bluebug 0 Posted November 1, 2015 Posted November 1, 2015 Hi, I've just rebuilt my Emby media server that has been running on Windows to the FreeNAS plugin (Version 3.0.5768.7). My existing supporter key says: You are on the Lifetime subscription plan. It is valid for the life of the 3.x major version. However when I enter it into the supporter key section under Help in the FreeNAS plugin I get the error: Emby Premiere key is missing or invalid. In order for any premium content to be registered, you must also have an active Emby Premiere subscription. Is a new key required or is there an extra step that I am missing? Server log file attached. Thanks Log.txt
Solution ebr 16307 Posted November 1, 2015 Solution Posted November 1, 2015 No, a new key is not required but it looks like you may have a DNS or other network access problem on that machine. Error: NameResolutionFailure
bluebug 0 Posted November 1, 2015 Author Posted November 1, 2015 Thanks for that, found a stupid networking error. No suprise that it comes down to user error :-)
