af22 6 Posted December 4, 2013 Posted December 4, 2013 Just want to see if anyone has setup the ability to toggle subtitles from your remote control using LAV Splitter / Video / Audio with xyvsfilter. There used to be some really old solutions i've used back in Vista Media center, but they all work off fddshow and direct vob sub.
Cheesegeezer 3106 Posted December 6, 2013 Posted December 6, 2013 @@af22 Unfortunately xyvsfilter doesn't provide any "hooks" for this option to be made possible. You could try and see if mediacontrol has a hack for this but i doubt it
Maquiavel 0 Posted December 6, 2013 Posted December 6, 2013 Ok. Let me tell what I do. Maybe can help you. I use the external player MPC-HC. With MPC-HC is possible to change subtitles with a shortcut. S: Next Shift+A: Previous So, I just need to combine my remote with Eventghost to emulate the keystroke "S" I hope that helps you. Cya,
af22 6 Posted December 6, 2013 Author Posted December 6, 2013 Thanks for the reply maquiavel. I have toy'ed around in the past to use an external player. My HTPC has 4 tuners for liveTV, so I spend a lot of time in WMC and DVR mode. I have never really stayed with an external player too long as the single consistent UI feel really makes a big difference. Now with LAV codecs being more feature complete and very solid, it makes playback of x264 feel almost as native as recorded liveTV. I may go play with using MPC-HC again as an external filter. Maybe so I can use MADVR.
thefever 2 Posted December 24, 2013 Posted December 24, 2013 I've been using MCEremoteplus with directvobsub. I didn't care for xyvs filter. But MCE Remote Plus works great for me. Can even cycle subtitles. http://headsoft.com.au/?category=mce Sent from my Nexus 7
