Teddy 100 Posted October 31, 2015 Posted October 31, 2015 (edited) I did a clean install of Emby Server 3.0.5781.0 and it seems like there are actors who are in a kind of blacklist. For example the Jerry Lewis actor. I have several films of his and does not appear on the web client, or Emby for WMC, it seems Sever not want fetch this actor, but he is in the XML file or nfo.I did a clean database, refresh people, scan media library and even erasing all data of the movie but without success. Any ideas of this mysterious behavior ? https://www.themoviedb.org/movie/24062-the-patsy Edited November 1, 2015 by Teddy
Happy2Play 9800 Posted October 31, 2015 Posted October 31, 2015 What people options do you have selected for download Bio/images? Metadata-Advanced-People
Teddy 100 Posted October 31, 2015 Author Posted October 31, 2015 (edited) I have all the fetching options available to people. In fact only fault with this actor until I Know far . (maybe there are another actors with same issue.) Edited October 31, 2015 by Teddy
Solution custardcream 1 Posted November 1, 2015 Solution Posted November 1, 2015 (edited) What does his .xml file say? It should be located by default at C:\Users\$USER\AppData\Roaming\Emby-Server\metadata\People\J (where $USER is your Windows user) I've had people "drop off" when there was an issue there (the folder title might be Jerry Lewis but the xml might say something else, for example). Edited November 1, 2015 by custardcream 1
Teddy 100 Posted November 1, 2015 Author Posted November 1, 2015 custardcream , you are right, the XML file contains misinformation artist. I've fixed manually and it is now recognized. Thanks for your help
