Guest walkme70 Posted November 1, 2015 Posted November 1, 2015 (edited) The Trakt Addin returns a "Sync library to trakt.tv failed" when run on the schedule, however when I manually press the start it run's no problems. Any idea's why ? Running the latest version of server - Version 3.0.5781.0 and Trakt - 3.0.5754.43056 Edited November 1, 2015 by walkme70
MrLinford 62 Posted November 6, 2015 Posted November 6, 2015 (edited) I have just set mine to scheduled task and will check it out. Mine is not scrobbleing at the moment, is yours? 2015-11-05 21:12:32.9953 Info - Trakt: Playback Stopped2015-11-05 21:12:32.9953 Info - Trakt: Item is played. Scrobble2015-11-05 21:12:33.0266 Error - Trakt: Exception handled sending status update*** Error Report ***Version: 3.0.5781.0Command line: C:\Users\Craig\AppData\Roaming\Emby-Server\System\MediaBrowser.ServerApplication.exeOperating system: Microsoft Windows NT 6.2.9200.0Processor count: 464-Bit OS: True64-Bit Process: FalseProgram data path: C:\Users\Craig\AppData\Roaming\Emby-ServerApplication Path: C:\Users\Craig\AppData\Roaming\Emby-Server\System\MediaBrowser.ServerApplication.exeThe request was aborted: Could not create SSL/TLS secure channel.System.Net.WebException at System.Net.HttpWebRequest.GetRequestStream(TransportContext& context) at System.Net.HttpWebRequest.GetRequestStream() at MediaBrowser.Common.Implementations.HttpClientManager.HttpClientManager.<SendAsyncInternal>d__1e.MoveNext()--- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Common.Implementations.HttpClientManager.HttpClientManager.<SendAsync>d__7.MoveNext()--- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Trakt.Api.TraktApi.<PostToTrakt>d__c5.MoveNext()--- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd(Task task) at Trakt.Api.TraktApi.<SendEpisodeStatusUpdateAsync>d__13.MoveNext()--- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Trakt.ServerMediator.<KernelPlaybackStopped>d__8.MoveNext() Edited November 6, 2015 by MrLinford
MrLinford 62 Posted November 6, 2015 Posted November 6, 2015 (edited) And here is the schedule log, also failed: Server Version 3.0.5781.0 Trakt Plugin Version 3.0.5754.43056 2015-11-06 11:34:37.4073 Info - HttpServer: HTTP GET http://192.168.0.2:8096/dlna/7d21756930f6d315b949cdd5cc145d45/description.xmlIp: 192.168.0.2:57962. Headers: Host=192.168.0.2:8096,Connection=close2015-11-06 11:34:37.4073 Info - HttpServer: HTTP Response 200 to 192.168.0.2. Time: 0ms. http://192.168.0.2:8096/dlna/7d21756930f6d315b949cdd5cc145d45/description.xml2015-11-06 11:36:31.7696 Info - App: IntervalTrigger fired for task: Sync library to trakt.tv2015-11-06 11:36:31.7696 Info - App: Queueing task SyncLibraryTask2015-11-06 11:36:31.7696 Info - App: Executing Sync library to trakt.tv2015-11-06 11:36:31.7852 Info - Trakt: 827 Items found for 'Craig'.2015-11-06 11:36:31.7852 Info - App: HttpClientManager GET: https://api-v2launch.trakt.tv/sync/watched/movies2015-11-06 11:36:31.8165 Error - App: Error getting response from https://api-v2launch.trakt.tv/sync/watched/movies*** Error Report ***Version: 3.0.5781.0Command line: C:\Users\Craig\AppData\Roaming\Emby-Server\System\MediaBrowser.ServerApplication.exeOperating system: Microsoft Windows NT 6.2.9200.0Processor count: 464-Bit OS: True64-Bit Process: FalseProgram data path: C:\Users\Craig\AppData\Roaming\Emby-ServerApplication Path: C:\Users\Craig\AppData\Roaming\Emby-Server\System\MediaBrowser.ServerApplication.exeOne or more errors occurred.System.AggregateException at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd(Task task) at MediaBrowser.Common.Implementations.HttpClientManager.HttpClientManager.<SendAsyncInternal>d__1e.MoveNext()InnerException: System.Net.WebExceptionThe request was aborted: Could not create SSL/TLS secure channel. at System.Net.HttpWebRequest.EndGetResponse(IAsyncResult asyncResult) at System.Threading.Tasks.TaskFactory`1.FromAsyncCoreLogic(IAsyncResult iar, Func`2 endFunction, Action`1 endAction, Task`1 promise, Boolean requiresSynchronization)2015-11-06 11:36:31.8165 Error - App: Error*** Error Report ***Version: 3.0.5781.0Command line: C:\Users\Craig\AppData\Roaming\Emby-Server\System\MediaBrowser.ServerApplication.exeOperating system: Microsoft Windows NT 6.2.9200.0Processor count: 464-Bit OS: True64-Bit Process: FalseProgram data path: C:\Users\Craig\AppData\Roaming\Emby-ServerApplication Path: C:\Users\Craig\AppData\Roaming\Emby-Server\System\MediaBrowser.ServerApplication.exeOne or more errors occurred.MediaBrowser.Model.Net.HttpException at MediaBrowser.Common.Implementations.HttpClientManager.HttpClientManager.<SendAsyncInternal>d__1e.MoveNext()--- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Common.Implementations.HttpClientManager.HttpClientManager.<SendAsync>d__7.MoveNext()--- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Common.Implementations.HttpClientManager.HttpClientManager.<Get>d__2.MoveNext()--- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Trakt.Api.TraktApi.<GetFromTrakt>d__bb.MoveNext()--- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Trakt.Api.TraktApi.<GetFromTrakt>d__b7.MoveNext()--- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Trakt.Api.TraktApi.<SendGetAllWatchedMoviesRequest>d__75.MoveNext()--- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd(Task task) at Trakt.ScheduledTasks.SyncLibraryTask.<SyncUserLibrary>d__23.MoveNext()--- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Trakt.ScheduledTasks.SyncLibraryTask.<Execute>d__2.MoveNext()--- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Common.Implementations.ScheduledTasks.ScheduledTaskWorker.<ExecuteInternal>d__c.MoveNext()InnerException: System.AggregateExceptionOne or more errors occurred. at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd(Task task) at MediaBrowser.Common.Implementations.HttpClientManager.HttpClientManager.<SendAsyncInternal>d__1e.MoveNext()InnerException: System.Net.WebExceptionThe request was aborted: Could not create SSL/TLS secure channel. at System.Net.HttpWebRequest.EndGetResponse(IAsyncResult asyncResult) at System.Threading.Tasks.TaskFactory`1.FromAsyncCoreLogic(IAsyncResult iar, Func`2 endFunction, Action`1 endAction, Task`1 promise, Boolean requiresSynchronization)2015-11-06 11:36:31.8165 Info - App: Sync library to trakt.tv Failed after 0 minute(s) and 0 seconds2015-11-06 11:36:31.9258 Info - App: HttpClientManager POST: https://api.pushbullet.com/v2/pushes Edited November 6, 2015 by MrLinford
paulsalter 84 Posted November 6, 2015 Posted November 6, 2015 Been going on for a while this problem http://emby.media/community/index.php?/topic/25184-trakt-scrobble/ If its a new show then it eventually gets sent to trakt, if its a rewatch then the play gets lost when this happens I have started looking at alternatives due to this problem
MrLinford 62 Posted November 6, 2015 Posted November 6, 2015 it worked for a good while, thought this was a new issue
paulsalter 84 Posted November 6, 2015 Posted November 6, 2015 (edited) It worked great for me for a long while, then about a couple of months ago it stopped working no one on here or the trakt forum replies to say whether its an app or trakt problem EDIT: my trakt plugin has just been updated, see if it fixes the issue Edited November 6, 2015 by paulsalter
Luke 42252 Posted November 6, 2015 Posted November 6, 2015 Luis added some fixes for running the plugin on non-windows operating systems. i then added some changes to the http requests to see if it helps with this problem 1
MrLinford 62 Posted November 6, 2015 Posted November 6, 2015 Well it appears so @@Luke. The trakt plugin updated to 3.0.5788.18703 early. Scrobble work and so has scheduled.
Guest walkme70 Posted November 7, 2015 Posted November 7, 2015 It would appear that the plugin update has cured my issue. Many thanks.
