runtime mediainfo libsqlite3-dev imagemagick-6.q8 libmagickwand-6.q8-2 libmagickcore-6.q8-2sudo apt-get install emby-server then this http://emby.media/community/index.php?/topic/28188-massive-update-for-debian-and-ubuntu/?hl=%2Bdebian+%2Bmassive+%2Bupdate i have wipe my unbuntu-mate install, install openmediavault for raspberry pi install emby plugins that work. but i would have prefer to have emby directly on ubuntu-mate, but i cant scan my library at all without having to reboot emby
hurricanehrndz 149 Posted December 19, 2015 Posted December 19, 2015 Interesting, there was an issue with an intermediate release. That was addressed by Luke sometime after your original post. The instructions that ask you to install libmagick are out dated. A simple apt-get install emby-server should be sufficient. Currently I would recommend using the latest beta. The issue you encountered could have also been due to the fact that although we had fixed the issue obs does take some time to get the arm builds done, up to 2 days. Sent from my D6603 using Tapatalk
Bernie V 7 Posted December 26, 2015 Posted December 26, 2015 I'm running osmc on a Pi2 (installed with latest osmc image). osmc comes with mono version 3.2.8. I can't get rid of this version, Emby needs version 4. After uninstalling mono and installing mono-complete the system installs version 3.2.8 again. I've looked here to upgrade the mono package: http://superuser.com/questions/883889/apt-doesn-t-seem-to-update-package-sources-when-attempting-to-install-mono-on-ub What I'm doing wrong?
Skarp 0 Posted December 26, 2015 Posted December 26, 2015 Hello I've followed the instruction on a fresh jessie-lite and everything seems to work fine. I can start the service with sudo service emby-server start and works fine. Only problem is when i reboot the system the service doesn't autostart. How can i fix this?
hurricanehrndz 149 Posted December 26, 2015 Posted December 26, 2015 Systemlctl enable emby-server Sent from my D6603 using Tapatalk 1
thereforguy 1 Posted January 13, 2016 Posted January 13, 2016 I'm getting a whole host of ffprope errors on Raspbian, with ffmpeg installed from deb-multimedia. 2016-01-13 12:12:16.6493 Error MediaEncoder: ffmpeg image extraction failed for file:"(.mkv file)" 2016-01-13 12:12:16.6499 Error MediaEncoder: I-frame image extraction failed, will attempt standard way. Input: file:"(same .mkv file)" 2016-01-13 12:12:42.5052 Info MediaEncoder: Killing ffmpeg process Should I try another source for getting ffmpeg? (Attached the log file anyway) server-63588283509.txt
Luke 42245 Posted January 13, 2016 Author Posted January 13, 2016 yea it looks like it doesn't like the version we're providing, for some reason. 1
hurricanehrndz 149 Posted January 13, 2016 Posted January 13, 2016 I don't think it's our version. He is using one installed on his system. I think he should perhaps try our version Sent from my D6603 using Tapatalk 1
djonnie 14 Posted January 13, 2016 Posted January 13, 2016 This afternoon I took a fresh SD micro card, installed Raspbian Jessie and followed these steps to install Emby: wget -qO - http://download.opensuse.org/repositories/home:emby/xUbuntu_14.04/Release.key| sudo apt-key add - sudo sh -c "echo 'deb http://download.opensuse.org/repositories/home:/emby/xUbuntu_14.04//' >> /etc/apt/sources.list.d/emby-server.list" sudo apt-get updatesudo apt-get install emby-serversudo systemctl enable emby-server Installation was smooth, didn't take very long and in the end I had Emby running. Great! But now I'm running in the same issues as posted by me in http://emby.media/community/index.php?/topic/27026-raspberry-pi/&do=findComment&comment=263356. FFMpeg is not functioning, so I'm afraid there's still something wrong. So unfortunately in the end I switched back to my old SD card and I'm running Jessie with my self compiled ffmpeg version. 1
