hurricanehrndz 149 Posted November 6, 2015 Posted November 6, 2015 There also seems to be an issue with armel and armhf, we don't support armel and it seems he is using an armel device.
Sabcoll 0 Posted November 6, 2015 Posted November 6, 2015 It's weird, i already tried that. I uncommented the line in sources.list, but i get an error of unmet dependencies: apt-get install mono-runtime mediainfo libsqlite3-dev imagemagick-6.q8 libmagickwand-6.q8-2 libmagickcore-6.q8-2 Reading package lists... Done Building dependency tree Reading state information... Done mediainfo is already the newest version. mono-runtime is already the newest version. Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming. The following information may help to resolve the situation: The following packages have unmet dependencies: libmagickcore-6.q8-2 : Depends: libjpeg8 (>= 8c) but it is not installable E: Unable to correct problems, you have held broken packages. Got it working. Okay, so what i did: deb http://ports.ubuntu.com/ trusty main restricted universe multiverse i deleted the -armhf string and then it downloaded just fine! installing emby server now, let's see what happens..
hurricanehrndz 149 Posted November 6, 2015 Posted November 6, 2015 (edited) Got it working. Okay, so what i did: deb http://ports.ubuntu.com/ trusty main restricted universe multiverse i deleted the -armhf string and then it downloaded just fine! installing emby server now, let's see what happens.. May I ask what your cpu and system is that your running? Thank you for your feedback, perhaps we can change it if people report back with enough success. Edited November 6, 2015 by hurricanehrndz
Sabcoll 0 Posted November 6, 2015 Posted November 6, 2015 ;-)Maybe you got me here. I'm running a bananaPi - standard one. SoC: Allwinner A20 ARM-Cortex-A7-CPU Dual Core System is the latest Bananian (Debian based) with Jessie.
Sabcoll 0 Posted November 6, 2015 Posted November 6, 2015 (edited) wget -qO - http://download.opensuse.org/repositories/home:emby/xUbuntu_14.04/Release.key | sudo apt-key add - sudo sh -c "echo 'deb http://download.opensuse.org/repositories/home:/emby/xUbuntu_14.04/ /' >> /etc/apt/sources.list.d/emby-server.list" sudo apt-get update # With Bananian: echo "deb http://ports.ubuntu.com/ trusty main restricted universe multiverse" > /etc/apt/sources.list.d/trusty.list cat << EOF | sudo tee -a /etc/apt/preferences.d/trusty.pref Package: * Pin: release a=trusty Pin-Priority: 10 EOF sudo apt-get install mono-runtime mediainfo libsqlite3-dev imagemagick-6.q8 libmagickwand-6.q8-2 libmagickcore-6.q8-2 sudo apt-get install emby-server But i'm encountering some other issued: W: GPG error: http://ports.ubuntu.com trusty Release: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 40976EAF437D05B5 NO_PUBKEY 3B4FE6ACC0B21F32 E: dpkg was interrupted, you must manually run 'dpkg --configure -a' to correct the problem. When i run " dpkg --configure -a" Setting up emby-server (3.0.5781.0) ... [ ok ] Starting emby-server daemon:. And then: Nothing! If i skip with control + c and start emby by hand: sudo service emby-server start emby starts. i can access emby via firefox .. but apt-get is not working anymore, because system stops on [ ok ] Starting emby-server daemon:. ... any ideas? ___ emby seems to cause some more trouble: apt-get install samba E: Could not get lock /var/lib/dpkg/lock - open (11: Resource temporarily unavailable) E: Unable to lock the administration directory (/var/lib/dpkg/), is another process using it? Edited November 6, 2015 by Sabcoll
djonnie 14 Posted November 6, 2015 Posted November 6, 2015 Okay, Instead of compiling have you tried using the following ppa? http://www.deb-multimedia.org/ Yes, I tried that one, but it has no H264 support, that's why I compiled it myself
hurricanehrndz 149 Posted November 6, 2015 Posted November 6, 2015 Add the gpg key for ubuntu trusty gpg recv-keys 40976EAF437D05B5 gpg recv-keys 3B4FE6ACC0B21F32
djonnie 14 Posted November 6, 2015 Posted November 6, 2015 Thanks, maybe that needed for earlier versions of raspbian. Just like Sabcoll I'm using Raspbian Jessie The steps under "If running Raspbian" were not needed on my PI 2
Sabcoll 0 Posted November 6, 2015 Posted November 6, 2015 (edited) gpg recv-keys 40976EAF437D05B5 usage: gpg [options] [filename] How can i add these keys? Never had such an issue before.. edit: gpg --keyserver hkp://keyserver.ubuntu.com --recv-keys 3B4FE6ACC0B21F32 still the same error... pg --recv-keys 40976EAF437D05B5 3B4FE6ACC0B21F32 gpgkeys: key 3B4FE6ACC0B21F32 not found on keyserver gpg: key 437D05B5: "Ubuntu Archive Automatic Signing Key <ftpmaster@ubuntu.com>" not changed gpg: Total number processed: 1 gpg: unchanged: 1 gpg: requesting key 437D05B5 from hkp server keys.gnupg.net gpg: requesting key C0B21F32 from hkp server keys.gnupg.net gpg: key 437D05B5: "Ubuntu Archive Automatic Signing Key <ftpmaster@ubuntu.com>" not changed gpg: key C0B21F32: "Ubuntu Archive Automatic Signing Key (2012) <ftpmaster@ubuntu.com>" not changed gpg: Total number processed: 2 gpg: unchanged: 2 I managed to add the keys: apt-key adv --recv-keys 40976EAF437D05B5 3B4FE6ACC0B21F32 well.. apt-get update works now. still i cant play videos: /var/lib/emby-server/ffmpeg/20150917/ffmpeg /var/lib/emby-server/ffmpeg/20150917/ffmpeg: error while loading shared libraries: libva.so.1: cannot open shared object file: No such file or directory is it possible that ffmpeg is no longer supported by jessie? https://packages.debian.org/en/jessie/libav-tools Edited November 6, 2015 by Sabcoll
djonnie 14 Posted November 6, 2015 Posted November 6, 2015 You can compile it yourself, the instructions are in this thread
Sabcoll 0 Posted November 7, 2015 Posted November 7, 2015 What do i need to edit? I dont understand this .sh file at all -.- sudo make install and then editing emby-server.sh to use this version of ffmpeg.
djonnie 14 Posted November 7, 2015 Posted November 7, 2015 (edited) What do i need to edit? I dont understand this .sh file at all -.- sudo make install and then editing emby-server.sh to use this version of ffmpeg. When the service emby-server is started (sudo service emby-server start) it starts /usr/lib/emby-server/emby-server.sh For some reason this script will not find the compiled ffmpeg / ffprobe version. I solved this on my PI by editing these lines (sudo nano /usr/lib/emby-server/emby-server.sh): # ffmpeg FFMPEG_BIN=$(which ffmpeg) [ -n "$FFMPEG_BIN" ] && FFMPEG_OPTS="-ffmpeg $FFMPEG_BIN" # ffprobe FFPROBE_BIN=$(which ffprobe) [ -n "$FFPROBE_BIN" ] && FFPROBE_OPTS="-ffprobe $FFPROBE_BIN" to... # ffmpeg #FFMPEG_BIN=$(which ffmpeg) FFMPEG_BIN=/usr/local/bin/ffmpeg [ -n "$FFMPEG_BIN" ] && FFMPEG_OPTS="-ffmpeg $FFMPEG_BIN" # ffprobe #FFPROBE_BIN=$(which ffprobe) FFPROBE_BIN=/usr/local/bin/ffprobe [ -n "$FFPROBE_BIN" ] && FFPROBE_OPTS="-ffprobe $FFPROBE_BIN" Edited November 7, 2015 by djonnie
frankp 1 Posted November 7, 2015 Posted November 7, 2015 On my fresh Raspbian Jessie install, Emby is working without the second step of the instructions. Now i'm only struggling to get the media paths correct. I want to add the path to my NAS (\\nas) but i get this in return: there was an error adding the media path I did got an error at the end of the install of emby saying the user "emby" doesn't have acces to some locations on the RPI2.
djonnie 14 Posted November 7, 2015 Posted November 7, 2015 (edited) On my fresh Raspbian Jessie install, Emby is working without the second step of the instructions. Now i'm only struggling to get the media paths correct. I want to add the path to my NAS (\\nas) but i get this in return: there was an error adding the media path I did got an error at the end of the install of emby saying the user "emby" doesn't have acces to some locations on the RPI2. I think you need to install a SMB client on your PI to be able to access a UNC path found a tutorial here, hope it helps: http://raspberrypihelp.net/tutorials/12-mount-a-samba-share-on-raspberry-pi after that you should use path substitution so that clients can directly access the files on your NAS without this the PI has to receive video's from the NAS and then send it over the network to the clients Edited November 7, 2015 by djonnie
frankp 1 Posted November 7, 2015 Posted November 7, 2015 So there has te be made a samba share on the Pi? I cannot point to my NAS directly?
djonnie 14 Posted November 7, 2015 Posted November 7, 2015 So there has te be made a samba share on the Pi? I cannot point to my NAS directly? it's not exactly a share like in SMB sharing you have to mount the NAS to a directory on your PI, so Emby-Server will see your NAS as a local path ( /mnt/.... ) you need a SMBClient to be able to mount your NAS to a UNC share (\\NAS\....) for your clients you setup path substitution, so that they will contact the NAS directly
frankp 1 Posted November 9, 2015 Posted November 9, 2015 Server is up and running. It works in Kodi with directstreaming Next problem: No images are showing.
hurricanehrndz 149 Posted November 9, 2015 Posted November 9, 2015 Do you have a log you could post? Sent from my D6603 using Tapatalk
Luke 42244 Posted November 10, 2015 Author Posted November 10, 2015 ImageMagick is failing saying you have some bad files Empty input file `/mnt/series/The Sopranos/landscape.jpg' @ error/jpeg.c/JPEGErrorHandler/322 ImageMagickSharp.WandException
daisyb 0 Posted November 13, 2015 Posted November 13, 2015 I'm getting massive install failures after "sudo apt-get install emby-server" on a fresh install of raspbian Jessie. The first failure I can see is: " * Installing 1 assembly from libnunit-core-interfaces2.6.3-cil into Mono Illegal instructionUse of uninitialized value $_ in scalar chomp at /usr/share/cli-common/runtimes.d/mono line 275." snapshot of my command line text showing the complete list of failures is attached error.txt
djonnie 14 Posted November 13, 2015 Posted November 13, 2015 I'm getting massive install failures after "sudo apt-get install emby-server" on a fresh install of raspbian Jessie. The first failure I can see is: " * Installing 1 assembly from libnunit-core-interfaces2.6.3-cil into Mono Illegal instructionUse of uninitialized value $_ in scalar chomp at /usr/share/cli-common/runtimes.d/mono line 275." snapshot of my command line text showing the complete list of failures is attached Did you follow these steps? wget -qO - http://download.opensuse.org/repositories/home:emby/xUbuntu_14.04/Release.key | sudo apt-key add - sudo sh -c "echo 'deb http://download.opensuse.org/repositories/home:/emby/xUbuntu_14.04/ /' >> /etc/apt/sources.list.d/emby-server.list" sudo apt-get update sudo apt-get install mono-runtime mediainfo libsqlite3-dev imagemagick-6.q8 libmagickwand-6.q8-2 libmagickcore-6.q8-2 sudo apt-get install emby-server Do not follow the steps "If running Raspbian". They are not needed and will result in errors. You also need to compile ffmpeg yourself, you can find the steps in this thread.
