Stretch and Wily support and more (libmediainfo0v5)
hurricanehrndz
You can always try and build the beta and/or the dev.
PS Did you install ffmpge from a ppa or are you using the one included in emby?
Yea, have thought of trying the beta.
I'm using the one with Emby.
hurricanehrndz
You could install ffmpeg from wily, the startup script will use the one in the system if it finds it. Which might address your issue.
The wily ffmpeg did the trick :D Thanks a bunch.
I was going bonkers from that scratch sound.
hurricanehrndz
No worries
Sent from my D6603 using Tapatalk
